September 10, 2026, 09:07:54 am
352302 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Mahle or Kolben-schmidt bearings? (Main/Con-rod)
Pages: 1 [2] Print
Author Topic: Mahle or Kolben-schmidt bearings? (Main/Con-rod)  (Read 41319 times)
Martin Greaves
10.88@128.58
« Reply #30 on: November 07, 2011, 14:35:11 pm »
Clemex
Sliver Line
Jesse/DVK
'64 2176cc
« Reply #31 on: November 08, 2011, 17:01:50 pm »
Can someone tell me if Sintermetal are ok to use for con-rod bearings? What should be the problems compared to other bearings if the size is ok? Different material?
Type1/DVK
« Reply #32 on: November 08, 2011, 17:20:07 pm »
feels like paper those main bearings.. Don't know about con-rod's but i would guess they be the same. I would not use the brand in any way. Mahle KS Clemex Silverline all good about those.
Jesse/DVK
'64 2176cc
« Reply #33 on: November 08, 2011, 17:50:05 pm »
There weren't available. I have silverline main, mahle camshaft and sintermetal con-rod.
viNce
« Reply #34 on: November 09, 2011, 09:06:27 am »
Go with Clevite's for your rods, you won't be disapointed.
http://www.drdracingheads.com/xcart/Rod-Bearings.html for example...
Type1/DVK
« Reply #35 on: November 09, 2011, 10:46:36 am »
i can send you a set of KS or Mahles.
PS: nice engine project you have again ViNcE! keep it up
henk
« Reply #36 on: November 09, 2011, 21:08:04 pm »
can somebody tell me how big the bearing on the flywheel side should be between the "U" on a STD. bearing?
the KS bearing i have now measures between 21,85 and 21,90.
is this normal or a bit to small,as they don't fit in my case.
henk!!!
Type1/DVK
« Reply #37 on: November 09, 2011, 22:55:30 pm »
measure your case, it should be around a round number like 22.00 or 21.00.
If you have the bearing and the case they should have a snug fit, and for me the best way to test it is by rotating the bearing until it hits its dowelpin hole. *click* should it say (haha difficult to explain)
The bearing could be 21.97 and the case 22.00 that's fine. But not a whole tenth off! bearing should have some ''kapspanning'' as it is said in dutch.
Measure your case, machine the bearing to it.
Jesse/DVK
'64 2176cc
« Reply #38 on: November 09, 2011, 23:51:23 pm »
henk!!!
Had that same problem with KS. Throwed them away Smiley
Pierside Parts Unlimited
« Reply #39 on: November 20, 2011, 06:56:05 am »
Clemex bearings are the OE bearing for Mexico. They are identical to the OE bearings(production #'s and manufacturing) that were around about a year ago. They are steel backed on the center main and seem to hold up well.
« Reply #40 on: November 20, 2011, 09:54:31 am »
henk!!!
Sounds like you got the KS bearings that do not fit. all where in a shorter and higher box than the older ones
henk
« Reply #41 on: November 20, 2011, 19:44:10 pm »
henk!!!
hallo,
yes,looks like it just my luck again.
i had them machined down a bit and now they fit perfect.
i just hope they last for some time,if i read al this i start to get scared of bearings whitout steel backings.
henk!!!
Pages: 1 [2] Print
