October 21, 2026, 02:18:43 am
JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio
5
18
Topic: JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio (Read 875055 times)
Re: 4in bore.com and JPM come together in my new engine
Reply #60 on:
December 25, 2008, 02:05:00 am »
Looking good buddy
Reply #61 on:
December 26, 2008, 12:42:30 pm »
Quote from: richie,uk on December 22, 2008, 19:14:27 pm
Quote from: JHU on December 22, 2008, 12:40:09 pm
I don't know when Richie received his heads, but Johannes has invested in a wetflow system this last year. He told me that his 247 hp 1915 was disastrous in that respect, and that he had since gotten rid of the major wet spots. But he had yet to test it on the dyno.
I recieved them from Johannes at SCC this year so maybe he did have a chance to test them this way
Heres the figures that johannes supplied me as he is happy with them being posted here
Flow no at 25" H2O.
Lift(mm) Intake (49mm) exhaust(39mm)
2 46,7 36,2
4 96,1 77,26
6 142,0 108,0
8 183,2 129,1
10 209,3 148,6
12 234,1 163,0
14 250,5 175,1
16 260,3 190,9
The velocity in the intake port in the largest cross sectional area is 309ft/s and the ex velocity at the center of the flange is 334ft/s
Looks like the same numbers as the CB CNC ported , this is how they look like , not that big .
www.Udobeckertuning.de
Reply #62 on:
December 26, 2008, 13:20:01 pm »
Quote from: John Maher on December 22, 2008, 21:17:08 pm
Quote from: JHU on December 22, 2008, 20:50:40 pm
Please use the same flow bench my CB CNC competition eliminators was measured on... that should add about 70 cfm.
Reply #63 on:
December 26, 2008, 19:11:40 pm »
Quote from: Udo on December 26, 2008, 12:42:30 pm
Apples and oranges I think
Reply #64 on:
December 27, 2008, 15:18:15 pm »
Hi Richie
I wish you good luck with the engine , i am building a 2,4 turbo at this time for a friend , hope it gets ready for next year .
Reply #65 on:
December 27, 2008, 20:17:43 pm »
Quote from: Udo on December 27, 2008, 15:18:15 pm
Hi Richie
Thankyou
Reply #66 on:
December 27, 2008, 21:55:43 pm »
Quote from: richie,uk on December 26, 2008, 19:11:40 pm
I had the pleasure of comparing my CNC apples to JPM's oranges in his flowbench... that's why I said 70 cfm...
Airspeed
Reply #67 on:
December 27, 2008, 23:40:21 pm »
Quote from: JHU on December 27, 2008, 21:55:43 pm
Don't forget the MS230 heads cool for the street. Big difference there too. Plus cooler heads also perform better.
Those things don't show on a dynosheet either.
Reply #68 on:
December 28, 2008, 19:45:08 pm »
At what pressure drop?
Reply #69 on:
December 29, 2008, 00:26:01 am »
Well its all together for the final time,
First checked the cylinders for piston to bore clearance and that they were round,Then set the ring gaps,then loaded the pistons into the cylinders
got the lash caps from Roger crawford and Jeff D had an adjustable push rod to suit a motor this wide,so did the rocker geometry and got push rod length,
just need to get some longer push rod tubes as they Jaycee ones I have are to short as are the pushrods,
will get manton to make some up for me next week.
The compression is set at 8.5/1 and I have 670thou[about 17mm] lift so this is going to be alot of fun
Need to make a couple of modifications to the car now to fit it in due to the width and will be building a new header as the 1 5/8 there at the moment is going to strangle this thing.
Reply #70 on:
December 29, 2008, 00:27:05 am »
and as it looks now
AntLockyer
Reply #71 on:
December 29, 2008, 00:57:52 am »
Want!
12.618 @ 104.87mph
58vw
Reply #72 on:
December 29, 2008, 03:02:10 am »
lookin good....ill have my car there tuesday so you can fit it.
www.4inbore.com
Angleflows...order them now
Reply #73 on:
December 29, 2008, 11:59:03 am »
Quote from: richie,uk on December 29, 2008, 00:26:01 am
Lookin' good!
Mags
2,2L 577Hk.
Reply #74 on:
December 29, 2008, 12:46:47 pm »
looking good richie,
where is first race?
Mags
Reply #75 on:
December 29, 2008, 13:18:52 pm »
Hi Jon
Turbo engines do not need much flow , so i think those smaler ports will work.
Reply #76 on:
December 29, 2008, 15:58:20 pm »
Engine is looking awesome. Cant wait to see the numbers its going to run
Reply #77 on:
December 29, 2008, 19:36:26 pm »
Quote from: Fastbrit on December 29, 2008, 11:59:03 am
Lookin' good!
Thanks Keith for lending me you car,think it suits you more though
any reason you wrote Brian on the back though??
K-Roc
Reply #78 on:
December 29, 2008, 22:11:30 pm »
Quote from: BeetleBug on December 26, 2008, 13:20:01 pm
Not sure why the Slamming on the CNC Comp Elims, Were making some pretty decent power with them here.. Lightly massaged Ex Ports, and a different Valve job. I think those heads are good value.
Flow Benches don't win races ( I Know.. I own one )
9.66 @ 140 With a Stupid Holley and No intercooler.
Soon to have EFI and Air to Water
Last Edit: December 29, 2008, 22:14:45 pm by K-Roc
Reply #79 on:
December 29, 2008, 22:13:18 pm »
Quote from: K-Roc on December 29, 2008, 22:11:30 pm
On a single tire launch no less.
Reply #80 on:
December 29, 2008, 22:58:11 pm »
Quote from: Bruce on December 28, 2008, 19:45:08 pm
Sorry, I don't understand the question.
Reply #81 on:
December 29, 2008, 23:07:30 pm »
Quote from: Udo on December 29, 2008, 13:18:52 pm
In my opinion 260 CFM is a lot for a fully streetable head... I'm sure Richie will show us what they can do under a hairdryer
Reply #82 on:
December 29, 2008, 23:13:52 pm »
It's not the heads that receive mixed emotions its the advertising and the CFM numbers therein
You don't need to tell me, I own a set of CNC eliminators!!
John Maher
Reply #83 on:
December 29, 2008, 23:54:28 pm »
Quote from: JHU on December 29, 2008, 22:58:11 pm
To make sense of flow numbers from different sources, you need to know what depression ("H2O) the tests were carried out at.
The higher the test depression, the bigger the flow numbers.
Old SuperFlow 110 benches were designed to test at 10". Some of the bigger SF benches use 25". Later SF600 uses 28".
28" is regarded by many as 'industry standard'.
Last time I looked CB were quoting figures taken at 25". JPM tests I've seen on here are also carried out at 25"
Therefore the
theory
is both sets of figures are directly comparable
You can convert figures taken at one test depression for comparison with those taken at a different depression using this formula...
Multiply current cfm by square root of new test depression/old test depression
Eg, to convert cfm from 25" test to 28" equivalent, multiply 25" test cfm by 1.058
Works pretty good when converting from 25" to 28" (or vice versa) because there's relatively small difference in test pressures but using the formula to correct figures taken at 10" and expecting the results to accurately reflect a test done at 28" is a bit of a stretch. Better to pull the actual depression - but that takes a pretty powerful bench when testing the real high flow stuff.
John Maher
John Maher
Reply #84 on:
December 30, 2008, 00:20:27 am »
Have to agree with JHU - my own flow tests don't come anywhere close to advertised figures
Turbo situation is a lot different and more forgiving of lower flow/low velocity
IMO, based on cfm per square inch of flow area, Comp Elim CNC is lacking and certainly on n/a engine will deliver less performance than other well developed heads with smaller port csa and higher flow (ie more efficient).
Been working on 46x38 CNC Comp Elims today and found a useful increase in flow and velocity by FILLING the intake port! .... as supplied it's wrong shape and too big.
Not on a mission to knock these heads - just a little disappointed to find they're not capable of getting close to the kind of power output the advertising blurb hints at.
Next time I'll start with non CNC version
Last Edit: December 30, 2008, 10:15:42 am by John Maher
John Maher
airstuff
Reply #85 on:
December 30, 2008, 10:45:08 am »
Quote from: richie,uk on December 29, 2008, 00:27:05 am
and as it looks now
hej Richie,
which sump are you using?
n2o
Reply #86 on:
December 30, 2008, 13:42:29 pm »
When I flowed my CE CNC 48x40 right out of the box, I got 230.6 cfm@18mm lift with intake on (25 inch of water, JPM's superflow 600). At that time the advertizement was 270cfm and this was the main selling point from CB performance.
I know there can be differences between flowbenches, with intake, without intake, different size of barrels etc.......but to get 40 cfm more??
Roar
9.88 @ 134.25 mph
Reply #87 on:
December 30, 2008, 13:55:36 pm »
Quote from: John Maher on December 29, 2008, 23:54:28 pm
Therefore the
theory
Thanks John!
I thought this was what Bruce meant, but I couldn't be sure as I have never seen that wording for depression.
Johannes is using a Superflow 600 with digital readout, he always measure in 25" to keep the confusion amongst his customers to a minimal.
So to answer Bruce, both tests was done at 25" at the same flowbench.
However I said 70 cfm as that's how I remembered the difference to CB's advertisements, this was not accurate, I have looked at the numbers again and the CNC 48x40 CE flowed 220 CFM at 16mm lift, where CB says 261 CFM... so thats 41 CFM of difference, not 70... for this I apologize.
I'm looking into filling mine up with plastic to increase the velocity, and increase the efficiency.
Reply #88 on:
December 30, 2008, 16:36:25 pm »
Quote from: JHU on December 30, 2008, 13:55:36 pm
....... the CNC 48x40 CE flowed 220 CFM at 16mm lift, where
CB says 261 CFM
... so thats 41 CFM of difference, not 70....
The problem with your comparison is that CB does not give their flow numbers at 16mm of lift. Only in increments of .050". IOW, only at 15.24mm, and 16.5mm.
n2o
Reply #89 on:
December 30, 2008, 17:33:22 pm »
Richie, what kind of barrels do you use, and are the powersleeved? I am looking for some good quality barrels to my 4inch engine (101,6x86)
Roar
9.88 @ 134.25 mph
5
18
