November 02, 2026, 19:09:37 pm
Building a 2110 - any advice ???
Topic: Building a 2110 - any advice ??? (Read 24023 times)
December 09, 2006, 19:55:09 pm »
Hey Guys I need some advice
I have just done a deal on some engine bits and it looks like I'm going to be building a 82x90.5 2110cc with a pair of IDA's and some Scat D port heads, My plan is for this to be a full on STREET motor that will be matched to a 5 speed box and will see plenty of miles so whats your advice guys
What cam
which make of crank
ratio'd lifters
push rods
Ignition
Rods
I need all the help I can get guys so let me know what set ups your running out there
48ida
Re: Building a 2110 - any advice ???
December 09, 2006, 20:24:01 pm »
2110? Good choice
Here is the spec of mine
82mm Berg forgedcrank
90.5mm Mahle barrels & pistons ( total seal rings )
Engle FK8 cam with straight cut timing gears
Eagle race rods
VW type 1 dual relief case
Scat deep sump
040 cast cylinder heads ported & polished by Jeff Denham
valves 44 x 37.5
compresion 9.5 to 1
bosch blue 009 dissy with 8mm Blue Max leads
Weber 48 IDA's with Berg linkage on skat trak maniolds
Pheonix 1 3/4 inch merged header with A1 Turbo muffler
Mocal external oil cooler
Berg oil breather / filler
Berg equaliser pulley
Berg welded fan
Good for 162 bhp and runs 13's in a full street weight bug with a lard arse driving it
I DRIVE MY VOLKSWAGEN WAY TO FAST TO WORRY ABOUT MY CHOLESTEROL LEVEL
December 09, 2006, 20:47:58 pm »
Cool cheers dude - but did it have ratio'd rockers
December 09, 2006, 22:56:41 pm »
Quote from: monkiboy on December 09, 2006, 19:55:09 pm
What cam
which make of crank
ratio'd lifters
push rods
Ignition
Rods
First is this all new or used? if used allow for a valve job and some springs,best to start of all good
My choice would be K8 or fk44 both with 1.4 rockers,chromoly push rods.
Rods,I would go for h beams,you could use i beams but they are heavier,personally i would put 5.5s in it but 5.4s would be ok
Compression 8.7 upwards,what is this going in? full weight car or light buggy
1 5/8 merged header with your choice of muffler[in a bug dual quiet packs]
I would use a scat crank,just had good luck with them myself & it would be 84mm stroke,but then I would use 94mm piston/cylinders
cheers richie,uk
PS and lose the idas,they are to old and badly designed
Re: Building a 2110 or 2332 what do you think guys
December 09, 2006, 23:52:28 pm »
Hey Richie - I was hoping you would reply
The parts I have are a pair of IDA's with match ported manifolds, Scat Pro comp heads 40x37.5 D ports cut for 90.5/92's with 56cc chambers and a 1 5/8 stainless header - They are second hand but have only done approx 1500 miles
I was thinking of a 84x94 motor but this would mean machining out the the heads - would this be ok
Also the engine will be going in my new Street racer Bug/ 70's Cal Looker
Why do you say don't use the IDA's
and what would you use instead
would it involve lots of tubing and a spinny thing
So what would be your ultimate spec for a street going 2332
Last Edit: December 10, 2006, 00:15:05 am by monkiboy
December 10, 2006, 03:07:43 am »
82 X 90.5 -- yeah now we're talking. I'm collecting parts for this combo myself.
So far I've collected:
Case--late 70s fuel injection case
Crank--CB forged/nitrided 82mm
Rods--RIMCO Super Rods
P/Cs--Mahle
Heads--VW 043 worked by K-Roc. 40x35.5, 186 CFM @ .600"
CB 1.4 ratio rockers, dual springs
Web 86B cam
Magnum gears
CB 28mm lifters
Dellorto 48 DRLAs
I'm going to try and have the shortblock underway over the winter (altho I am not sure how that will really go). Once it is done, if it runs solidly down in the 13s on street tires I'll be really happy.
December 10, 2006, 08:27:33 am »
I Just Built an 84x94 Motor 2332 for my 67 Bug
Scat 84mm Chevy Rod Crank
C.B. 5.7 H Beam Rods
Engle FK47 Cam with 1.4 Pauter Rockers
Magnum Straight Cut Gears Steel on Steel
C.B. Wedgeport Heads 44x37
10 to 1 Compression
Century Long Barrels with Wisco Pistons
12Lb Flywheel with a Stage 1 Kennedy Press Plate
48 Ida's with 42mm vents and Scat Track Manifolds
1 3/4 A 1 Merged Exhaust with Magnaflow muffler
Joe Hunt Magneto with locked out advance
Motor put out 237 H.P. @ 6500 on the Dyno
Working on Building the Trans Now. Cant Wait to get it in the Car I Wanted to put the Engine in the Car but Dont Want To spit The Stock Trans out in the Street LOL
Martin Greaves
10.88@128.58
December 10, 2006, 11:43:57 am »
monkiboy
Don't listen to Richie what does he know
December 10, 2006, 13:46:08 pm »
Quote from: gold65turbo on December 10, 2006, 11:43:57 am
monkiboy
Sorry Lee,
as martin says i dont know anything, I will let him advise you as he knows so much,cheers richie,uk
December 10, 2006, 14:20:19 pm »
I will run 86 x 94 with AA pistons and Barrels. 10:1cr 44 x 37 heads IDA's (Which i will change to EFI cuz they are shit;)) and using a webcam 86b cam for street use.
Should be good for 200bhp+
Only need a a couple of bits and it can be put together.
December 10, 2006, 14:31:14 pm »
monkiboy
Quote from: richie,uk on December 10, 2006, 13:46:08 pm
monkiboy
Sorry Lee,
Ah come on guys stop putting your selves down
So what would you suggest Martin
let me guess some more tubing and a spinny thing
ESH
December 10, 2006, 16:20:24 pm »
I definitely don't know anything, (I work in an office for a start!
) but you're welcome over anytime. Richie's 84/94 suggestion makes sense to me, a big lazy is good for the street I think.
December 10, 2006, 16:49:41 pm »
Well I must know nothing then cos I work in a Hotel in London
Thanks for the offer Mat PM your phone number and address and I'll pop over soon dude - I've been dying to checkout your ride in more detail
you run a 2332 right
December 10, 2006, 18:38:12 pm »
If you dont upgrade to 94's now, you will soon wish you had once the motor is running!
Martin Greaves
10.88@128.58
December 10, 2006, 19:01:45 pm »
monkiboy
Sorry Lee,
Go and buy a mini and put a 1340cc motor in it.
ESH
December 10, 2006, 20:59:48 pm »
Quote from: monkiboy on December 10, 2006, 16:49:41 pm
Have sent a PM. A hotel? It's a wonder either of us even know what an engine is!
Rune
SCC Crew
Screwdrivers #7
December 12, 2006, 11:56:12 am »
Keep your IDAs dude, runs just as smooth as everything else if you just get to know them..
Last Edit: December 12, 2006, 12:06:25 pm by Rune
