September 22, 2026, 16:18:19 pm
| | |-+  Benefits of front drag runner tires
Author Topic: Benefits of front drag runner tires  (Read 12594 times)
Eric Justus
« on: December 30, 2008, 16:12:36 pm »
Anyone ever noticed a dramatic difference between running a front runner, drag type tire on the front versus a 135 size tire?  Undecided
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #1 on: January 01, 2009, 17:55:21 pm »
  Benefits of using drag tires such as frontrunners are,
high speed rating
22" are shorter than 135's which will give you a better reaction time
23" are taller than 135's which will slow reaction time  eg.(non pro tree)
135's are radials,when mixed with slicks will have more a tendancy to make the car darty and wander
much lighter
they look much cooler too Cool
« Last Edit: January 01, 2009, 22:24:27 pm by Jason Foster » Logged
AntLockyer
« Reply #2 on: January 01, 2009, 18:11:24 pm »
135's are radials,when mixed with slicks will have more a tendancy to make car darty a wander
Is that true?
12.618 @ 104.87mph
« Reply #3 on: January 01, 2009, 20:50:10 pm »
Is that true?
Yes
And is not legal,you should not mix bias ply[most slicks] with radials
cheers richie
AntLockyer
« Reply #4 on: January 01, 2009, 21:04:02 pm »
I thought the law is don't mix radial/cross ply on a single axle.
I'll add some front runners to my shopping list then.
12.618 @ 104.87mph
Martin
Cash Converter....
« Reply #5 on: January 03, 2009, 15:39:21 pm »
Is that true?
Im running Sportman Pro's on the rear (cross plys) and 135 radials on the front. feel great  at 145mph.
Front runners offer less rolling resistance and allow you to set your front wheels with zero toe in. if you look at the the Front runners they arnt speed rated and the maufactures wont put a speed rating on them.
We have had this argument in street eliminator.
Ant is right you can have a mix of tire on the cars just not on the same axle.
SO the benfit is less effort to push the car down the track.
Martin.
Martin
www.taylormachine.co.uk
OFF/500
andy M.
« Reply #6 on: January 03, 2009, 19:54:48 pm »
<a href="http://www.youtube.com/v/vs0WzoVJmaM" target="_blank">http://www.youtube.com/v/vs0WzoVJmaM</a>
this is what happens to people who mix their tyres!
andy
L.B.C.R.
« Reply #7 on: January 03, 2009, 20:22:16 pm »
What!!! You mean you'll be forced to drive a Morris 1100 in BMC Tartan Red? OMG! Cheesy
« Reply #8 on: January 03, 2009, 20:30:32 pm »
Is that true?
Martin.
martin you need to go read the rules Shocked,
sorry but those front tyres are not legal on your car according to the msa rule book Roll Eyes
cheers richie
Martin
Cash Converter....
« Reply #9 on: January 03, 2009, 23:02:02 pm »
Is that true?
Martin.
cheers richie
I'll Go read the rule book, but its what most of the street eliminator cars are running. Radials on the front and big old baggy cross plys on the rear.
Andy I remember that advert when it was on TV!!! Man i'm getting old!.
Martin
OFF/500
AntLockyer
« Reply #10 on: January 03, 2009, 23:13:05 pm »
andy
That's awesome, I'm going to mix some tomorrow for some stunt driving.
12.618 @ 104.87mph
Eric Justus
« Reply #11 on: January 03, 2009, 23:30:22 pm »
high speed rating
much lighter
Eric Justus
Jason Foster
« Reply #12 on: January 04, 2009, 01:13:21 am »
Good choice Eric...
« Reply #13 on: January 04, 2009, 10:08:29 am »
The speed rating of a tyre is the measure of its ability to dissipate the heat which is generated under prolonged use at high rpm. I have had discussions before with both tech inspectors and tyre people about this and they all said (mind you, it was a few years ago...) that speed ratings as applied to road tyres are irrelevant in drag racing. The tyres do not revolve at speed long enough to generate sufficient heat to cause a problem – or so I was told by industry specialists.
Martin
Cash Converter....
« Reply #14 on: January 04, 2009, 13:05:08 pm »
Just read the Rules and Yes your right Richie, the speed rating is to low for my MPH. Looks like i'll just have to buy some more front wheels and tires.
The other SE cars are running a higher speed rated tires on the front.
Going to have to investigate this a little more. As Keith says im sure the 135 are safe at the speeds they are traveling at. Hell there only 10 years old! LOL
Have a good day, Just off to make some more power!
Martin
Martin
OFF/500
« Reply #15 on: January 04, 2009, 19:16:09 pm »
Martin
 Wink  i dont buy stuff I dont need,to tight for that,there must have been a reason I bought them Wink Cheesy
cheers richie
Eric Justus
« Reply #16 on: February 11, 2009, 03:24:35 am »
Touchin on this subject again. I have been running the math on the heigth of the front runners which go from 22.5, 24 and 26. All play a diiferent role in which tree you run and how your reaction time and roll-out affects what you are going for. I will be racing on the pro-tree most of the time, but not all of the time. I have also talked to a few guru's about this and how the heigth plays into personal scenarios.
I am eluding to...I like to hear from people about this.  Cheesy Stories anyone
Eric Justus
Roman
« Reply #17 on: February 11, 2009, 18:25:51 pm »
I have 22.5" on my car, but if I would buy new ones I'd choose 24". They look better and the speedo gets a bit more accurate.
Martin Greaves
10.88@128.58
« Reply #18 on: February 11, 2009, 19:01:20 pm »
What don't you go over 90mhp then. Cheesy Grin
Roman
« Reply #19 on: February 11, 2009, 20:33:49 pm »
Well, some of us drive on the street! Smiley
Martin Greaves
10.88@128.58
« Reply #20 on: February 11, 2009, 20:37:07 pm »
So do i  Grin
