January 13, 2026, 18:41:05 pm
67gtv220
Alum pannels
Topic: Alum pannels (Read 11353 times)
sven
Alum pannels
December 03, 2008, 20:11:08 pm »
Hi Everybody,
As the most of you know, I have to redo my alum panels.
I'm looking around witch kind of material I should use, Stian talked me about Aircraft alum, this should be much stronger than the standard alum plates.
If their is anybody with experience in this matter, please tell me.
Thx.
Sven
Last Edit: December 03, 2008, 20:13:50 pm by sven
Re: Alum pannels
December 03, 2008, 20:47:15 pm »
There is a guy in France that made alu panels for our VW's.
http://blackhands.skynetblogs.be/
(Edit: I' ve took the wrong links
There also is a member of the DAS that makes some nice panels. I can't remember his name but he has the Fastback with the Corvair engine.
Last Edit: December 05, 2008, 18:57:13 pm by j-f
Re: Alum pannels
December 03, 2008, 21:44:21 pm »
Quote from: j-f on December 03, 2008, 20:47:15 pm
(Edit: I took the wrong links
emerson
Re: Alum pannels
December 03, 2008, 21:45:23 pm »
Quote from: speedwell on December 03, 2008, 21:44:21 pm
emerson
That's it.
sven
Re: Alum pannels
December 04, 2008, 19:45:20 pm »
Is their anybody who has a telephone number from Emerson.
Re: Alum pannels
December 04, 2008, 19:54:45 pm »
Quote from: sven on December 04, 2008, 19:45:20 pm
pm sent
Tekken
www.proturbovw.com
Re: Alum pannels
December 04, 2008, 22:34:47 pm »
Sven-
Ric @ Bigwigracecars does some amazing work,he uses 6061-T4 in .032” for the interiors.5052 is probably the most common alloy,and works just fine.If you can get 3003, it’s really soft, and you can do just about anything in that alloy without much distortion.
-Stian
henk
Re: Alum pannels
December 04, 2008, 23:57:56 pm »
hallo sven,
i work on an airport and i see guys working with aircraft alu, they told me and showed me when you would like to bend it
you have to be more careful with it because it crack easier than normal alu.
henk!!!
pig1200
Re: Alum pannels
December 05, 2008, 18:17:52 pm »
the Aircraft alum is 7050 or 7075 but is not available in sheet, just in plate. We used 5754 for price an easy to obtain it!
Thx j-f for the link
a+
cedric
Re: Alum pannels
December 05, 2008, 18:58:41 pm »
Quote from: pig1200 on December 05, 2008, 18:17:52 pm
cedric
You made great job, I follow you blog each weeks and find a lot's of inspiration.
Re: Alum pannels
December 08, 2008, 22:26:29 pm »
a+
cedric
I can recommend cedrics work, I had some made, there was a small problem, this was no problem he made another set and dropped them off at eBI, never met him, as I was always too busy at the show.
Awesome work.
Re: Alum pannels
December 09, 2008, 15:29:15 pm »
Quote from: speedwell on December 04, 2008, 19:54:45 pm
pm sent
have you receive the mail
sven
Re: Alum pannels
December 09, 2008, 19:30:51 pm »
Yes I have, thx.
Fasterbrit
Re: Alum pannels
December 12, 2008, 11:39:59 am »
you could use S1C for non-structual panels as it bends really well, has fairly good rigidity and cuts nicely. If you are swaging panels, S1C is easy to bead-roll. It is readily available off the shelf. For structual panels NS3 is a good choice. It's quite tough, but cuts reasonably well and shapes well with an English wheel. It folds pretty good, too. Both of these grades of ali respond well to annealing with oxy-accetylene. We use these grades of aluminium on historic sports cars such as Jaguar D-Types etc. These ali types weld really well with oxy-accetylene, too. Not sure if the codes of the aluminium are just UK codes or international codes.
Duralumin (aircraft stuff) is very expensive, hard to work due to the high copper content (about 12%, from memory...) and has the tendency to crack along tight fold lines. It is also tricky to bead roll (will make your swaging machine groan!). It fatigues with age, too. I would save yourself grief and time by avoiding this unecessary metal for your car. Matt
Last Edit: December 12, 2008, 11:45:05 am by All Torque
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
sven
Re: Alum pannels
December 12, 2008, 20:36:04 pm »
Thanks Matt
Basti
Re: Alum pannels
November 13, 2014, 11:03:57 am »
Is there any company in Europe doing nice ali panels for race cars?
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Re: Alum pannels
November 13, 2014, 17:02:46 pm »
Quote from: Basti on November 13, 2014, 11:03:57 am
Cheers,
Basti
Jim & Trevor at Cotsweld
http://www.cotsweld.co.uk/
Happychappy
Re: Alum pannels
November 18, 2014, 08:59:41 am »
Quote from: richie on November 13, 2014, 17:02:46 pm
Cheers,
Basti
What Richie said.
Basti
Re: Alum pannels
November 18, 2014, 09:44:33 am »
Thanks everybody...!
- Pro Mod Race car
