November 03, 2026, 13:44:36 pm
| | |-+  Pauter roller tip rockers and Ti valves??
Author Topic: Pauter roller tip rockers and Ti valves??  (Read 9672 times)
« on: December 25, 2008, 03:56:45 am »
Opinions on lash caps,are they needed with the roller rockers and Ti valves,when I have used these rockers with steel valves I havent used lash caps but am unsure with Ti,so anyone know for sure?
cheer srichie,uk
Elnef
« Reply #1 on: December 25, 2008, 09:44:25 am »
I am pretty sure you need them
Last year when I bought my Pauter head with Ti valves the lash caps was include and I dont think they follow if not needed
LGK
« Reply #2 on: December 25, 2008, 11:09:24 am »
Hi Ritchie,
If you have the steel tip inserts in the valve-stems you don't need to run the lash caps.
I have a few motors out in this set-up on roller tips and no problems so far.
take care Steve
K-Roc
« Reply #3 on: December 25, 2008, 18:46:11 pm »
Yup you need to know what tips your valves have, or if in doubt and you can't find out... use the lash caps.
merry x-mas
« Reply #4 on: December 25, 2008, 19:06:54 pm »
Thanks everyone,i dont think they have steel tips as we cut them down to length so lash caps it is
Airspeed
« Reply #5 on: December 25, 2008, 21:17:20 pm »
Another consideration about lash caps and Pauter roller rockers is valve geometry. It sounds odd maybe and has nothing to do with strength, but on a type 4, Pauter used lash caps in his kit just to make the proper valve geometry at all possible...
Don't know what the stock geometry is like on a type 1 head with Pauters though, but maybe it has nothing to do with material compatibiity there as well... Roll Eyes
Just a (different) thought  Wink
If you don't actually need them for material strength or material compatibility, they only make the valve side unnecessarily heavier imo... (as you don't run Ti valves for giggles right?)
Cheers,
Walter
« Reply #6 on: December 26, 2008, 00:35:37 am »
Cheers,
Walter
ideally i wouldnt run them but it sounds like I need too,I wonder if Elnef was running roller rockers?Pauter may include them incase you use regular rockers?
Griebel
« Reply #7 on: December 26, 2008, 20:09:50 pm »
Elnef's  Pauter heads :
http://griebel.blogspot.com/2008_01_01_archive.html
« Last Edit: December 26, 2008, 20:11:26 pm by Griebel » Logged
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
« Reply #8 on: December 26, 2008, 21:26:41 pm »
Nice Smiley
« Reply #9 on: December 29, 2008, 12:01:24 pm »
I know it's over a decade ago, but FWIW I always ran lashcaps with Pauter rollers and DelWest ti valves.
Martin
Cash Converter....
« Reply #10 on: December 29, 2008, 15:07:09 pm »
Can you remember that far back Keith?.......   Cheesy
Martin
www.taylormachine.co.uk
OFF/500
« Reply #11 on: December 29, 2008, 16:46:17 pm »
It's a struggle... Cry
