November 03, 2026, 01:55:30 am
Deburring made my day
Topic: Deburring made my day (Read 14401 times)
airstuff
December 23, 2008, 19:39:38 pm »
OK,today while deburring inside of the case i had an accident,the rotary lightly tuched the edge of the case,but not the whole width of the sealing edge.
It is the right side of the case looking from the oil pump,and this little burr is under the oil pump on the sealing edge,where there is a factory case pin that keeps case sides together.
It's not a milimeter deep,it's smaller,but i can feel it slightly when going over it with the nail.
I hope this can be sealed,what do you guys think
Sorry,it's not the best pic
Here's a pic:
and here's another of the case today in da werks,i finished deburring it from inside out
This was my first case deburring ever,and gee was it ruff and sharp from the factory and from the machine work done to it.
Last Edit: December 29, 2008, 12:20:44 pm by cal-look
airstuff
Re: Deburring made my day
December 23, 2008, 20:19:42 pm »
I was thinking of using Curil T or K2 for sealing the case halves
Doktor
December 23, 2008, 21:28:25 pm »
now you have to buy another new case !
dr.aircooled
airstuff
December 23, 2008, 21:37:27 pm »
Yeah wright ;Dv In another life
December 23, 2008, 22:49:20 pm »
youŽll be fine. IŽm using Hylomar Aerograde for sealing engines. Perfect stuff that remain sticky under all conditions and doesnŽt fell apart like silicone based sealants.
SlingShot
December 24, 2008, 05:54:19 am »
It's going to leak oil for sure ! I would find a new case
Will Race For Beer !!!
Hotrodvw
December 24, 2008, 07:42:44 am »
It's junk. Send it to me ASAP for a secret government project I'm working on.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Type1/DVK
December 24, 2008, 09:19:11 am »
'Dirko' sealant.
DDD#8 - 14.74sec @ 1776cc - Member of: DVK ~ Der Vollgas Kreuzers -
www.ultimatevw.nl
- and racing engines
airstuff
December 24, 2008, 10:15:31 am »
here it is,I measured it today,it ain't bad at all
the mosc to the scratch is outside of the sealing area,only a tiny bit is,but it is also bypasse around it,so it can't leak
December 24, 2008, 12:49:47 pm »
Quote from: cal-look on December 23, 2008, 20:19:42 pm
Perfect.
181
December 24, 2008, 12:50:24 pm »
thereŽs a plenty of untouched sealing surface around the scratch. It will be fine.
Jan
K-Roc
December 24, 2008, 20:12:52 pm »
I like Loctite 574 anerobic flange sealant, it's about a close as your gonna get to the original Porsche sealant and it works soo damm good on the case halfs. if you use the primer as well you will be guaranteed no leaks!
Check it out
http://www.henkel.sg/sea/content_data/93789_574EN.pdf
December 24, 2008, 20:27:32 pm »
I've seen guys on aircraft motors, Put a small peice of thread in the bad areas to fill any voids in castings and combinded with good sealants.
December 24, 2008, 20:40:21 pm »
Quote from: K-Roc on December 24, 2008, 20:12:52 pm
Check it out
574 is killer stuff... case halves, oil pump, cylinder bases... leak free.
SlingShot
December 25, 2008, 21:57:39 pm »
Quote from: danny gabbard on December 24, 2008, 20:27:32 pm
I have heard of this before, some kind of nylon thread.
airstuff
December 26, 2008, 19:31:07 pm »
and who produces this sealing primer/cement?
airstuff
December 29, 2008, 17:23:30 pm »
There's another thing about the case imperfections that I want to ask you guys.
When it came from the USA it came with this little scratch.It's not deep but I can feel it with a nail,should I polish it a bit and assemble,or would this effect oil pressure in any kind.?
Mags
2,2L 577Hk.
December 29, 2008, 17:51:33 pm »
Is this Case from Rimco?
I have same problem with my case.
Mags
airstuff
December 29, 2008, 17:55:14 pm »
no,my case is from Brothers VW Machine
how big is your scratch,and what do you plan to do with your case?
I think in my case,it is not worth align boring jet
But let's hear what experienced people have to say
Last Edit: December 29, 2008, 18:11:27 pm by cal-look
Mags
2,2L 577Hk.
December 29, 2008, 18:21:48 pm »
hi,i have used 2 komp alu from loctite.
i hope you can fix that.
Mags
airstuff
December 29, 2008, 22:32:09 pm »
your case is a mag case or alu case?
What is the product number of this Loctite product,
Thank you
Last Edit: December 29, 2008, 23:44:00 pm by cal-look
airstuff
January 06, 2009, 21:43:59 pm »
I will buff it a little with some steel wool a little bit,and the Brothers say it will be ok
