September 22, 2026, 04:34:40 am
| | |-+  Can we identify these heads?????
Pages: 1 [2] 3 Print
Author Topic: Can we identify these heads?????  (Read 59659 times)
« Reply #30 on: November 13, 2008, 14:49:00 pm »
they could be old FEBI german heads. BTW not all headports stamp there stuff that could be the old owners first/last. UD.
Very good point - I just thought it was worth asking as these are the ONLY marks/stamps on these heads  Smiley
Monkiboy - get them flow tested. If you do not have a place over there you can pack them and send them to me and I will bring them to JPM for you to get them tested and send them back.... no wait... that depends on the flow results.... Nah.. I will of course return the heads safely.
BRBB
I am also not too bothered about getting the flow figures as Matt Keene seems more than happy with them and he seems to know his stuff ( Wink)
I may get it done just out of interest - Kalle I will drop you a pm later tonight  Smiley
« Last Edit: November 13, 2008, 15:02:05 pm by monkiboy » Logged
roland
lates are the new splits...
« Reply #31 on: November 13, 2008, 16:52:11 pm »
There is also a French shop that do the job not far from Paris.
it would maybe be cheaper to send them there than to Norway?
I guess there are a couple of flowbenches closer than norway or france, those UK guys are pretty in love with cars in general so it shouldn't be too hard to find if Lee wants to...
Fasterbrit
« Reply #32 on: November 13, 2008, 19:53:08 pm »
Does John Maher have a flow bench? Failing that, let someone like Lee Maynard have a look at them - I know he knows a hell of a lot about heads! Wink
Yes, I  believe John Maher does now have a flow bench. Maybe it's worth giving him a ring and getting him to do a test. Would be nice to find out some figures - especially port velocity. Smallish ports with very good velocity (the speed at which the air/fuel flows through the port) can work just as well as big ports with low velocity - particularly on something that is mostly street driven.
There is much more to a head other than the size of its port. Multi-angle valve seats, back-cut valves and good combustion chamber design help make a head work. Ultimately, is all about balancing the all the factors with one another. A huge port with shrouded valves and a poor valve job is not going to work anywhere near as well as a well ported and sorted head even if it appears mild...
There is a huge difference between port flow and port velocity. People tend to get carried away with huge ports and fantastic flow figures. You can have all the flow you like, but if the velocity is low you will have a motor that is very highly strung and wont make much power below a certain rpm. True, it may well make good HP when it finally comes on cam, but every day driving will be far from ideal.
The objective is to fill the combustion chamber with as much air/fuel as possible on every cycle even when the rpm is low. The engine has only X time to fill the chamber. If air flow is rushing into the chamber at a greater speed due to good port velocity, it fills the chamber more quickly, therefore bigger bang. Bigger bang = greater torque. Jackpot Cool.
Lee's idea with this engine is sticking close to the roots of VW racing. Back in the day a 40 mm inlet valve was a BIG valve and the likes of Comp Eleminators with 48x40 valves were a long way off in the future. Maybe we have gotten carried away and spoilt for choice these days, but the legends back in the day used to run 12s no problem with comparatively conservative motors. Yes, some of them even ran SPG cranks for their sins. The object of this exercise is to make about 150 horsepower, which should be easily attained with 2180 cc, the right cam, 48 IDAs and these heads. Oh, and a good engine build...
Long live round ports and roller bearing cranks Grin
www.air-kraft.com
www.marcomansiperformance.com
« Reply #33 on: November 13, 2008, 20:42:57 pm »
"Maybe we have gotten carried away and spoilt for choice these days, but the legends back in the day used to run 12s no problem with comparatively conservative motors. Yes, some of them even ran SPG cranks for their sins. The object of this exercise is to make about 150 horsepower, which should be easily attained with 2180 cc, the right cam, 48 IDAs and these heads. Oh, and a good engine build..."
THANKYOU Matt Wink there are ALOT of very good points in your post but I think the ouote above about sums it up  Smiley
This is project is really NOT about "all out power" its about building an engine I've always wanted to build and RUN,
I also want it to be as "period correct" as possible ( I hate that term though!) oh yeah there is also that COOOOOOOOL Factor Wink Grin
ugly duckling
« Reply #34 on: November 14, 2008, 03:22:14 am »
should be a nice set for a 70s period small CI engine. UD.
« Reply #35 on: November 14, 2008, 23:36:11 pm »
Thanks Jeff that boosts my confidence a little Wink Smiley
John Maher
« Reply #36 on: November 15, 2008, 02:34:42 am »
Matt and Neil are correct - the JMR flow bench....
Ideally you make cam choice AFTER you know the flow and velocity data
... bit like choosing gear ratios once you know the engine's power and torque curves
It may turn out the heads you have are not the best choice for good low and mid-range performance
Can't mask a head deficiency with cam, rockers, carbs etc
Matt's right.... huge ports can flow plenty of air but the cfm number should be judged on cfm per square inch of flow area i.e. EFFICIENCY of the port
Big ports and impressive cfm numbers may work well on a high rpm drag race motor but when fitted to an engine intended for street use could be a pain to live with on a daily basis
Personally I'd never handicap my choice of cam (or any other component) based on Cal-Look fashion-police styling points... takes all sorts    Cheesy
In the old days major surgical procedures were performed without the aid of anaesthetic... Wink
With regard to extracting good performance from conservative ports and valve sizes see attached graph
2110cc designed for a bus
...strong low and mid-range torque took top priority
Just finished testing yesterday and with a slight change in jetting peak figures are now slightly higher than those in the graph... 153bhp @ 6000rpm and 160ftlb @ 4500rpm
Fairly conservative stuff....
Engle 120, 1.25 rockers, 40mm x 35.5mm valves (JMR modified heads), 40IDFs.
The key ingredient is the small, fast efficient port design.
I could achieve the same cfm numbers with a lot less work by fitting larger valved heads but port velocity would fall, engine would make less torque in the rpm range it'll spend most of its time and throttle response would be lazy.
One of the best examples of super efficient small port heads I've ever seen was on the JPM 1603cc engine featured elsewhere on this forum
Proof positive that bigger isn't always better
With flow data you have a good idea of maximum bhp potential
Once you know lift at which flow increase tails off, you have a target peak lift figure to aim for.
If you have a duration figure in mind this probably helps narrow cam choice down to 2 or 3 candidates
With the bus example shown in the graph, budget didn't stretch to a set of 1.4 rockers.
Based on flow data I knew I wanted close to .500" total lift but didn't want to run excessive duration to achieve it
The E120 w/1.25 rockers delivers an average .470" actual at the valve
That takes pretty good advantage of the flow characteristics of the heads (172cfm @ .500" - tested at 28" H2O)
.... more than some of the 'custom ported' 44mm valved heads I've tested
« Last Edit: January 08, 2013, 22:59:59 pm by John Maher » Logged
John Maher
Fasterbrit
« Reply #37 on: November 15, 2008, 10:51:05 am »
Excellent info from John as per usual Cool. The flow bench takes all of the 'guess' work out of the equation. All the 'voodo' about 'must have' giant ports can easily be disproven by hard facts and experience. Looking at that power graph the power looks really smooth and revs surprisingly well!
www.air-kraft.com
LGK
« Reply #38 on: November 15, 2008, 10:55:05 am »
Hi John,
Are those dyno-numbers corrected BHP and were these tests with fanbelt(without i guess)  and muffler ( with i guess?)
Anyway it's nice combo and your customer will be very pleased with his engine.
Regards Steve
Fasterbrit
« Reply #39 on: November 15, 2008, 10:58:04 am »
[/quote]
This is a great statement Cool and one which I believe Lee is adhering to!
What cam would you recommend, John? Bear in mind Lee wants to see some revs to make the most of the roller bearings Cool
Spec:
SPG 82mm
92mm
Old school heads with 42x35.5
48 IDAs
www.air-kraft.com
John Maher
« Reply #40 on: November 15, 2008, 14:15:06 pm »
Hi John,
Regards Steve
Correct on all three counts... no belt, corrected as per SAE, muffler fitted
Correction factor for that particular test was an average of 1.0126
My baseline dyno tests are always carried out minus fanbelt, otherwise it becomes impossible to detect small differences in torque and power between similar specification engines
eg. two identical spec engines might run different cooling systems (VW vs Porsche), bigger or smaller diameter crank pulley, 55amp or 75 amp alternator etc
Although the basic engine specifications are identical, dyno figures could be significantly different depending on the cooling/charging combination
Could account for at least 10bhp variation
Difficult to evaluate changes if you're not comparing apples with apples
This is why it's also important to correctly apply a correction factor based on accurately measured intake air supply temp, air density etc
Note, those same heads with different cam and carburetion could make much more power but it'd all happen higher up the rpm range.
Also, gap between peak torque and peak power would narrow.
Fine for a Beetle maybe but exactly the wrong way to go for a heavyweight bus running a stock ratio Type 1 trans (as in this case)
Tailor the spec to suit the application
If engines are leaving here complete with tin, cooling etc, I also carry out tests in full street trim
Very useful to see the effect different cooling systems, pulleys, alternators etc have on power output
Spec:
SPG 82mm
92mm
48 IDAs
I've probably got an original Barney Rubble Terrosaur Caveman cam lying around here somewhere...
... based on a stock 25hp cam and reprofiled with an angle grinder by someone with a beard and flip-flops from California in the mid '60s
if anyone's interested, also got a set of super rare prototype BRM wheels that never made it into full production....
probably something to do with them being square
Cool as f**k though  Wink
OK...serious now....
re cam choice...
like I said before, a flow test will give you some good pointers
Without the data you must rely on educated (or maybe uneducated?) guesswork
At this stage I hold my hands up - I haven't a scooby
Should also mention it's wise to flow the complete induction system to get the full picture
Little point in reworking a head to flow 200cfm if the manifold reduces it by 25%, then finding the carb (and vel stack/filter) chokes off another 30cfm
The cylinder can only receive what's allowed in by the entire intake system
« Last Edit: November 15, 2008, 14:22:09 pm by John Maher » Logged
John Maher
« Reply #41 on: November 15, 2008, 15:02:30 pm »
Thanks for your input John  Cool It looks like I might be sending you up a pair of heads then  Undecided Smiley
« Reply #42 on: November 15, 2008, 18:49:07 pm »
What?? can't you tell how good the heads are by looking at pics of them??   Roll Eyes
I wouldn't trust this guy Monkey Undecided Smiley Wink Cheesy Grin
« Reply #43 on: November 15, 2008, 20:45:10 pm »
very good info there. thanks for sharing and being so open about what you do.
« Reply #44 on: November 15, 2008, 21:28:41 pm »
Yes, It's very interesting for "young" people.  Wink
Thanks John.
« Reply #45 on: November 15, 2008, 22:01:21 pm »
Thanks John.
Yeah us "Pups" need a little guidence from the Masters  Wink Smiley
Fasterbrit
« Reply #46 on: November 15, 2008, 22:06:38 pm »
That's the funniest quote I've seen on this forum for ages Grin.
Is the terrosaur cam painted purple by any chance? Grin
www.air-kraft.com
Martin Greaves
10.88@128.58
« Reply #47 on: November 15, 2008, 22:47:38 pm »
Lee if you are after some period heads why not try and get this type.Tongue Grin
« Reply #48 on: November 15, 2008, 23:55:34 pm »
Now those are COOOOOOOOOOOOL - any idea what they are - purely out of interest  Wink Smiley
Rick Sadler
« Reply #49 on: November 16, 2008, 08:07:16 am »
Arao Engineering Heads
Fasterbrit
« Reply #50 on: November 16, 2008, 19:17:29 pm »
Wow! Look at the size of the inlet valves Shocked
www.air-kraft.com
« Reply #51 on: November 16, 2008, 20:14:01 pm »
Hmmm a roller crank and a pair of those - Sounds interesting  Wink Smiley
« Reply #52 on: February 25, 2013, 21:55:33 pm »
Just thought I'd drag this thread back - I just sent these heads to Ian Clark to have them built up - Here's what he sent me when he'd checked them out:
Hi Lee.
Heads turned up today all safe. These are a better casting than the epco but still not really sure who made them but it doesn't really matter I suppose. It's who worked on them that is interesting as they're nicely done, not too crazy but I'm sure they'll flow some great numbers. I had some stock heads reworked by Fumio once (they're on Phil West's brothers car,1776) small round ports but very similar to these. That's how they used to do it back then as they had limits on piston size and valves so there was no need to hog it all out. He's tapered the valve seat/blended it into the port taper which is definately a nice touch and very time consuming/tricky to do, especially back then. But....these have been cut for high compression. I cc'd them and they hold 41cc which with your 82 x 92 combination and a deck height of .040' ( 1mm ) they give a compression ratio of 12.4:1. If I increase the deck to .060' ( 1.5mm ) the max. I will go to, it still gives 11.7:1. This is the upper limit for a street engine on V-Power 98oct pump gas
I will post some flow figures when he's done  Smiley
dirk zeyen
« Reply #53 on: February 26, 2013, 10:11:14 am »
..... A SPG don't like that much compression Angry
back again!!!
spanners
« Reply #54 on: February 26, 2013, 15:49:01 pm »
they may well be for a Circle track G.P Midget engine, they ran alky.
best regards Johnny.
Best regards, spanners.
« Reply #55 on: February 26, 2013, 17:30:20 pm »
Ok..... Ian later goes on to say that "Lil wooper" runs 11.8 on his SPG motor, And my friend "Robthemanx" runs 11.8 on his SPG motor, I have spoken with Gary (the guy who rebuilt/modified my crank) and he is more than happy with them runnning over 12:1 and has personally used his Pinned/welded/modified SPG's on Turbo motors well over 350bhp
The main problem is the Fuel - This isn't going to be a "Daily Driver" I just want to be able to drive it to a track run a 13 and drive home....
I/Ian could "Semi Hemi" the cambers for an extra 13cc which would bring it down to 10.5.... I'll be talking with Ian soon to finalize the details Smiley
spanners
« Reply #56 on: February 26, 2013, 19:08:08 pm »
your gonna rip those chambers out? all that history swept into a waste bin,  Cry
« Reply #57 on: February 27, 2013, 00:15:49 am »
I agree, don't do it man.
Just cam it up, or mix 10-20% methanol into it, or both.
Bugger it man, just use straight methanol. A 40L tankful will get you nearly 300km on the street if you're careful enough, and another drum behind the seat to run a few laps down the strip.
When you're idling at the lights, try to sit just in front of the nearest convertible.......... Grin
« Reply #58 on: February 28, 2013, 22:03:02 pm »
Russ' shop is walking distance from my office. cool guy.
« Reply #59 on: March 01, 2013, 12:19:49 pm »
Thanks John.
+1 Thanks guys  Smiley
makes me wonder if i've taken too much out on my head now!
