September 23, 2026, 01:16:41 am
| | |-+  Header size
Author Topic: Header size  (Read 9083 times)
Eric Justus
« on: December 15, 2008, 21:32:57 pm »
I keep scratchin my noggin on the appropriate size header to run on this motor... 1, 3/4" vs 1,7/8". I know it seems basic, but I always like to get some insight from everyone.
84x94
13.1 cr
44x37.5 heads
48 idas
1.4 rockers
MSD ignition
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
John Rayburn
« Reply #1 on: December 15, 2008, 21:44:54 pm »
That's a dyno session question.
I also park at Nick's.
Paul Bate
« Reply #2 on: December 15, 2008, 22:24:20 pm »
Hello John,
You haven't stated what cam you are using but even if you were using an FK89 with the 1.4's I would still recomend a 1 3/4 big is not always better.
Kind regards Paul
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #3 on: December 15, 2008, 22:34:30 pm »
I agree 1 3/4 or you may be better off stepping it. But as John said you'd need a dyno session to try your options. I believe too big is bad you want to keep it somewhat tight to keep exhaust speed up.
 Daniel Kurtzmans S/G car runs much the same combo you mention:
84x94
44x37.5
only 10.1 to 1 though
1.4's with FK87
MSD
 We run 1 3/4 header.
John Rayburn
« Reply #4 on: December 15, 2008, 22:38:55 pm »
Hi Paul! Eric was wondering. So, how are you? I wouldn't discount the larger system without dyno time. Greg Brinton uses 1 7/8. His dyno sessions gave him that answer. 1 3/4 didn't cut it with his combination. Again, ask the dyno.
Gary Justus
« Reply #5 on: December 15, 2008, 22:42:00 pm »
It's an FK89.
« Reply #6 on: December 15, 2008, 23:15:42 pm »
Eric/Gary, surely head flow would affect the size required more than anything?conservative ports wouldnt require as a big a header as some huge race port job? John is proberly correct,only the dyno can really answer this,my old n/a 2332 worked perfectly with 1 3/4 phoenix merged header but it was only 10.2/1
cheers richie,uk
Gary Justus
« Reply #7 on: December 15, 2008, 23:28:51 pm »
Hey Richie! Good points. 1 3/4 was the direction I was headed, but diving into new waters just brought up options. As well, the dyno can tell the "tune".
Dominick Luppino
« Reply #8 on: December 16, 2008, 00:58:18 am »
1 3/4 is what I would recomend.
Gary Justus
« Reply #9 on: December 16, 2008, 01:18:39 am »
Seems like the "votes are in". Thanks, Dom (and everybody else).
« Reply #10 on: December 16, 2008, 03:07:46 am »
Maybe a silly question but the air you draw into the combustion, bore and stroke, would that have anything to do with size tube you use when building your header and collector length? Shit, Stuff I do not under stand
« Last Edit: December 16, 2008, 03:10:09 am by danny gabbard » Logged
Speed-Randy
« Reply #11 on: December 16, 2008, 06:10:43 am »
compression ratio also affects size of tube. lower compression, smaller tube, high compression11.5:1 or higher and thats when you start looking for the 1 7/8. the dyno will prove this everytime
