September 22, 2026, 13:28:35 pm
Pages: 1 ... 17 18 [19] 20 21 ... 28 Print
Author Topic: My >street/<strip '56  (Read 908116 times)
fahrvergnugen
« Reply #540 on: October 13, 2012, 13:48:23 pm »
Next week I can Finlay work on the car again. the trailer is completely level and the car is welded on it at the wright height.
Paul.
fahrvergnugen
« Reply #541 on: October 18, 2012, 20:45:16 pm »
Finlay did some work to the car again Smiley
Paul.
fahrvergnugen
« Reply #542 on: October 24, 2012, 20:49:01 pm »
1/4 panel is welded up now. IRL it's pretty strait, even without filler.
Also started repairing the innerwing, here it's almost finished
Paul.
fahrvergnugen
« Reply #543 on: October 27, 2012, 17:14:07 pm »
Innerwing is done.
Paul.
thehanz DVK
« Reply #544 on: October 27, 2012, 17:19:03 pm »
looking good...
fahrvergnugen
« Reply #545 on: October 27, 2012, 20:13:48 pm »
looking good...
Wink
fahrvergnugen
« Reply #546 on: November 28, 2012, 21:46:24 pm »
Is wasn't easy to get the dash near the doorpillar. I finally managed it and it looks good if I say so my self.
Paul.
fahrvergnugen
« Reply #547 on: December 01, 2012, 14:41:55 pm »
Right innerwing is almost done, only the marked pieces need some love.
Paul.
fahrvergnugen
« Reply #548 on: December 12, 2012, 22:02:03 pm »
After the innerwing was done, it was time to start with the Porsche front beam.
Porsche sheetmetal underneed the spare wheel well
When the car is finished it should not have rake. Now it has a 3,6deg rake, this is why the arm has to be 3,6deg. as well.
Bend and shaped 3mm steel tacked in.
The innerwing has to come out a bid to reinforce the a-arm mounting point.
Paul.
tikimadness
« Reply #549 on: December 12, 2012, 22:21:49 pm »
Why the 3 mm plate? Are you welding the bracket to it or are you going to make it a bolt on affair?
Michael
NIDGAFWYT
fahrvergnugen
« Reply #550 on: December 13, 2012, 08:05:09 am »
The Porsche bracket Will be welded to this plate and The roll-cage will be welded on The other Side.
« Reply #551 on: December 13, 2012, 12:37:50 pm »
The sheet metal you are working with here will take a huge amount of weight/force during heavy braking. I guess the torsion bar mounts to the chassis in the other end.
I would suggest to either box a structure all the way to the front firewall or even tie in the cage down there.  As the weakest point would be in the body between the notch for the stock beam and the tank hole. Please keep sharing this cool project!
fahrvergnugen
« Reply #552 on: December 13, 2012, 20:53:24 pm »
Hi JHU,
The sheet metal is just the piece you see in the picture, there now is a piece on the right in the spare wheel well and when I am finished it has one on the left as well. I don't see how these small pieces will give problems during braking. When the new engine is ready, I will probably need more weight in the front Wink
The cage will also be welded to the new sheet metal you see in the spare wheel well. This is a '56 beetle, it has no tank hole Grin
I will, thanks
fahrvergnugen
« Reply #553 on: December 13, 2012, 21:02:11 pm »
JHU, Here's the other end of the A-arm mount. this picture was taken way waaay back Grin
http://cal-look.no/lounge/index.php?action=dlattach;topic=7217.0;attach=33163
fahrvergnugen
« Reply #554 on: December 15, 2012, 22:01:49 pm »
As I told earlyer, I had to widen the innerwing a bit, so I had to try it with cardboard first.
When the cardboard fitted, I made it out of sheetmetal and welded it in.
Then I tack welded the Porsche bracket in place. I just had to try the shockabsorber.
Paul.
56BLITZ
« Reply #555 on: December 15, 2012, 23:18:05 pm »
I am guessing that you will tie the upper strut mounting to the roll cage also?
Nice work . . . glad to see your progress!
fahrvergnugen
« Reply #556 on: December 16, 2012, 10:01:46 am »
You guessed Wright, the plan is to mount the upper too the cage as well. The original Porsche upper mounts will be welded in the inner wings and attached to the roll cage. Wink
kev d
« Reply #557 on: December 19, 2012, 10:39:27 am »
Looks like you're coming to the end of the main fab work now though Grin
Is it mostly finishing off type jobs now before starting body prep?
Kev
fahrvergnugen
« Reply #558 on: December 19, 2012, 22:06:44 pm »
Kev
Still a long way to go Kev. but where getting closer. Cool
fahrvergnugen
« Reply #559 on: December 19, 2012, 22:11:18 pm »
there's a hole in the innerwing Grin. I am going for 6-7deg.caster, -1camber and 0 toe in/out.
Inside of the innerwing, not much space there.
And ofcourse I needed to test a wheel.
Paul.
tikimadness
« Reply #560 on: December 19, 2012, 22:57:49 pm »
Looks like you need to put a wing on it to see how it looks Wink
Michael
NIDGAFWYT
fahrvergnugen
« Reply #561 on: December 20, 2012, 20:13:37 pm »
Michael
That is tempting indeed Wink
Black Sheep
less is more
« Reply #562 on: December 20, 2012, 21:05:02 pm »
I'm loving this concept / project , almost make's me want to tear my 49 apart and start again .
Keep it up really looking forward to seeing the end result  Cool
13.03 @ 98mph
fahrvergnugen
« Reply #563 on: December 20, 2012, 22:16:23 pm »
Thanks for the kind words but please don't tear yours apart, it's almost finished.
I am looking forward to the end result too.
Cheers Paul.
56BLITZ
« Reply #564 on: December 21, 2012, 09:31:57 am »
As am I, but I’m inspired in the craftsmanship you are displaying in the process!
fahrvergnugen
« Reply #565 on: December 21, 2012, 13:36:17 pm »
Thanks for the compliment, stay tuned  Grin
fahrvergnugen
« Reply #566 on: December 22, 2012, 21:16:57 pm »
Unfortunately I had to little space to move the spindle up n down. after some internet searching, I found out that the golf1 inserts will fit the Porsche strut and is 2" shorter. so I bought a used set to test fit.
if it fits I can shorten the complete strut by 2".
Paul.
« Last Edit: December 22, 2012, 21:20:03 pm by fahrvergnugen » Logged
tikimadness
« Reply #567 on: December 22, 2012, 21:47:57 pm »
Are you driving it to Bug-in Grin Grin Grin
Michael
NIDGAFWYT
fahrvergnugen
« Reply #568 on: December 22, 2012, 21:51:02 pm »
Michael
If there's a bug-in #10 Grin
fahrvergnugen
« Reply #569 on: December 28, 2012, 14:04:09 pm »
Point of no return (again)
I had planned to use more of the Porsche innerwing, but I did not have enough space. Now I only used the upper shockmount and made it 5cm higher. When I find the correct position I will weld it in the innerwing.
Paul.
