brewsy
« Reply #780 on: November 28, 2017, 12:14:28 pm » |
WOW. Another awesome build!!
Great work
fahrvergnugen
« Reply #781 on: November 28, 2017, 21:26:53 pm » |
Great work
fahrvergnugen
« Reply #782 on: November 10, 2019, 17:58:21 pm » |
slow progress.  home again  new spare wheel.  made new a-arms with camber adjustment.  New (test) tyres  The test tyres fir perfectly.
Phil13
« Reply #783 on: November 11, 2019, 07:09:42 am » |
 The test tyres fir perfectly. [/quote] what fenders are those ? GFK ?
« Reply #784 on: November 11, 2019, 08:28:17 am » |
Slow progress is still progress! Good to see an update again!
Stevo_L
« Reply #785 on: November 11, 2019, 21:04:05 pm » |
+1 gonna be an awesome car
fahrvergnugen
« Reply #786 on: November 11, 2019, 21:24:11 pm » |
Thanx
« Last Edit: November 11, 2019, 21:26:16 pm by fahrvergnugen »
fahrvergnugen
« Reply #787 on: November 11, 2019, 21:26:48 pm » |
 The test tyres fir perfectly. what fenders are those ? GFK ? [/quote] Race weight day molding
fahrvergnugen
« Reply #788 on: November 07, 2020, 19:51:37 pm » |
Due to small other projects, the bug was waiting in the corner. now it is time to start again/ Restored and sold a Vespa  Fixed and sold a Honda  Fixed and sold a 944
fahrvergnugen
« Reply #789 on: November 07, 2020, 19:57:52 pm » |
fahrvergnugen
« Reply #790 on: November 12, 2020, 15:23:58 pm » |
spoolin70
« Reply #791 on: November 12, 2020, 18:33:10 pm » |
Link broken message
fahrvergnugen
« Reply #792 on: November 12, 2020, 19:40:41 pm » |
spoolin70
« Reply #793 on: November 13, 2020, 06:19:01 am » |
That's better Thankyou
fahrvergnugen
« Reply #794 on: July 31, 2024, 14:06:34 pm » |
It's bin a long time since I was here. I am still making progress.
Fuel tank is narrowed, has an fuel sender and the filler cap is replaced to the middle of the hood.
fahrvergnugen
« Reply #795 on: July 31, 2024, 14:07:33 pm » |
Filler cap
fahrvergnugen
« Reply #796 on: July 31, 2024, 14:08:48 pm » |
engine is a typeVI and is seriously raised. so I had to make costum angine tin.
fahrvergnugen
« Reply #797 on: July 31, 2024, 14:09:28 pm » |
The fuelpumps and filter
fahrvergnugen
« Reply #798 on: July 31, 2024, 14:10:13 pm » |
Some hardlines I made
« Reply #799 on: July 31, 2024, 20:36:01 pm » |
Good to see its still progressing and you back with updates cheers Richie
Cars are supposed to be driven, not just talked about!!! Good parts might be expensive but good advice is priceless
fahrvergnugen
« Reply #800 on: August 01, 2024, 12:52:13 pm » |
Good to see its still progressing and you back with updates cheers Richie Hi Richie, still working on it, just not posting here for a long time ;-) Proost Paul.
fahrvergnugen
« Reply #801 on: August 03, 2024, 21:14:51 pm » |
Getting closer with the fueltank
fahrvergnugen
« Reply #802 on: August 03, 2024, 21:15:55 pm » |
Test fit
fahrvergnugen
« Reply #803 on: August 03, 2024, 21:17:02 pm » |
Fuel cap
fahrvergnugen
« Reply #804 on: September 08, 2024, 11:16:43 am » |
Fillercap ready
fahrvergnugen
« Reply #805 on: September 08, 2024, 11:19:23 am » |
fahrvergnugen
« Reply #806 on: January 04, 2026, 12:20:06 pm » |
OK, just to let you know I am still at it  I am almost ready to open up the type4, this engine was a good runner but is laying around for 15 yrs. I want to open it, clean it and replace Watt needs to be replaced. the car is build for a Nitrous system with 2 fuel systems and all the safety's and switches. I was thinking of a 30 to 50 shot of nitrous, can someone tel me if I need to change something in the engine? bigger pistonring gaps? lower compression ratio? etc.... Here's a pic of the brakecooling I am working on. Thanks, Paul. https://www.facebook.com/Vwrankenstein-Ovaal-109015887687050/
« Last Edit: January 05, 2026, 10:09:28 am by fahrvergnugen »
« Reply #807 on: January 06, 2026, 08:56:28 am » |
Good to see its still progressing  To give some advice on nitrous use the complete engine spec would be needed? cheers Richie
fahrvergnugen
« Reply #808 on: January 06, 2026, 20:59:02 pm » |
Good to see its still progressing  To give some advice on nitrous use the complete engine spec would be needed? cheers Richie Hi Richie, Thanks for your reply. I do not have All the spec's yet. I Will have to open Up the engine to check it. It is a type4 94x71 but I have the Parts to upgrade to a 104x71. Haven't decided which cam yet.
fahrvergnugen
« Reply #809 on: March 16, 2026, 13:48:17 pm » |
Okay, I openend the engine, good I did because one of the exhaust valves did not shut and one of the cylinders had a bad spot. I think it had a some water while it was stored. The valves are 41mm inlet and 33mm exhaust. I want some power in the low rpm's so was thinking of keeping these valves.
any cam suggestions?
Paul.
