September 22, 2026, 07:37:39 am
Max HP @ what revs?
Topic: Max HP @ what revs? (Read 19471 times)
stretch
Max HP @ what revs?
January 07, 2009, 10:58:41 am »
I've recently completed the engine build for my street / strip car. When it was set up on the Mustang dyno at Race Shack I was supprised to find that peak power was made at 6134rpm, with peak torque at 5400rpm.
The engine spec is as follows:
2332cc
10.9:1 c/r
CB Ultra wedge port cnc heads (46 x 37.5mm)
CB 5.6" rods
CB 2289 cam (very similar to engle fk87)
51.5mm IDA's
Running on Bio-ethanol.
Peak power was 163BHP @ the wheels, peak torque was 147ft-lbs. I'm not disappointed with the figures, far from it, they have grossly exceeded my estimates, and after driving the car it feels pretty quick.
I just assumed (wrongly) that with that cam / head combo, peak power would have been made higher up the rev range, what do you guys think?
Roman
Re: Max HP @ what revs?
January 07, 2009, 11:20:30 am »
The power seems a bit low. I had a very similar combo on my 2387 and it made 30 more HP.
2387cc
12: 1 CR
Wedgeports with 46 x 37
5.7 rods
FK-89
52 mm carbs
Running on E-85
See dyno sheet here:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=282333
Peak power 228 hp at 6950 rpm
Rear wheel horsepower 195.7
My heads were made by JPM before the ultra wedgeports was availible. Take a look at the manifolds as the ones made by CB were far too small even though CB called them match ported.
Mark Herbert ported the manifolds some and when I got them I ported them some more. When JPM got them he added some weld and ported them even more!
January 07, 2009, 11:21:09 am »
Morning Stretch, how's it going!
What weight did the car come in at? I'm still convinced that there needs to be a correction factor applied to the numbers from that dyno!
I'd have expected a little closer to 200bhp with that set up.
Anyway - things like the length of the intake manifolds are going to affect where in the rev range the power will be. Have a search for some of Jim Rattos posts - he seems to have tried most combinations and is very knowledgeable when it comes to remembering combinations of what works and what doesn't!
Neil
stretch
January 07, 2009, 11:42:29 am »
Morning Neil, i'm good thanks you?
Car with me in it weighs 2000lbs. Car without me in it weighs a LOT less !!
You can't really compare dyno figures unless they were all taken on the same dyno, i'm not looking for more power (yet
), but was wondering about where the power was made.
I notice from your graph Roman that peak power was made at 6900rpm, with a slightly wilder cam, so mines looks about right.
Cheers guys.
John Maher
January 07, 2009, 13:40:47 pm »
Peak power rpm definitely seems low for the engine specification.
Slight giveaway might be the relatively narrow gap between peak torque and peak power. On a street engine I'd expect the difference to be much greater than 600rpm!
The fact peak power is at relatively low rpm for the spec and not too far away from peak torque, I'd suspect something restrictive on the intake side (heads, manifolds, carbs??).
Each time I've tested an engine with restrictive intake (usually heads), the power peaks earlier than expected and tends to flatten off for several hundred rpm rather than continue the expected upward climb. How does it look on the printout?
BTW, agree with you re comparing figures from different dynos.... it's generally a waste of time. You can only make direct comparisons when carrying out subsequent tests on the same dyno (assuming it has the same calibration). Lots of other variables too but that's another conversation
John Maher
stretch
January 07, 2009, 15:29:02 pm »
John,
The power curve certainnly wasn't peaky. The power rose steadily and flattened off, as you suggested.
The heads are out of the box cnc ported c/w cnc ported manifolds (tall). The carbs are jaycee 51.5mm ida's with 44mm venturi's.
To be honest I'm happy that it makes power lower down, to my way of thinking lower revs = less stress on components. Also the broader spread of peak power will mean that shift points aren't as critical. This will be good for bracket racing. I hope
John Maher
January 07, 2009, 17:23:54 pm »
Quote from: stretch on January 07, 2009, 15:29:02 pm
That's another clue.... check the
gastric band
manifolds... big at the top and bottom but what about in between?
Manifold cross sectional area should taper gradually from carb butterfly down to head flange. Instead you have hour glass impression.
Minimum csa of manifold is determining ultimate flow potential of your entire intake system.
Might involve some welding on manifolds to avoid breaking through but peak rpm and bhp will increase, eliminating plateau on power graph (more area under the curve) i.e. car goes faster/quicker
John Maher
Roman
January 07, 2009, 18:58:37 pm »
Quote from: John Maher on January 07, 2009, 17:23:54 pm
gastric band
Yep, exactly as I said earlier. Here is a picture of my manifolds just to get an idea what is needed. The welding/porting from CB wasn't enough so I added some more (the uglier weld on the side towards the engine and on the outside towards the valve covers). A LOT was removed in the middle.
drgouk
January 08, 2009, 05:29:54 am »
What Exhaust are you running?
January 08, 2009, 07:22:45 am »
John,
I think the cnc heads out of the box need some port work , and cutting for more compression ! As i said in anouther thread , the cnc work is good to have less hand work .
udo
www.Udobeckertuning.de
stretch
January 08, 2009, 09:56:38 am »
Thanks for the info guys. I'll get the manifolds modified and let you know the results when I get the chance to get the car back on the dyno.
When I say the heads are out of the box, they have had some work, essentially they have been cut for higher compression and have had all the sharpe edges radiused. I also smoothed the cnc marks out of the inlet and exhaust ports. So no major work, just a few hours in the garage with a few rolls of emery cloth.
The exhaust is an 1 3/4" turbo thomas stainless merged header & turbo muffler.
January 08, 2009, 16:58:40 pm »
I agree, manifold design for Type 1 style (stock) head needs more work. A good design is the Super Flow or comp eliminator IDA manifold. I think the long Skat trak style, if not ported enough, over accelerates the intake charge, and restricts it at high rpm. It may have worked on 1700-1800cc motors "out of the box" but with nearly 600cc of cylinder volume to fill @ 6000+ rpm... they neck down too much and are probably too long.
ugly duckling
January 20, 2009, 16:01:56 pm »
it just goes to show ya what hand done heads can do for ya VS the macine type. talk to (schwimmer or rayburn) they will tell ya two perfect exampels of what 94 bore true pump gas (OEM STYEL) street head engines will make on alot lower 8.6 to 8.8 compression and reg 48s and smaller cams.
JD.
Last Edit: January 21, 2009, 06:40:07 am by ugly duckling
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
Ohio Tom (DdK)
January 28, 2009, 15:19:55 pm »
From those dyno sheets. It looks to me like there is a big issue starting aroun 5,000rpm that just makes power nose downward.
I'd be looking at your fuel system and/or jetting combo. Are you getting enough Alky to the motor?
Something is definatly way off.
Ohio Tom
08'.. 3 R/U...3 Win...
The Ideaman
January 29, 2009, 02:32:10 am »
Here is the dyno sheet from the Steve Hollingsworth 2276 in the Jade Grenade.
Customer 2276 Cu Cm 4 Str
Luke 82X94 5.325 rods 50/50 rac gas
48 IDA 165m 200a 120ia 65i 40 vents 32 timing
42X37.5 heads 9. cr K8 berg 1.4 rockers
1 5/8 ex w 2 1/2 magnaflow muff
FUEL SG = 0.720 INERTIA FAC = 0.000
AIR TEMP = 66.0 REL HUMID = 27 BAROMETER = 29.86 SAE CORR = 1.014
DRIVE RATIO = 1.0 TORQUE ARM IN = 12.6 LOAD CELL MAX = 250
REV TQ-RAW TQ-COR BHP PRESS-1 O2 AT3 AT4 KT1 KT2 KT3 KT4 BSFC SFC ET DELTA ACCEL RPM
Min Lb-Ft Lb-Ft CORR #/hp-hr #/hr Sec Time Rpm/S Act
3300 124.9 126.6 79.6 -23 0.12 32 32 68 182 156 205 0.44 34.8 0.217 0.217 0 3304
3400 127.3 129.0 83.6 -23 0.12 32 32 68 199 191 297 0.44 36.8 0.733 0.516 196 3405
3500 132.3 134.1 89.5 -23 0.12 32 32 68 176 188 334 0.45 40.6 1.235 0.502 199 3505
3600 132.6 134.5 92.3 -23 0.12 32 32 68 211 184 286 0.49 45.1 1.721 0.486 204 3604
3700 134.9 136.7 96.5 -23 0.00 32 32 68 255 220 383 0.50 48.0 2.200 0.479 217 3708
3800 135.6 137.5 99.6 -23 0.12 32 32 68 279 230 422 0.49 48.8 2.586 0.386 254 3806
3900 134.6 136.5 101.5 -23 0.00 32 32 68 195 217 461 0.50 50.8 2.862 0.276 370 3908
4000 133.7 135.6 103.4 -23 0.00 32 32 68 203 200 451 0.51 52.5 3.234 0.372 266 4007
4100 133.3 135.2 105.8 -23 0.12 32 32 68 271 235 424 0.55 58.5 3.662 0.428 245 4112
4200 134.2 136.0 110.0 -23 0.00 32 32 68 261 271 447 0.55 60.8 3.856 0.194 691 4246
4300 134.8 136.7 112.7 -23 0.00 32 32 68 242 272 455 0.54 60.8 3.922 0.066 1273 4330
4400 136.8 138.7 116.4 -23 0.12 32 32 68 240 246 428 0.52 61.1 3.996 0.074 1068 4409
4500 137.9 139.8 120.0 -23 0.12 32 32 68 261 239 383 0.52 62.8 4.278 0.282 344 4506
4600 135.8 137.7 120.7 -23 0.12 32 32 68 246 246 340 0.52 63.1 4.595 0.317 319 4607
4700 138.9 140.8 126.2 -23 0.00 32 32 68 252 252 349 0.50 62.8 4.797 0.202 490 4706
4800 146.0 148.0 135.3 -23 0.12 32 32 68 249 224 384 0.46 62.3 5.010 0.213 460 4804
4900 148.3 150.4 140.5 -23 0.12 32 32 68 241 231 388 0.44 62.0 5.195 0.185 562 4908
5000 145.3 147.3 140.5 -23 0.00 32 32 68 235 250 488 0.44 62.0 5.347 0.152 651 5007
5100 140.5 142.4 138.5 -23 0.12 32 32 68 233 221 379 0.46 63.7 5.507 0.160 638 5109
5200 139.0 140.9 139.7 -23 0.00 32 32 68 196 206 355 0.47 65.7 5.668 0.161 596 5205
5300 138.8 140.7 142.6 -23 0.12 32 32 68 244 204 337 0.47 67.7 5.805 0.137 861 5323
5400 138.6 140.5 144.7 -23 0.00 32 32 68 246 192 361 0.48 68.8 5.924 0.119 739 5411
5500 137.7 139.6 146.5 -23 0.00 32 32 68 257 235 412 0.48 70.5 6.016 0.092 1087 5511
5600 136.7 138.6 148.1 -23 0.00 32 32 68 242 259 407 0.48 71.7 6.110 0.094 1074 5612
5700 135.5 137.4 149.8 -23 0.12 32 32 68 215 200 400 0.48 72.2 6.191 0.081 1395 5725
5800 134.8 136.6 151.1 -23 0.12 32 32 68 207 193 391 0.48 72.0 6.258 0.067 1269 5810
5900 134.0 135.9 152.9 -23 0.00 32 32 68 215 178 353 0.47 71.4 6.344 0.086 1140 5908
6000 133.5 135.3 155.0 -23 0.12 32 32 68 219 170 286 0.46 70.5 6.459 0.115 939 6016
6100 132.8 134.7 156.9 -23 0.00 32 32 68 205 180 358 0.44 68.8 6.554 0.095 1105 6121
6200 132.1 133.9 158.4 -23 0.12 32 32 68 216 176 439 0.42 67.1 6.618 0.064 1422 6212
6300 130.4 132.2 158.9 -23 0.12 32 32 68 208 173 343 0.41 65.4 6.717 0.099 1020 6313
6400 127.6 129.4 157.9 -23 0.00 32 32 67 211 238 356 0.41 64.5 6.842 0.125 792 6412
6500 123.7 125.4 155.4 -23 0.12 32 32 68 246 252 341 0.42 64.8 6.974 0.132 735 6509
6600 120.2 121.8 153.2 -23 0.12 32 32 68 245 241 389 0.43 65.1 7.121 0.147 646 6604
6700 116.8 118.4 151.2 -23 0.12 32 32 67 229 197 331 0.44 66.0 7.281 0.160 650 6708
6800 112.3 113.9 147.6 -23 0.12 32 32 68 239 205 375 0.47 69.7 7.463 0.182 544 6807
6900 106.7 108.2 142.2 -23 0.12 32 32 68 226 224 399 0.51 72.0 7.717 0.254 386 6905
7000 101.3 102.7 136.9 -23 0.12 32 32 68 196 221 343 0.53 72.2 8.024 0.307 322 7004
7100 96.1 97.4 131.8 -23 0.00 32 32 68 216 189 313 0.55 72.8 8.370 0.346 298 7107
7200 92.3 93.6 128.4 -23 0.00 32 32 68 215 204 345 0.58 74.5 8.756 0.386 254 7205
Here ya go, Barry!
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
January 29, 2009, 17:16:56 pm »
I should dig up the dyno session from Roger Crawford's in 2000
2276cc street engine, Comp Eliminator 46 x 37 by Heads Up, 10.0:1, s/s valves, Heads Up 320 steel cam (280@ .050), 48IDAs, 40mm vent 165 main, 170 air F11 tube
made 213 @ 7100 and 175ftlb @ 5500.
67worshipper
February 01, 2009, 12:48:49 pm »
Quote from: The Ideaman on January 29, 2009, 02:32:10 am
Here ya go, Barry!
cheers luke.i,ll make a photocopy of this page for my records.
vw hot rod heaven
John Maher
February 02, 2009, 02:07:51 am »
Results from a 2276cc n/a fuel injected street motor, fitted with Dick Nuss heads (044s, fitted with 45mm x 37.5mm valves).
Porsche cooling, stainless 1 3/4" header and 2 1/2" turbo muffler.
Very driveable on the street - fitted with Berg 5 transmission.
Figures are flywheel bhp in full street trim i.e. muffler and belt fitted.
Dick Nuss heads also allow more peak bhp rpm (superior flow) than seen on the next engine.
Never been on a drag strip.... yet
Another 2276cc street engine. Normally aspirated, 48IDAs, 9.5:1, mildly reworked (fluff and buff, good valve job), CNC oval port 044s: 44mm x 37.5mm
Fitted to a
real
street car i.e. full interior, all steel panels, original glass etc plus roll cage.
12.30 @ 108mph with 3.88 r&p, 1.48 3rd, 1.04 4th.
MT DOT tyres.
These figures are also flywheel bhp, through same style 1 3/4" exhaust and 2.5" muffler as engine above but no fanbelt.
Check how the EFI engine can be pulled as low as 2500rpm at wide open throttle whereas the IDA engine wanted to stall out when pulled much lower than 3500rpm.
Figures have
NOT
been subject to the
'Add 4 bhp per 1000rpm'
bullshit correction factor
Last Edit: February 02, 2009, 10:44:22 am by John Maher
John Maher
