October 20, 2026, 23:01:36 pm
352322 Posts in 28959 Topics by 6927 Members
| | |-+  JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio
Pages: 1 ... 15 16 [17] 18 Print
Author Topic: JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio  (Read 874953 times)
Airspeed
« Reply #480 on: March 19, 2017, 09:19:02 am »
Did not know that you grew too old to fool idiot drivers  Grin  Wink
I just agree its a fine line to becoming that idiot driver yourself: street racing has altready killed too many good people...
« Reply #481 on: March 19, 2017, 14:04:16 pm »
This is not Oklahoma and there are no TV crews around Wink   And besides this was in rush hour traffic, not a good place to be making boost Shocked Grin
« Reply #482 on: March 28, 2019, 17:25:02 pm »
As I am doing a few changes to the engine I thought I would keep it on original thread for reference so will update this as I go along Smiley
Airspeed
« Reply #483 on: March 28, 2019, 20:48:43 pm »
Good thinking!
« Reply #484 on: April 02, 2019, 18:50:36 pm »
One of the compromises I made last time was on the was on the fan speed, with the big pauter pump and the biggest bottom pulley that would clear it even the smallest available top pulley gave us a ratio way off stock and much lower than even power pulley ratio gives, also the bottom pulley was so close to the pump that to change a fan belt would involve either removing crank pulley or the oil pump.
My idea to solve this was a serpentine belt set up but again nothing available would give us anywhere near stock fan speed so only solution was to make something which is what we are now doing Smiley The finished pulley in pic is smallest I can find & what we are using for measurements for everything except diameter Wink
We also have the gearbox apart as when it was fixed last time some wear on 3rd gear was noted and I don,t want to take any chances this time so it is being replaced with everything else being checked while apart, and also we are adding a sensor to measure input shaft speed
Airspeed
« Reply #485 on: April 02, 2019, 20:08:34 pm »
Nice job on the pulleys!
What were the signs of the former pulley ratio being too small?
« Reply #486 on: April 03, 2019, 00:08:51 am »
As old ECU didn't monitor head temp there is no exact science but we are now the Fueltech and it has the potential to scare me Shocked Cheesy Grin, stock ratio is about 1.57, and we were about 1.36 so at 3500rpm cruising fan is spinning nearly 500rpm slower. one other of our considerations is less availability of E85 this time so if we are running on only 91octane pmp fuel it will need all help it can get on street drives I think
« Reply #487 on: April 03, 2019, 01:48:06 am »
Gday Ritchie.
Some of the green and red tractors/headers (John Deere, Case IH, Meeow Cat if you must) had alternators with really small multirib pulleys, under 2" diameter (ex-John Deere Parts  Wink ).
Since you're in that area, hahaha, maybe worth a look?
https://www.google.com/search?channel=mac_bm&q=john+deere+9650+alternator+pulley&tbm=isch&source=univ&client=safari&sa=X&ved=2ahUKEwjYkd7n2LLhAhUFk3AKHf7FD6sQsAR6BAgJEAE&biw=1174&bih=644#imgrc=UeFVnpBh2KdNuM:
« Last Edit: April 03, 2019, 01:49:53 am by modnrod » Logged
« Reply #488 on: April 03, 2019, 02:24:23 am »
Gday Ritchie.
Thanks mate Cool
Airspeed
« Reply #489 on: April 03, 2019, 08:03:10 am »
I understand the concern! Didn't realize you cruised on E85 last year, but on the upside: you probably need a lot less fill-ups when cruising on 91  Cheesy
Will the stock ratio, the very good 'traction' of a multi-rib pulley and the high RPM of dragracing not be a problem for the fan?
« Reply #490 on: April 03, 2019, 17:02:08 pm »
We are going to have 2 different top pulleys so the track only one slows fan right down to stop that exact problem Smiley
« Reply #491 on: April 03, 2019, 17:03:18 pm »
Whoops, one wheelie to many maybe? Wink
« Reply #492 on: April 05, 2019, 03:21:48 am »
No such thing as too many wheelies ........  Grin
« Reply #493 on: April 05, 2019, 05:00:48 am »
Gearbox is all back together, with added input shaft sensor this time Cool
Basti
« Reply #494 on: April 05, 2019, 12:09:32 pm »
Looking good   Grin
- black 62 cal look beetle
- Pro Mod Race car
« Reply #495 on: April 06, 2019, 17:15:49 pm »
All back together, quick drive round block to check it all works and now will load it into trailer for
TNT@fontana tomorrow Smiley
JeeWee
the Netherlands
« Reply #496 on: April 06, 2019, 21:36:19 pm »
good luck and have fun, very impressive stuff you do!
Eddie DVK
« Reply #497 on: April 08, 2019, 19:06:44 pm »
How did it go Richie
Regards Edgar
« Reply #498 on: April 09, 2019, 19:43:00 pm »
Not wonderful, the tps failed on 1st pass,plastic tang on inside broke off Angry  but I figured a way to get round it enough to run car so we made 2 more passes but could only run on wastegate spring as all the add ons needed to activate 2step/boost control etc need tps signal to know when to start, good news was gearbox worked good and input shaft sensor works so some positives, and its better that tps failed now than in Virginia at start of drag week!!!
volkskris
« Reply #499 on: April 09, 2019, 21:11:10 pm »
It might be good to take some extra sensors to drag week to be sure?
Eddie DVK
« Reply #500 on: April 10, 2019, 07:08:31 am »
Hmm those TPS are all plastic and weak looking I noticed...
Regards Edgar
henk
« Reply #501 on: July 17, 2019, 16:03:51 pm »
Drag week is done,no?
How did it go?
Henk!!!
Erlend / bug66
Global Moderator
SCC Event
« Reply #502 on: July 17, 2019, 16:46:36 pm »
How did it go?
Henk!!!
September.
Race Week has ended
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #503 on: July 17, 2019, 17:57:41 pm »
Yes Erlend is correct, its not until september so I will fly out next month and prepare car etc then we will tow both cars 2500miles to get to start!!!
henk
« Reply #504 on: July 18, 2019, 09:19:27 am »
Oh sorry,my mistake.
Have fun. Grin
Henk!!!
karmi
« Reply #505 on: September 07, 2019, 13:34:13 pm »
Do you already have a 356 (= smaller size) top pulley?
Even smaller than that, its 88mm outer diameter and I have shimmed it as far apart in middle as I can to get belt in deeper so tricking it to think its even smaller Grin
Hello! I'm looking for a KIDD Pulley. Unfortunately I can not find it on the internet. Where did you get yours from? Thank you.
Greeting Conny
« Reply #506 on: September 19, 2019, 23:33:01 pm »
Greeting Conny
http://dev.dunebuggywarehouse.com/kidd-racing-dry-sump-alternator-pulley.html
 Smiley
karmi
« Reply #507 on: September 20, 2019, 22:37:20 pm »
Thank you!  Grin
« Reply #508 on: February 06, 2024, 20:58:46 pm »
Well it finally all worked as intended on Sick week last week, not many Street cars going to 60ft or ET like that on a DOT tire[not slick] with no sissy sticks either Grin
andrewlandon67
« Reply #509 on: February 06, 2024, 21:11:07 pm »
You and Mr. Dalton really took it to the V8 guys last week, fantastic show from both of you and congrats on the big wins in the yellow car!
14.877 @ 88.85 mph
He who waves at 911 drivers
