April 25, 2024, 23:08:29 pm
350687 Posts in 28576 Topics by 6822 Members
Latest Member: tpb_karl
Pages: 1 ... 24 25 [26] 27 Print
Author Topic: My >street/<strip '56  (Read 257063 times)
fahrvergnugen
« Reply #750 on: January 16, 2016, 14:05:22 pm »
I could use those red brake line brackets-where did u find them? Or do you wanna get rid of yours?
Nic
Hi Nic,
here is there site.
http://stores.ebay.co.uk/Torques-U-K
Cheers.
fahrvergnugen
« Reply #751 on: January 16, 2016, 14:07:16 pm »
Can anyone tel me what the best method is to determine the driveshaft length?
Nikke
« Reply #752 on: January 19, 2016, 08:22:54 am »
Nic
Hi Nic,
here is there site.
Cheers.
Thank you!
« Reply #753 on: January 19, 2016, 09:49:56 am »
Paul
good to see some progress Smiley  With gearbox mounted in car and stub axles in arms, I try to get them in a straight line so middle of stub axle is in line with middle on gearbox output then measure face to face where Cvs will bolt on, that is length I use as its at its shortest point
fahrvergnugen
« Reply #754 on: January 19, 2016, 18:26:06 pm »
Paul
Thanks Richie, I Will measure it this way👍🏼
fahrvergnugen
« Reply #755 on: February 27, 2016, 17:14:27 pm »
Hydraulic thrust bearing test setup.
First I made a bracket to mount the bearing in the gearbox
Setup an old master cylinder and tested the clutch.
I miss the weight of the car and power of the engine, but it seems to work just fine. Cool
« Last Edit: February 27, 2016, 17:25:40 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #756 on: March 10, 2016, 21:28:27 pm »
Bought some new toy's
« Last Edit: March 10, 2016, 21:30:19 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #757 on: April 13, 2016, 21:03:53 pm »
Small step. it's on wheels again (only two for now)
Now it's on it's wheels I could adjust the height and found out that the coilovers where hitting the drive shafts. So back to the drawingboard:mad:
The fuel system is almost complete. this week I received the pumps, pumpbrackets and regulators. one set for the carb's and one set for the nitrous.
Paul.
fahrvergnugen
« Reply #758 on: April 24, 2016, 19:44:59 pm »
Relocated the upper shockmounts. now the axles run free.
Played with the camber adjusters on the rear. i am happy for now.
Difference before and after adjusting is around 2cm on the top side of the tire.
fahrvergnugen
« Reply #759 on: April 30, 2016, 16:57:06 pm »
After the camber adjustment on the rearwheels I wasn't happy with the outcome and adjusters, so I'll make a new attempt..
kev d
« Reply #760 on: May 01, 2016, 08:48:40 am »
Have you got a new set up planned Paul?
Kev
fahrvergnugen
« Reply #761 on: May 01, 2016, 09:07:11 am »
Kev
Hi Kev,
Yes i have new plans. I will make new brackets for 12mm bolts and weld them in a higher position. also thinking of monoball instead of the urethane bushes like this;
http://www.pelicanparts.com/techarticles/911_monoball/911_monoball2.htm
also the outher uniballs will be welded in a lower position, this way the whole arm sits in a higher position. (it's like raising the complete rear)
kev d
« Reply #762 on: May 01, 2016, 10:24:31 am »
What was the problem you had, incorrect geometry or clearance?
Always a pain re-doing things but if it makes a better car at the end of it it's well worth it! Grin
fahrvergnugen
« Reply #763 on: May 01, 2016, 11:32:50 am »
Had some geometry problems, especially camber. It's a PITA doing it twice but i will do it over and over until i am satisfied.
fahrvergnugen
« Reply #764 on: May 04, 2016, 19:47:17 pm »
Testing, getting there.
fahrvergnugen
« Reply #765 on: May 07, 2016, 19:21:04 pm »
Zero camber @ the lowest position. now i have to check the camber when it's a bit higher.
fahrvergnugen
« Reply #766 on: July 06, 2016, 17:18:39 pm »
Rearsuspension version 3.0 is almost ready, only need to receive the new toe in / toe out adjuster plates and mount them. also relocated the gearbox and made new mountings.
fahrvergnugen
« Reply #767 on: November 15, 2016, 22:27:05 pm »
Done some small things, but has to be done.
*Made a stronger adjustable bracket for the rear suspension and bought 10,9 bolts and nuts to mount them.
*Changed the Porsche 914 hubs from 4 to 6 bolts.
*Made a bracket for the new throttle cable.
*Made a throttle cable mount to the throttle pedal.
*Pressure test the rear brakes (fail :-( )
fahrvergnugen
« Reply #768 on: November 27, 2016, 13:20:19 pm »
Made 2 driveshafts out of 4 VW Golf shafts.
Yesterday I mounted the T1 and T2 CV's and fitted them on the car.
Paul.
fahrvergnugen
« Reply #769 on: December 04, 2016, 19:04:58 pm »
The chassis is ready (so far) so the body is on again.
« Reply #770 on: December 04, 2016, 19:25:07 pm »
Nice progress Cool
On the chassis shots it looks like the rear coil over just has one tab supporting it on top?  If so I would consider adding a second on other end of mounting bolt, I think just one will fatigue and maybe fail Shocked
fahrvergnugen
« Reply #771 on: December 04, 2016, 20:13:30 pm »
Nice progress Cool
Hi Richie,
Thanks. I am using two bolts, i think this will do.
« Reply #772 on: December 04, 2016, 20:18:13 pm »
Its this bracket I circled that I was referring to, looking at that side on picture its probably ok, you have just done it in a different way to how it looked  Smiley
« Last Edit: December 04, 2016, 20:20:02 pm by richie » Logged
fahrvergnugen
« Reply #773 on: December 04, 2016, 21:55:04 pm »
Ok, in the circled pucture is does looks different. But it is like the earlier picture. Thanks for thunking with me👍🏼
fahrvergnugen
« Reply #774 on: December 24, 2016, 16:15:23 pm »
The front is nearly ready.
fitting the Porsche suspension
And it's on 4 wheels again.
fahrvergnugen
« Reply #775 on: December 28, 2016, 21:56:50 pm »
Master brakecylinders and clutch cylinder are overhauled and mounted with the TILTON pedalbox.
The Steering column is mounted and connected to the R&P and it works like a dream..
Stevo_L
« Reply #776 on: December 28, 2016, 22:17:18 pm »
awesome work man! keep on going  Grin
fahrvergnugen
« Reply #777 on: December 31, 2016, 19:11:10 pm »
 "tight fit"
fahrvergnugen
« Reply #778 on: April 20, 2017, 21:21:19 pm »
It's bin a while but I'm still on it.
After setting the stance I found out that the front shocks where too short. the new shocks are gas filled and a bit longer.
I want the camber on the frontwheels somewhere between 0 and -1deg. but the adjustment did not go further as -2deg. now I will modify the Porsche A-arms. I will narrow them a bit and replace the original balljoint with an adjustable uniball.
fahrvergnugen
« Reply #779 on: November 27, 2017, 22:47:16 pm »
New a-arms
now the wheels are centered.
Fits like a glove
