October 13, 2026, 04:04:48 am
My >street/<strip '56
14
15
16
17
28
Topic: My >street/<strip '56 (Read 924962 times)
fahrvergnugen
Re: My >street/<strip '56
Reply #420 on:
February 18, 2011, 20:13:20 pm »
Quote from: Nico86 on February 18, 2011, 13:16:00 pm
I'll say it again but it's an impresive bodywork
Thanks Nico. The trick is, when your not satisfied, get the grinder and start over again.
Paul.
http://fast-air.skynetblogs.be/
Reply #421 on:
February 19, 2011, 17:10:48 pm »
GODDAMN Paul, you have patience and skill.
Last Edit: February 19, 2011, 18:15:23 pm by Harry/FDK
kev d
Reply #422 on:
February 19, 2011, 19:40:13 pm »
Hey Paul!
Build threads been quiet lately but you've obviously been keeping busy
Good work
Cheers,
Kev
fahrvergnugen
Reply #423 on:
February 19, 2011, 20:51:06 pm »
Quote from: Harry/FDK on February 19, 2011, 17:10:48 pm
No Harry, just patience and guts
fahrvergnugen
Reply #424 on:
February 19, 2011, 20:55:19 pm »
Quote from: kev d on February 19, 2011, 19:40:13 pm
Hey Paul!
Good work
Cheers,
Kev
Hey Kev, Yes it was quiet. I had a ski trip to the alps with "the guy's", I have bin ill and had some motivation problems. Today I worked on my wife's new car (
twingo
), and from now I will be updating again
Paul.
Reply #425 on:
February 21, 2011, 23:24:42 pm »
Stop talking Harry, time to drive this baby to EBI this year
If i make it lets race. Street versus Drag. Fun.
fahrvergnugen
Reply #426 on:
February 22, 2011, 07:26:22 am »
Quote from: Harry/FDK on February 21, 2011, 23:24:42 pm
That would be nice
, I will be there but my car will not be ready this year that's for sure.
See you at EBI.
fahrvergnugen
Reply #427 on:
February 26, 2011, 20:48:37 pm »
Today I did some more work under the hood. This is one of the holes to fix the gastank, needs some work
This looks a whole lot better.
The channels are welded, so Finlay it was time to take out the climbing frame
Looks better already
After I welded the channels to the body I lifted the body again, now I can stand in it and weld all the seems.
Paul.
fahrvergnugen
Reply #428 on:
March 16, 2011, 22:08:54 pm »
Started on the Tilton set yesterday.
Find the wright place to cut.
mounted the steering column and cut the hole.
And made the side panels.
Paul.
Last Edit: March 16, 2011, 22:11:39 pm by fahrvergnugen
thehanz DVK
Reply #429 on:
March 19, 2011, 20:15:22 pm »
looking great ouwe knutselaar.....
fahrvergnugen
Reply #430 on:
March 19, 2011, 20:35:38 pm »
Quote from: thehanz on March 19, 2011, 20:15:22 pm
Thanks Hans,
How is your '67 comming along? have you sold the notch?
fahrvergnugen
Reply #431 on:
March 19, 2011, 21:25:52 pm »
This morning bolted the body back on to check the pedal-steer-seat position
First I checked the old with the new pedal position, look good to me
Then fitted the seat and for the first time in a few years I took place behind the wheel
When I place the steering wheel 5cm closer to the seat, the position is spot on. The steering column can be moved 5cm without cutting or welding, how cool is that.
Before I weld the channels, I had to be sure that the trunk still fits. And it fits like a glove.
The gearbox and engine are raised, so the trunk has to be raised as well. After some measurement it seems that the trunk needs to be raised by 12cm.
Paul.
Last Edit: March 19, 2011, 21:27:57 pm by fahrvergnugen
fahrvergnugen
Reply #432 on:
March 23, 2011, 21:37:09 pm »
this piece gave me many headages
After a lot of hammering, grinding, welding and swearing, this is what I made of it. The plan is to give it it's original strength again
And when that is finished, build the mountingpoint for the rollcage around it.
This way I can still mount the back seat (I will probably never fit it). now it is time to read the official cage requirements, maybe I will need it in the future. :wink:
Paul.
Last Edit: March 23, 2011, 21:38:45 pm by fahrvergnugen
fahrvergnugen
Reply #433 on:
March 30, 2011, 20:42:58 pm »
I choose to not only spotweld, but to weld all round all edges. my goal is to make the welds close to invisible.
Welded the (ex)spotwelds (left-rear), and tried to make it invisible.
Also started doing the same to the right site.
Paul.
fahrvergnugen
Reply #434 on:
April 02, 2011, 20:54:59 pm »
Worked a few hours on the Tilton box today, unfortunately all the hours and effort can't be seeing.
First I made the pedals 100% fit in the box, then I took away all the sharp edges, changed the windings to metric windings, welded the box allround and grind-ed the welds.
When to box was to my standards I welded it to the body, just a few cm to go.
Paul.
fahrvergnugen
Reply #435 on:
April 06, 2011, 20:55:28 pm »
Made a hole for my bias adjustercable, damn i wish i had done this before welding.
Also started finishing the left doorpillar.
Paul.
fahrvergnugen
Reply #436 on:
April 09, 2011, 21:03:17 pm »
When I was working on the left pillar today, I noticed that the right pillar (out of a '66 car that already was welded to the heater channel) had a different shape, Damn... how Manny differences can you have
The left pillar is ready, well maybe a few tab's with a hammer away from being ready.
On these picture's you can see that the pillar out of the '66 car has a sharp bent, a '56 car does not have this bent.
So after I finished the left pillar I took out the grinder again and started to make the '66 look like a '56.
The result; '66 metal that looks like a '56.
Paul.
Last Edit: April 09, 2011, 21:06:17 pm by fahrvergnugen
tikimadness
Reply #437 on:
April 10, 2011, 09:59:45 am »
Keep going like that and it will get finished..........................................eventualy
No seriously looking good.You are finally making progress on the body.
Michael
Ps did you convince your wife we have to go to Hangover?
NIDGAFWYT
fahrvergnugen
Reply #438 on:
April 10, 2011, 12:59:37 pm »
Quote from: tikimadness on April 10, 2011, 09:59:45 am
Michael
Thanks buddy,
I am afraid Hangover is not gonna happen
fahrvergnugen
Reply #439 on:
April 13, 2011, 20:55:47 pm »
This week my new brake fluid reservoirs arrived from the UK, black anodised billet aluminium.
Now I have to think about how and where to mount them.
It looks damaged, but it's just dust.
Started to prep. the new left wing.
Paul.
mychatype3
Reply #440 on:
April 14, 2011, 12:34:35 pm »
Quote from: fahrvergnugen on April 13, 2011, 20:55:47 pm
NICE
love it, keep up the good work (respect voor je doorzettingsvermogen)
Greetz mycha
1968 fastback "in resto"
fahrvergnugen
Reply #441 on:
April 14, 2011, 19:41:32 pm »
Thanks mate, ik blijf het leuk vinden....vandaar
fahrvergnugen
Reply #442 on:
April 20, 2011, 19:56:17 pm »
Removed more useless metal from the (new
)inner wing , Damn the VW spotweld guy went crazy on that wing. The piece of wheel well that is still on there can stay for now.
Dare to go where no man is gone before
(I think)
The plan is to drill out the spotweld that hold the inner plate to the pillar, cut the pillar halfway the drilled holes and weld the new wing to it.
This is the cutting line.
Paul.
fahrvergnugen
Reply #443 on:
April 22, 2011, 21:11:22 pm »
Had a day off today, this meant I was still working only not at the office
sometimes I hate customers.
Between telephone calls I did some work on the oval.
cut the pillar along the line and left the inner plate.
I had to cut out some more rust.
a little test fit, when it all fits I can weld on a piece of flat with the inner plate underneed.
some more test fitting.
And where getting close.
The innerwings are different to the original oval wings, but i have to cut out the most to make room for the 914/911 front suspension..
Pas
Reply #444 on:
April 24, 2011, 11:53:19 am »
More quality workmanship going on there
fahrvergnugen
Reply #445 on:
April 24, 2011, 20:05:01 pm »
Quote from: Pas on April 24, 2011, 11:53:19 am
Thanks Pas, on the pic's it's almost done but i am far from satisfied.
Paul.
fahrvergnugen
Reply #446 on:
April 27, 2011, 20:56:41 pm »
Some jobs take more time than expected, these innerwings are that kind of a job.
The holes from drilling the spotweld had to be welded, they did not match with the new location. In the past someone mounted an emergency switch, this had to be closed as well.
After welding the holes, I smoothed them and I cleaned the area that can't be reached later on.
And before you know it....time's up.
fahrvergnugen
Reply #447 on:
May 07, 2011, 19:59:53 pm »
didn't want to do body work today, so I did some work on the chassis.
I was not satisfied with the place where the fuellines came out the chassistube. again a hole was made
It does not show on the pictures, but the hydraulic clutchline is now near the fuellines.
Paul.
fahrvergnugen
Reply #448 on:
May 07, 2011, 20:01:52 pm »
New package arrived from the US of A
Reply #449 on:
May 07, 2011, 20:10:16 pm »
Quote from: fahrvergnugen on March 30, 2011, 20:42:58 pm
If you do that then nobody can see them
http://selvedgeyard.com/
14
15
16
17
28
