September 22, 2026, 05:57:23 am
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  dimensions of radio
Author Topic: dimensions of radio  (Read 5338 times)
« on: January 08, 2009, 15:59:06 pm »
i'm not around my car at the moment. i was wondering if anyone knows the dimension of the radio hole.
better still, how large does a radio need to be to fit in my '67?
thanks  Wink
« Reply #1 on: January 08, 2009, 16:15:20 pm »
Not sure, but I know they're smaller than standard DIN size radios. Are you trying to repair a cut out dashboard? If so, Karmann Konnection sells a repair panel, although I used a section cut out of a donor car to repair mine. If you're looking for a radio to fit, then I think CIP1 has a period-style radio with MP3 input for a reasonable price.
« Reply #2 on: January 08, 2009, 17:56:24 pm »
i found a very cool radio, but i can't tell if it will fit...
faceplate dimensions are 173 x 50 mm, but they size of the radio is not listed though from the pictures i can tell that it's about the same.
ian c
« Reply #3 on: January 09, 2009, 07:01:47 am »
faceplate will probobly be bigger than the actual hole .
(o\ ! /o)
« Reply #4 on: January 12, 2009, 12:42:15 pm »
could it be that a 911 radio is smaller? i measure my old radio and it was something like 19x6cm
