October 13, 2026, 10:22:10 am
| | |-+  Battery kill switches
Author Topic: Battery kill switches  (Read 11656 times)
SteveW
« on: November 13, 2008, 20:42:52 pm »
Just looking for ideas as to where I can mount the battery kill switch on our car, anyone got any ideas?!!
Steve
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
benssp
www.callookvw.com
« Reply #1 on: November 13, 2008, 20:52:22 pm »
bottom of the right hand rear 1/4 panel, what do the regs state? does it have to be externally mounted?
www.vwheritage.com  My Job
YMCA
Jonny Grigg
« Reply #2 on: November 13, 2008, 20:55:58 pm »
Steve,
you should check the drag racing year book. This is only mandatory if you relocate the battery. If installed it is stated to be "installed on the rear-most part of each vehicle and easily accessible from outside the car body". All a bit tricky on a rear engined VW, especially if you have a removable rear valance and/or rear wings. Also it is probably where the fire would be, if there is one..........
I would hope the scrutineers take a common sense apporach with this one. I have never had one on the car before, but have now engineered mine to be operable from a pull handle where the screen washer used to be. It is connected via a cable to the switch inside the car next to the seat- the idea being that I would kill the power- unless I couldn't for some reason, but I don't really want to go there.......
It would be interesting to get other people's views and experiences of the UK scrutineers' opinions in the recent past.
Jonny.
No Compromise. O/FF111
SteveW
« Reply #3 on: November 13, 2008, 20:58:04 pm »
Not externally mounted, no but the switch handle needs to be external. I had thought about mounting it in the 1/4 panel! Any other ideas?! Isn't Bernies mounted near his running board?
The battery will be in the stock location but to be honest it's another safety feature which is never a bad thing!!
Steve
1970 Stock Beetle.
benssp
www.callookvw.com
« Reply #4 on: November 13, 2008, 21:04:15 pm »
yep, bernies is on the running board Grin
YMCA
58vw
« Reply #5 on: November 13, 2008, 21:54:29 pm »
most tracks if you are racin the car it needs to be at the rear of the car were it can be clearly seen and reached in the event of a mishap...mine is in the fender above the taillight
www.4inbore.com
Angleflows...order them now
« Reply #6 on: November 13, 2008, 22:51:33 pm »
An external MUST be mounted at the rear . Internal i would mount on the dashboard or at the tunnel next to the parking break . But it must be a steel switch .
58vw
« Reply #7 on: November 14, 2008, 03:15:17 am »
also when your done hooking it up make sure it works.....ive seen tech guys go up and hit the switch and it does not kill the car....then your left not racing..... Angry Grin
www.4inbore.com
Ohio Tom (DdK)
« Reply #8 on: November 14, 2008, 04:02:50 am »
I got mine mounted in the right rear 1/4 panel. Even NHRA tech gives it the "pass".
The only thing they gave me a "fix it" on was not having a sealed battery box. Even thou it's stock location, they still made me put it in a box.
Every track is differnt in how they interpret the rules.
Ohio Tom
08'.. 3 R/U...3 Win...
Jim Smith
« Reply #9 on: November 14, 2008, 10:03:05 am »
I have had a number of talks with Geoff and Mark {tech com} about this subject as in my opinion having the switch mounted at the rear most point on a rear engined vw is daft. I still have mine mounted in the centre of the skuttle panel, never have any probs with passing tech. Both Mark and Geoff agreed this was a much more sensible location for a vw, they did tell me that they would at some point be adding this into the year book, but  nothing in there yet.
   Best off giving Mark Norton a bell and see what he has to say.
Hope this is of some help?
Jim.
www.cotsweld.co.uk      Race car fab   01242 232084
SteveW
« Reply #10 on: November 14, 2008, 10:44:56 am »
In the states their rule book also states that it needs to be at the rear most part of the car but yeah it doesn't make sense in a rear engined car!! In circuit racing here the rules state that on all cars it needs to be on the scuttle panel like yours Jim.
The plan we have gone for is the bottom rear of the 1/4 panel next to where the battery will be fitted. We have a nice and small billet handle so it's not 'in your face' and we'll have 'off - on' sign written above it. Its being mounted on the passenger side as I'm fitting the battery there so all the weight is not on the drivers side.
Steve
1970 Stock Beetle.
« Reply #11 on: November 14, 2008, 12:26:20 pm »
I fitted mine in the scuttle, right in front of the drivers seat. I could reach it to turn it off on my way out of the door. The Ghia had one mounted in the engine bay, with a cable coming through the vents.
Bernard Newbury
9.50 @ 141 MPH
« Reply #12 on: November 14, 2008, 22:32:35 pm »
Jonny.
Believe me Jonny the kill switch is the last thing you think about when making a hasty exit Wink. Mine is mounted in the running board by the rear right 1/4  and the only comment I have had from the scrutrineer was the lack of the triangle label. I think the rule book is worded mainly for front engined cars with the switch being as far away from the engine as possible , so in theory ours should be at the front end of the car. Bernie
dave.d
10.39 @ 129mph n/a 1.37 60ft pan car
« Reply #13 on: November 15, 2008, 03:27:57 am »
i have mine in the same place as jim  always passed Smiley
dth
« Reply #14 on: November 15, 2008, 23:48:48 pm »
Mounted mine in the rear side window (lexan) ,saves drilling the body ,if you wanted to try sticking to the rules you could put it on the rear window ,never had any problems at scritineering Smiley
