September 24, 2026, 05:39:42 am
what makes a good street tranny
Topic: what makes a good street tranny (Read 19243 times)
Re: what makes a good street tranny
Reply #30 on:
March 16, 2009, 19:38:53 pm »
time to revive my topic...
broke the box yesterday, coming to freddyfiles
so i am now searching for a box again
i am still in a dilemma to use short 3 and 4 or not...
i would like these gears are a bit snappier,
and 1/4 mile is not so important.. i dont race it so much anyways
what do you guys think?
thanks, Peter
aussie
Reply #31 on:
May 03, 2009, 11:58:38 am »
I was looking for exactly the same thing from my gearbox - ended up with the following:
4.125
3.44
2.00
1.32
0.93
Will let you know how it feels when I fit it!
67worshipper
Reply #32 on:
May 04, 2009, 10:41:38 am »
ruff ive got a 3.88 ring and pinion with 3.78,2.21,1.58 and 1.21 which makes it about 60mph in 4th at 3200rpm and 70mph is 4000rpm in 4th.thinking about putting a 1.04 4th to drop the revs a little and not loose to much on the strip.whose got a 1.04 4th with a 3.88 r+p and what speed at 60 and 70?
vw hot rod heaven
Reply #33 on:
May 04, 2009, 11:03:58 am »
hi guys,
because i didn have more money to spare, i chose for stock ratio's
this is what will be installed in a few weeks
Rancho Pro Street Plus (Same as Pro Street with these Extras) $1199
Trans comes complete axle to axle
3.78 Super Beetle 1st
4.12 K ring and pinion
Chromoly Pinion Plate or Nut
SAW Axles for (Swing)and Boots
like i said, most of the time i will be driving on the street, and never use slicks, so lets hope it stays together
67worshipper
Reply #34 on:
May 04, 2009, 11:35:50 am »
do you know the exact ratios ruff.you,ll be fine just lay off the burn outs and dont dump the clutch in first.
vw hot rod heaven
Reply #35 on:
May 04, 2009, 12:16:16 pm »
i think:
3.78 1st
2.06 2nd
1.26 3rd
0.89 4th
and a 4.12r/p
cheers, Peter
Reply #36 on:
May 04, 2009, 12:27:31 pm »
There is also some nice street beef up trans at CSP with different ratio and 4th gear
Reply #37 on:
May 04, 2009, 12:53:57 pm »
a 0.89 is allready long enough for me j-f
i dont like to drive on the belgian freeway anyway
and i think with the extras its a bit stronger?
Reply #38 on:
May 04, 2009, 14:50:36 pm »
Quote from: 67worshipper on May 04, 2009, 11:35:50 am
just wondering, what would he need to be able to do burnouts? it sounds like a nice 'box to me...
p.s. ruff, what bothers me about the belgian freeway is the asphalt, pretty lethal without dropped spindles. is that what you mean?
DVK ~
tikimadness
Reply #39 on:
May 04, 2009, 15:52:10 pm »
Go for a super diff and some heavy duty side covers and you are fine for burn outs(even in first gear)
Michael
NIDGAFWYT
Reply #40 on:
May 04, 2009, 15:57:48 pm »
what's the difficulty scale of upgrading a stock gearbox with a super diff and HD side covers, once you have build a hi-po VW engine?
DVK ~
tikimadness
Reply #41 on:
May 04, 2009, 16:02:46 pm »
You need to shim the ring and pinion(preload) and set the backlash.
It is not just exchanging the diffs .
Michael
NIDGAFWYT
Reply #42 on:
May 04, 2009, 16:55:51 pm »
Quote
yeah, that,
and the fact the the front end gets very light with speeds above 150
67worshipper
Reply #43 on:
May 04, 2009, 17:51:09 pm »
Quote from: 67-indeed/DVK on May 04, 2009, 14:50:36 pm
its the torque of the 2litre plus.if its only run on roads and not the dragstrip it,ll be fine.slicks and traction will make it a mess
vw hot rod heaven
