September 22, 2026, 07:20:46 am
| | |-+  48 IDA fuel inlet fittings - how and where ?
Author Topic: 48 IDA fuel inlet fittings - how and where ?  (Read 20554 times)
Rasser
« on: January 02, 2009, 20:56:25 pm »
I am trying to find a good fuel inlet system for my 48īs.
I would like to run a stainless hardline to a tee, and from there a stainless tube to each carb. I have been looking at summit racing, but I canīt find the proper fittings for the connection between the carb and flared end of the stainless tube. It doesnīt matter if the fitting is a banjo fitting for the side of the carb, or an ordinary fitting for the top of the carb, since im not running any airfilters.
I just wanīt to be able to run a safe, good looking and easy to dismantle fuel inlet pipe/fitting, and I would still like the classic look, so I am trying to avoid the red/blue AN fittings (black is OK)
Anyone that knows what will fit and where I can get it ?
Rasmus
« Last Edit: January 02, 2009, 21:10:32 pm by Rasser DK » Logged
1955 type1
1966 type2 13w deluxe
« Reply #1 on: January 02, 2009, 22:05:46 pm »
How about these:
http://www.cbperformance.com/catalog.asp?ProductID=1762
Rasser
« Reply #2 on: January 02, 2009, 22:43:34 pm »
They are great items, but my problem is getting from there to 5/16" stainless steel HARDline (or 3/8")... anyone know where I can get the flare fittings i need for this ?
I have allready found the stainless hardline and the flarefittings for installing on the hardline, but canīt figure out how to get from there to the carb.....
« Last Edit: January 03, 2009, 00:14:38 am by Rasser DK » Logged
1955 type1
Rasser
« Reply #3 on: January 02, 2009, 23:26:39 pm »
It looks like I need a fitting that has "16x1,5mm (male)" on one side and on the other side it has to accept "1/2-20" Male inverted flare"
Or I will have to go 16x1.5mm -> AN 6 -> AN tube end (3/8")
Rasmus
« Last Edit: January 03, 2009, 00:16:20 am by Rasser DK » Logged
1955 type1
« Reply #4 on: January 02, 2009, 23:36:40 pm »
I think Eric, the guy that posts as HotrodVW can probably help you.
Isn't the thread going into a 48IDA 12mm x 1.5 though?
Rasser
« Reply #5 on: January 03, 2009, 00:14:03 am »
As far as I can figure out (measure) the one on the side uses 12x1.5mm and the top one uses 16x1.5mm.
But there isnīt much room on the side of the carb, so you have to use a banjo fitting here - and the choices here seem to be limited. Thatīs why i was hoping to find a good way to connect to the top 16x1.5mm and then make a 90degree bend and go into the stainless tube from there.
If Eric doesnīt find this thread, I will try to contact him -
thanks.
1955 type1
« Reply #6 on: January 03, 2009, 00:23:17 am »
thanks.
Originally, Weber sold the 48IDA equipped with a 12mm banjo bolt and a banjo fitting that a hard line had to be sweat soldered to... maybe you can find those?
In pictures of some of the old Cobra Coupes, like the cars that ran @ Le Mans, and in some of the old GT40 pics, you can see how this was originally done (and the cool heatshield that protected the carbs from the heat off the headers too!)
Rasser
« Reply #7 on: January 03, 2009, 00:29:30 am »
thanks.
Modifying a banjo and solder the stainless tube to the banjo could be an idea, but can this be done with steel banjo/stainless steel tube ?
anyway here are pictures that might help
« Last Edit: January 03, 2009, 00:32:02 am by Rasser DK » Logged
1955 type1
« Reply #8 on: January 03, 2009, 01:39:48 am »
Here is what I'm putting together. I made the carb fittings myself from 6061 Aluminum and had them hard anodized. The 90 degree fittings are -6 AN Ano-Tuff swivel fittings from Earls. I will be using Earls Pro-Lite black cloth hose to the fire wall regulator and 3/8 aluminum hardline from the pump up front to the regulator in the engine bay.
« Last Edit: January 03, 2009, 08:54:59 am by stealth67vw » Logged
SHAWN GEERS
« Reply #9 on: January 03, 2009, 01:41:54 am »
Is this what you're looking for?
« Last Edit: January 03, 2009, 01:45:06 am by SHAWN GEERS » Logged
« Reply #10 on: January 03, 2009, 01:48:21 am »
This is another option
http://www.thesamba.com/vw/classifieds/detail.php?id=660340
Rasser
« Reply #11 on: January 03, 2009, 12:16:38 pm »
I have thought about that option, but I would still need to get from AN-6 -> 5/16 or 3/8 hardline, and thats my biggest problem right now.
1955 type1
Rasser
« Reply #12 on: January 03, 2009, 12:17:58 pm »
Sorry no, I wanīt to route a stainless steel hardline to the inlet of the carbs - and I canīt figure out how to go there from the AN-6.
1955 type1
Rasser
« Reply #13 on: January 03, 2009, 12:20:06 pm »
Thats what Iīm looking for, but I donīt like the "space-age" look with the blue anodized AN fittings. If they were available in black anodized og nickel plated, then I would have found what I was looking for.
1955 type1
Lanny Hussey
« Reply #14 on: January 03, 2009, 16:16:18 pm »
Show off.... Wink
Hotrodvw
« Reply #15 on: January 03, 2009, 17:53:30 pm »
I'm here!  I found it!   Cheesy
Where is your 5/16" hardline located?  I can also get you some #5AN/JIC x 12mmx1.5 adapter to accomodate the 5/16" hardline if needed.  You can use what we call a tube reducer (Fem. #6 x Male #5) which will let you use an #6AN fitting on your carb, and reduce it to #5.  This would look funny IMO, and would be better visually to reduce it behind the shroud or somewhere else.
I ran all 3/8" hardline.....it's way over kill, but I had the materials to do it.
IT CAN BE DONE.   Wink  PM me if you'd like.
Eric
« Last Edit: January 03, 2009, 18:00:06 pm by Hotrodvw » Logged
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
« Reply #16 on: January 03, 2009, 18:25:43 pm »
Cool Eric. I want to do hard lines to my IDAs as well. I will get up with you when I am at that point.
Hotrodvw
« Reply #17 on: January 03, 2009, 18:42:12 pm »
I say this from experience.  THEY'RE A PAIN IN THE ASS!!!!!!!!!!!!!!!!!!   Cheesy
But they look kinda cool.
Hose & Fittings
'67 Sunroof
« Reply #18 on: January 03, 2009, 19:04:11 pm »
Hi Eric, Great work, i like the seperate line for the pressure gauge. Nice !
Why are they a pain ?
Hotrodvw
« Reply #19 on: January 03, 2009, 19:08:37 pm »
They're a pain to install w/ the carbs and engine in.  Not much room to swing a wrench.  I use some stubby combo wrenches which help a lot, but it's not near as easy as rubber hose.  BUT.......I'd still run the hardlines.   Wink
Hose & Fittings
'67 Sunroof
« Reply #20 on: January 03, 2009, 19:15:31 pm »
What about the flare tighteness ? How many loosen ups and re-tightenings could the flares of the
hard line stand ?
Thanks, Eric
Best Regards,
Harry
Rasser
« Reply #21 on: January 03, 2009, 23:38:14 pm »
Hotrodvw:
What you have on your engine is almost similar to what I want.
I will send you a PM with more detailed description
thanks
Rasmus
1955 type1
Hotrodvw
« Reply #22 on: January 04, 2009, 07:41:40 am »
hard line stand ?
Thanks, Eric
Best Regards,
Harry
The key first off is to not over tighten.  The main cause for a leak here is damaging the sealing surface (The AN/JIC Flare).  There is a proper torque spec, generally I just get them snug and not over do it, it seems to be real close to the proper torque spec.  Technically, you can install and uninstall them many, many times, as long as the seal is in good shape, and the same parts are used together.  Taking an adapter that was previously used on somethign else, and now using it w/ a different tube or hose, can increase your chances of a leak.
Hose & Fittings
'67 Sunroof
« Reply #23 on: January 04, 2009, 17:56:39 pm »
Thanks Eric !
Ohio Tom (DdK)
« Reply #24 on: January 04, 2009, 22:12:11 pm »
You can buy the swivel nuts and specal flaring tool that will put a 37deg flare on tubing.
This is compatible with the standard AN/JIC fittings. (looks like the motor above). Nothing specal needed. Summit racing sells everything for the job. Any color you choose too.
However, I do have one caution about running any hard lines to the carbs.
The motor grows in width as it warms up. This repeated heat/cool cycles will stress the hard lines. Combined with all the vibration it will see, I'd worry about flex failure.
I don't see this as a "safer" option.
Ohio Tom
08'.. 3 R/U...3 Win...
Rasser
« Reply #25 on: January 04, 2009, 22:29:31 pm »
I have allready found the tube bending/flaring kit, but I canīt find the swivel nuts on summits webshop (only found the inverted flare nuts, but would like the same type as hotrodvw uses on his hardlines in the pictures above)....  can anyone help me out ?
1955 type1
« Reply #26 on: January 04, 2009, 22:37:04 pm »
Thanks Tom, i'll always forget about the expanding/shrinking factor. No hard lines for me.
Hotrodvw
« Reply #27 on: January 04, 2009, 23:04:07 pm »
Tube nuts:
http://store.summitracing.com/egnsearch.asp?N=700+115+310636&D=310636
Tube Sleeves:
http://store.summitracing.com/egnsearch.asp?N=700+115+300081&D=300081
I also have had concerns about the expansion, and have been keeping a close eye on them.  I haven't had a single issue yet.
Hose & Fittings
'67 Sunroof
Rasser
« Reply #28 on: January 05, 2009, 13:12:45 pm »
Tube nuts:
Tube Sleeves:
That was exactly what I was looking for.
AN6 tubenuts and sleeves + 3/8" hardline will fit together ?
1955 type1
Hotrodvw
« Reply #29 on: January 05, 2009, 16:01:12 pm »
Yup....think of it this way (in SAE terms):  6/16" = 3/8"  Meaning, #6, or 6/16", is what we call a #6 fitting.  #4 is 1/4", or 4/16".  All of the AN fittings are measured in 1/16ths of an inch.
Hose & Fittings
'67 Sunroof
