September 24, 2026, 04:32:32 am
| | |-+  Oil Fliter mounting
Author Topic: Oil Fliter mounting  (Read 7339 times)
Chris W
« on: December 20, 2008, 21:03:23 pm »
Just wondering where everyone is mounting their oil filters. With the current set up just hits the body . Thinking of moving it to the bumper brackets or ....
Thanks for the input.
« Reply #1 on: December 20, 2008, 21:11:26 pm »
Traction Bar ?
« Reply #2 on: December 20, 2008, 21:36:51 pm »
did you the drill holes yourself, harry? nice position.
« Reply #3 on: December 20, 2008, 21:46:23 pm »
Berg mount kit to the bumper bracket for me....
« Reply #4 on: December 20, 2008, 21:47:13 pm »
More Holes in: Hurry, It's Late  Grin
« Reply #5 on: December 20, 2008, 21:47:56 pm »
love it, but it won't work with a nice set of dual quiet packs  Wink
brave man Wink
but could you just post a pic of how it was before, 4" higher?
« Reply #6 on: December 20, 2008, 22:02:02 pm »
Back to Oil Filter Mounting.
Hotrodvw
« Reply #7 on: December 21, 2008, 03:17:31 am »
Guys....watch those block style 90deg fittings....they're tough on the oil flow.  Bent tube 90's are ideal.   Wink
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
« Reply #8 on: December 21, 2008, 19:38:23 pm »
Good point regarding the 90º fitting and flow.
Chris, your engine looks AWESOME! Good job.
Personally, I've always preferred the oil filter to be in the vertical position for servicing ease. Hope that you find a suitable location that works well for you.
Mohawk
« Reply #9 on: December 22, 2008, 00:48:56 am »
I use JayCee billet oil filter mont. I use the mounting holes for the bumper. That have worked perfect for me all years and it's easy to get the filter lose if you have to change it or clean it.
I'm just here because I love VW
http://mohawk-vw.blogspot.com/
Hotrodvw
« Reply #10 on: December 22, 2008, 04:18:37 am »
Are those BSPP hose fittings and adapter for your filter plumbing?Huh   Shocked  Only in Europe.   Wink
Hose & Fittings
'67 Sunroof
Mohawk
« Reply #11 on: December 22, 2008, 11:16:59 am »
What's wrong with them Huh No leaks, most safe stuff you can use and safe for heat so I can't see anything wrong with them, And no they are not for plumbing they are hydraulics  Tongue
Hotrodvw
« Reply #12 on: December 22, 2008, 15:57:22 pm »
No, nothing wrong with them at all....   Wink
It's just not something us Americans see very often.  I'm amazazed I could point it out correctly!   Grin
Hose & Fittings
'67 Sunroof
jimi323
« Reply #13 on: December 22, 2008, 16:52:08 pm »
Traction Bar ?
excuse me for the OT but have you mounted  the traction bar to the bumpers holes?
i think to use a ball joint between the center of the traction bar and the center of the carter... Huh
Chris W
« Reply #14 on: December 23, 2008, 19:01:43 pm »
Thanks for all the ideas!
I am not running a traction bar yet...so I think I will give the bumper brackets a try.
