September 24, 2026, 01:27:58 am
| |-+  For sale!
| | |-+  2276 Longblock + Carbs + Oil System £2500 ono
Author Topic: 2276 Longblock + Carbs + Oil System £2500 ono  (Read 2375 times)
71CALRIPPER
« on: January 07, 2009, 11:34:08 am »
Posting for a good friend of mine, selling up due to having other priorities these days. I think this is a good buy even for parts as its had some good parts put into this build, it still needs its cam burnt in and had only been test fired before being put into storage.
£2500
The engine is in Surrey UK but could be shipped out at buyers cost Smiley
Built by John Skeldon - UK engine builder who has produced some good engines
Specs are:
CB Perf High Roof Case
Compression 9.5:1
82mm Scat Crank
Lightened Flywheel, HD gland nut etc
CB Perf 5.6 inch vw journal H beam rods
FK87 Cam
Manton straight cuts
Mahle B&P's
Total Seal Rings
Superflow Heads 48x38
Scat Pro 1.4:1 Ratio Rockers
Anodised pruple spring loaded push rod tubes
44 idfs
Fram Filter and oil system
Please ignore the header it was only used to test fire Smiley
« Last Edit: January 07, 2009, 11:58:31 am by 54caldub » Logged
