October 14, 2026, 02:25:16 am
tips for turbo engine spec
Topic: tips for turbo engine spec (Read 8108 times)
Rocket Ron
It's old school for a reason
January 06, 2009, 09:52:14 am »
Hi all
Just picked up a CB turbo / efi cb set up and I'm looking for some help with the engine spec..
I would like to use a pair of the JPM heads as I've been impressed with the cars running these and they seem to have more cooling area than most performance heads, but I'm looking for some help with rods, timing gears, compression ratio, cam, turbo size etc .
I have a 2276 with IDA's which was built for me in my bug and I'm real happy with. I'm told that this size of engine go together fairly easy, so I'm thinking of this sort of size engine again
It will be going into the ghia I've got and this will be fulll street weight plus cage. The ghia got irs out back so I'm looking to run a uprated bus box.
My goal would be to run a 11.99. What sort of hp and set up do I need for this.
I think the problem is going to be lack of grip as I'm limited to the size of wheel I can get out back.
Any tips or pointers for a turbo virgin
13.12 @ 101.84
Grooving out on life
yvre
Der Autobahn Scrapers
Re: tips for turbo engine spec
January 06, 2009, 10:08:25 am »
There you go:
http://www.turbobobefi.com/
January 06, 2009, 20:00:27 pm »
Quote from: rocket ron on January 06, 2009, 09:52:14 am
Hi all
Ron ,look at what Mike lawless has done to his ghia regards fitting the slicks and a bus box here:
http://home.comcast.net/~mlawless29/wkr.htm
You would need to be looking at about 300hp to guarantee 11s,given the way turbo cars launch and you have to shift the thing.I have PM you some more
cheers richie
Roman
January 06, 2009, 21:23:37 pm »
You don't need any turbo to run 11.99 with JPM heads!
January 06, 2009, 22:19:21 pm »
Quote from: Roman on January 06, 2009, 21:23:37 pm
With a full weight ghia with cage,bus box,IRS and driver weighing about 2400lbs? you think?
it should end up really drivable with sensible compression for english fuel and still run that with ease
cheers richie
Rocket Ron
January 06, 2009, 22:56:42 pm »
Quote from: richie,uk on January 06, 2009, 20:00:27 pm
Hi all
cheers richie
Good read I've pm'd you back
i saw something like this where they took 1.5/8" from each side and fabed up some new shock mounts off the frame horns and then tied it together through the floor etc they go a 235 radial under a stock low light body using irs
Ps just put a bid on a fk45
13.12 @ 101.84
Roman
January 07, 2009, 11:05:19 am »
Quote from: richie,uk on January 06, 2009, 22:19:21 pm
cheers richie
2400 lbs, that's heavy! If it is 2400 lbs I agree, you would need around 300 hp to get into the 11's with some margin.
January 07, 2009, 11:14:53 am »
you think?
cheers richie
At 2400lbs is Ron going to fit in a Ghia?
Sounds like a nice project though Ron, and Mike Lawless' site is a vey interesting read. I've got it bookmarked at home...
Rocket Ron
January 07, 2009, 19:32:05 pm »
Quote from: Neil Davies on January 07, 2009, 11:14:53 am
you think?
cheers richie
Its alright Neil I'll have to start weight watchers, should be able to get the pounds off by the time the cars ready
The lawless site is boked marked here as well
13.12 @ 101.84
