September 22, 2026, 14:16:12 pm
guys in Europe: what do you know about Malpassi
Topic: guys in Europe: what do you know about Malpassi (Read 13511 times)
December 16, 2008, 20:09:55 pm »
Malpassi regulators and filter/regulator assemblies seem to be very popular with the Weber gurus in Europe. I have a brand new Filter King with pressure gauge and filter, and was wondering what the consensus is on these? A lot of the feedback I have found among Weber tuners has been full of praise.
Thank you.
richarzzz
Re: guys in Europe: what do you know about Malpassi
December 16, 2008, 21:34:10 pm »
never heard before. in germany, we use filters from knecht, k&n, fram....
kind regards
jens
if it's tits or tires, it's gone be trouble
December 16, 2008, 21:41:11 pm »
Jim, you see Filter King advertized, but not installed on Hi-Po cars.
PM.
airstuff
December 16, 2008, 21:51:19 pm »
I've heard for Malpassi and their Regulators have a fair price,so are available to everybody.They also produce blow-off valves,fuel filter and that kind of stuff
December 16, 2008, 21:54:36 pm »
Quote from: FDK/Hurry on December 16, 2008, 21:41:11 pm
PM.
Not quite true – if you look at many older sports or race cars, they have now been fitted with Filter King set-ups. I don't like them as they seem a bit crude, but they obviously work.
JS
December 16, 2008, 21:58:14 pm »
I run a filter king on my 12sec car. Used to run a stock fuel pump, too. Worked like a charm. I have the glass bowl so I can see the level when the car is on the dyno.
What´s wrong with them Harry?
Signature.
December 16, 2008, 22:03:27 pm »
Quote from: Fastbrit on December 16, 2008, 21:54:36 pm
PM.
Correct. You do see them on many Weber equipped cars with high specific output motors. The unit I have doesn't seem crude at all though. Beautifully cast mag housing, well finished, etc. The consistency and reliability record of Holleys?
Anyway, hard to find gph rating on these.
For a hot street car, I doubt one of these regulators would come up short on flow... circuit racing, maybe.
December 16, 2008, 22:40:01 pm »
Quote from: JS on December 16, 2008, 21:58:14 pm
Just my impression on DDD and EBI Drag cars. Correct me if i'm wrong.
December 16, 2008, 23:26:56 pm »
Quote from: Jim Ratto on December 16, 2008, 22:03:27 pm
Yeah Jim, but you like BRMs too.
December 16, 2008, 23:57:00 pm »
Hi JS, have you ever had a fuel starvation issue? Do you know your motor HP and your fuel demand (gallons or liter per hour)?
Are you running 8mm hose?
Jim
JS
December 17, 2008, 00:17:09 am »
Nope, no fuel starvation except for a couple of issues with piece of shit electric fuel pumps.
Back when I had the original fuel pump and small valve heads it made about 150 on the dyno. Since then I changed some stuff on it, today it´s maybe 190´ish based on ET.
I was planning on running the original fuel line, but I changed it to 8mm because I was "told" the original would not work. Which I think it would have...
Signature.
December 17, 2008, 00:38:32 am »
Quote from: JS on December 17, 2008, 00:17:09 am
very cool. Thank you!
viNce
December 17, 2008, 06:44:03 am »
King filters are Malpassi filters
There are 3 versions, the standard FK67with standard barbed or 1/8 npt fittings
The FK85...
For Hi Po cars, there is a Hi flow version of the King/Malpassi fuel pressure regulator
http://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=V8reg&CategoryID=8&PartsectionID=18
Bye!
Last Edit: December 17, 2008, 06:54:08 am by viNce
yvre
Der Autobahn Scrapers
December 17, 2008, 11:40:40 am »
Yep. And the ones CB Perf are selling are also from Malpassi I believe.
December 17, 2008, 13:17:40 pm »
wow, those look cool!
DVK ~
December 17, 2008, 17:57:22 pm »
I was given one of the high flow (?) versions with gauge from my friend that does the Porsche restoration, dyno stuff, etc.
He bought few from a vendor in Great Britain, and has used them on a few 911 vintage-race projects, including a psuedo 911R.
I've been staring at it on my workbench, and it sure seems to want to crawl into my engine compartment. Would look nice next to a pair of 48IDAs and a Vertex, right?
And maybe a little better suited to European carburetors over the caveman Holley.
Fasterbrit
December 17, 2008, 18:46:17 pm »
I used a Malpassi filter king on my IDA equiped 2276 Bug a while back and had no probs. 8 mm hose and 3 psi fuel pressure was more than enough for the 196 horsepower the motor made on the dyno.
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Bewitched666
Bewitched
December 18, 2008, 10:20:30 am »
Malpassi..mmm sounds like some exotic dish to me
Fast vw beetle's rule
December 18, 2008, 13:39:41 pm »
I think the boost-sensitive regulator on my turbo stuff was a Malpassi. Came from CB Perf if memory serves me right.
