October 12, 2026, 21:34:46 pm
| | |-+  Too much detail?
Pages: 1 [2] Print
Author Topic: Too much detail?  (Read 43754 times)
Frank LUX
Back...Soon...hopefully!!!
« Reply #30 on: January 05, 2007, 18:52:36 pm »
Frank i havn't copied your Oberg I have a Oberg Heavy Duty 600, and its HUGE!
by the way does anybody have a wiring diagram for the sender on this unit, and what type of sender is it?
No Problem Lids....
The wiring is quite simple and the sender is the same than the reverse Gear Sender from a VW Tranny...
Frank
« Reply #31 on: January 06, 2007, 21:32:11 pm »
One more of Daniels car.
SlingShot
« Reply #32 on: February 18, 2007, 01:29:49 am »
This is the latest addition.
Will Race For Beer !!!
« Reply #33 on: February 18, 2007, 13:23:42 pm »
pretty neat!!
are those treuhaft 010s any good? do they differ much from a normal 010?
Tobi/DFL
« Reply #34 on: February 19, 2007, 09:57:43 am »
Hi Slingshot,
is that a Mallory unilite module in that Treuhaft dissy? It´s the same conversion I´m planning to do and I´ve already received the module for my Treuhaft 010, but I wonder how to modify the ignition rotor as the Mallory unit is way larger than the Treuhaft unit. Do you simply shorten the brass part of it...? Huh
Many thanks in advance!
Tobi
jick
« Reply #35 on: February 19, 2007, 11:27:55 am »
Frank
hey Frank...i copied yours! Cheesy
it looks fucking great.
« Reply #36 on: February 20, 2007, 03:13:42 am »
It is a Mallory conversion, and it works great. Motor sounds bitchin Wink
Tobi/DFL
« Reply #37 on: February 20, 2007, 09:41:57 am »
Hi Zach,
do you have a pic of the rotor?
Thanks!
Tobi
« Reply #38 on: February 20, 2007, 10:12:33 am »
Can somebody please post the product codes to do this conversion, I have an old treuhaft 010 at home, it would be nice to bring it upto date.
SlingShot
« Reply #39 on: February 21, 2007, 03:29:06 am »
This is a description that is found in one of my old catologs.
 "The Treuhaft 010 distributor was developed as a direct replacement for the Bosch 010, which became unavailable. The performance characteristics of the Treuhaft 010 are equivalent to the Bosch with the exception of the camshaft dwell angle, which was improved to extend the life of the coil.
This improvement also reduces point float for greater and more consistent accuracy. Proven in offroad, roadrace, and dragrace competition."
The conversion I used is a Mallory E-spark conversion part # 61009M the conversion kit cost about 65.00 US$ thru www.summitracing.com. Also check out www.malloryperformance.com for more info on the kit. There is also a unilite conversion sold by mallory, which hits the pocket 4 times higher in cost than the E-spark.
The kit is fairly straight forward to install, the hardest part is, pulling off the point cam off of the dist shaft to make room for the new style rotor.
Here is a pic of the rotor.
Tobi/DFL
« Reply #40 on: February 21, 2007, 09:59:27 am »
Thanks a lot for that very valuable information, Slingshot! Smiley
« Reply #41 on: February 21, 2007, 11:55:28 am »
What coil and control unit are you using with this?
« Reply #42 on: February 21, 2007, 18:39:19 pm »
slingshot, what is the direct gain of this conversion?
would the treuhaft also run well without?
« Reply #43 on: February 22, 2007, 03:49:27 am »
The coil is a standard Bosch Blue. The advantages to the E-Spark is you lose the points and condensor and you get a hotter spark. Not to mention new points and condensors are apparently getting very hard to find Sad
Mags
2,2L 577Hk.
« Reply #44 on: February 23, 2007, 08:43:01 am »
My Frontbeam too my 62 gasser.
christophe
« Reply #45 on: February 23, 2007, 10:43:57 am »
 Shocked Shocked Shocked
want to see more,want to see more......
Rasser
« Reply #46 on: March 16, 2007, 01:08:40 am »
I think this one belongs here...
1955 type1
1966 type2 13w deluxe
« Reply #47 on: March 16, 2007, 06:53:22 am »
Time well spent Grin
71CALRIPPER
« Reply #48 on: March 16, 2007, 08:28:24 am »
its all in the little details, makes you stand out from the rest.
Top work   Grin
« Reply #49 on: October 01, 2007, 19:48:54 pm »
Who says a type 2 cant be cal look?
« Reply #50 on: October 01, 2007, 19:55:11 pm »
Top work   Grin
Couldn't agree more dude  Wink Smiley
Pages: 1 [2] Print
