October 12, 2026, 07:52:27 am
My >street/<strip '56
27
28
Topic: My >street/<strip '56 (Read 921737 times)
fahrvergnugen
Re: My >street/<strip '56
Reply #810 on:
March 25, 2026, 21:08:09 pm »
Upgrade in proces
http://fast-air.skynetblogs.be/
fahrvergnugen
Reply #811 on:
March 29, 2026, 18:53:27 pm »
Good thing I opened the case,, the bearings don’t look that good.
fahrvergnugen
Reply #812 on:
April 14, 2026, 19:43:23 pm »
Just my luck 🤬
While checking the heads of my engine, I discovered that One of the heads has smaller push rod tube openings.
It seems that the tubes I need are not sold new and are rare to find 😞
fahrvergnugen
Reply #813 on:
April 18, 2026, 18:32:08 pm »
Problem solved
fahrvergnugen
Reply #814 on:
April 18, 2026, 18:34:12 pm »
Cleaning, cleaning amd cleaning.i
fahrvergnugen
Reply #815 on:
May 29, 2026, 14:20:01 pm »
Quote from: fahrvergnugen on January 06, 2026, 20:59:02 pm
Quote from: richie on January 06, 2026, 08:56:28 am
Good to see its still progressing
To give some advice on nitrous use the complete engine spec would be needed?
Hi Richie,
This will be a 71*104 engine (2,4ltr)
Original length H-beam rods.
41mm inlet and 33mm exhaust valve.
Schleicher 324 cam.
10:1 compression (i think)
do I need to change the CR or something else to use a small shot of NOS?
Last Edit: June 02, 2026, 21:22:45 pm by fahrvergnugen
Reply #816 on:
May 29, 2026, 17:42:36 pm »
What compression does it have now? use 99octane fuel?
fahrvergnugen
Reply #817 on:
June 01, 2026, 13:25:40 pm »
Hi Richie,
I am building this engine therefor I can do all the needed mods. the Schleicher 324 cam runs good with 10:1 compression, so I taught this is good but for NOS maybe it needs a bit lower.
I Will be driving this on the street on pumpgas 95 or 98 octane. and occasionally will use a small shot of NOS.
Thanks.
Last Edit: June 01, 2026, 13:29:24 pm by fahrvergnugen
Reply #818 on:
June 01, 2026, 19:16:45 pm »
Should be no problem with that compression still if you stay under 50hp of nitrous with small retard on ignition
fahrvergnugen
Reply #819 on:
June 02, 2026, 20:08:02 pm »
Thanks, retard is there when needed👊
Last Edit: June 03, 2026, 15:57:50 pm by fahrvergnugen
Reply #820 on:
June 03, 2026, 07:42:41 am »
27
28
