October 14, 2026, 11:55:29 am
| | |-+  Shimming springs?? Help for a newbie.
Author Topic: Shimming springs?? Help for a newbie.  (Read 5262 times)
Jesse/DVK
'64 2176cc
« on: December 14, 2008, 23:30:51 pm »
I would like to know more about the shimming of valve springs. Why do you need to do it and how do you do it? I should recieve my bugpack 4046 next week and I would like to know how to install them on my heads. I've searched a bit on the forum and I read something about coil bind, it's bad if the coil touch each other but to much of a gap is also not good?
Also with break-in of the engine should I remove the inner valve spring?
Thanks!
« Reply #1 on: December 15, 2008, 11:31:59 am »
hey Jesse,
i dont know if its completely correct,
but for my motor, i had 2.5 mm before coil bind at full lift
you also have to check the retainer to guide clearance, and piston to valve clearance
i ran the double springs directly, but i have udo lifters... dont know for other brands of lifters
hope it helps you a bit...
airstuff
« Reply #2 on: December 15, 2008, 20:41:53 pm »
hey ruff,which springs did you use with your web 86c?
how much should they last?
« Reply #3 on: December 16, 2008, 12:30:20 pm »
original CB springs that came with the heads,
they wont last long i think, valves are floating at 7000
i will buy jpm springs in the future i think
