May 20, 2026, 17:54:07 pm
Latest Member: mvptkfjb
| | |-+  Blocking off the nitrous jets
Author Topic: Blocking off the nitrous jets  (Read 10010 times)
AntLockyer
« on: December 02, 2008, 12:09:30 pm »
Bit of an odd question. My manifolds are drilled for nitrous jets but I'm not going to run nitrous straight away becase it scares the hell out of me and I want to get the car going straight first.
Would I be better off fitting the nitrous gear and jsut not filling the bottle or would it be better to block the holes in the manifold with some sort of blanking plug? I want to avoid any leaks in the induction.
12.618 @ 104.87mph
« Reply #1 on: December 02, 2008, 12:20:40 pm »
Hi,
You plug the holes with this;
http://store.summitracing.com/partdetail.asp?autofilter=1&part=NOS%2D17210NOS&N=700+115&autoview=sku
AntLockyer
« Reply #2 on: December 02, 2008, 12:21:36 pm »
Perfect thanks.
12.618 @ 104.87mph
« Reply #3 on: December 03, 2008, 06:34:37 am »
NOS fogger nozzles use a 1/16 NPT thread. I would suggest a steel or brass plug over the above picture Al. plug. They strip faster than Paris Hilton.
Paul Bate
« Reply #4 on: December 03, 2008, 09:11:28 am »
Hello Ant,
If you struggle to get steel or brass blankers you could always put a bit iof PTFE tap on the ally blankers.
All the best Paul
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
AntLockyer
« Reply #5 on: December 03, 2008, 10:20:49 am »
1/16 NTP cool thanks.
Paul good thinking. I'm hoping that they will go in, stay there for a few runs and then I'll bolt the nitrous in when I stop being a girl about it.
12.618 @ 104.87mph
Paul Bate
« Reply #6 on: December 06, 2008, 19:46:31 pm »
Hello Ant,
I wouldn't say you were being a girl about it just sensible or cautious which in the case of nitrous is a very good way to go about it.
Good luck Paul  Smiley
10.79 Nitrous
AntLockyer
« Reply #7 on: December 06, 2008, 20:42:49 pm »
The car ran 13s with the 1914 in it. This is 2443 so I'm interested to see what it does NA. The trouble with me is if the gas is there I will be too eager to get in switched on.
12.618 @ 104.87mph
Paul Bate
« Reply #8 on: December 06, 2008, 21:40:36 pm »
Hello Ant,
I tried to get the most I could out of the car first so that I could get a handle on how much the gas was actually worth. I would also say that if you get as much out of the car before you put the gas on ie, overall set up then when you put on the gas you are actually allready further down the road if you know what I mean.
The slower you develop the more you will pick up on the way, but being patient in a drag race is kinda hard LOL !!!
Cheers Paul
10.79 Nitrous
AntLockyer
« Reply #9 on: December 06, 2008, 22:09:48 pm »
Paul, I know exactly what you mean. Trouble is the motor is built for gas as is the gearbox so I think there is going to be a big gap in performance. If I could get a 12 without the nitrous I'd be pleased.
12.618 @ 104.87mph
Paul Bate
« Reply #10 on: December 07, 2008, 18:43:32 pm »
Hello Ant,
It might just be worth plumbing the whole lot in anyway? If it's all fitted ok then you shouldn't have any air leaks.
good Luck Paul
« Last Edit: December 07, 2008, 21:30:16 pm by Paul Bate » Logged
10.79 Nitrous
Bernard Newbury
9.50 @ 141 MPH
« Reply #11 on: December 07, 2008, 19:12:29 pm »
Hello Ant,
It might just be worth plumming the whole lot in anyway? If it's all fitted ok then you shouldn't have any air leaks.
good Luck Paul
Just because it's there Ant you don't have to use it. Bernie
AntLockyer
« Reply #12 on: December 08, 2008, 00:24:45 am »
That is a good point. I was thinking about saving some time so I could get the car out again but if I do that then I'll only have to tear it al down to fit the gas so I guess it will be quicker in the long run.
You are right Bernie but the temptation would be difficult to resist Smiley
12.618 @ 104.87mph
