October 12, 2026, 09:15:16 am
59 gets a makeover-Early Cal-look - includes 1985cc Engine Build - it runs!!!!!!
5
Topic: 59 gets a makeover-Early Cal-look - includes 1985cc Engine Build - it runs!!!!!! (Read 170173 times)
Re: My 59 gets a makeover - Early Cal-look - includes 1985cc Engine Build
Reply #90 on:
December 04, 2011, 20:12:32 pm »
that makes that car even more special. cool project, which would make a nice engine with the rebuild gearbox.
Reply #91 on:
December 04, 2011, 21:30:11 pm »
Jo, the flywheel looks chromeplated...
Jo Clifford
Reply #92 on:
December 05, 2011, 00:41:52 am »
Quote from: Zach Gomulka on December 04, 2011, 13:07:26 pm
Neat motor build, I dig the specs. How much compression? I've heard the NPR's don't like it over 9:1, maybe thats just a nasty rumor though.
With the deck height we're aiming for it will work out at 8.9, so looks like I'm safe
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Russell
Reply #93 on:
December 05, 2011, 01:13:48 am »
Looking great Jo, glad your getting stuck in to the engine, better than waiting for the boy, he takes ages...... I'm always waiting.
Nice work on the interior also, can't wait for you too take me to starbucks, we will get there in half the time now.
Russell
Best Regards
Russell
rick m
Reply #94 on:
December 05, 2011, 02:20:07 am »
ZACH....
Just a rumor on the NPRs. We've all run them with more compression than 9.0.
RM
Rick Mortensen
Driving Hot VWs since 1970
Jo Clifford
Reply #95 on:
December 10, 2011, 20:52:30 pm »
Thanks for the positive comments
and also thanks to Rick M, for confirming what we already believed, that the rest of the components, assembly and final tune are the most important aspects of any build.
So with the deckheight set at 0.055 I was able to know the desired cc required in the heads, so now I am just waiting for this to be done and my manifolds to be match ported, so I can finish up the long block, I am supposed to have the heads and manifolds at the end of next week, fingers crossed
The compression is now set at 9.1/1
Also this week, I had the pistons balanced (thanks Shawn, for the quick service
) there was 6 grams difference from lightest to heaviest, so they definitely needed doing.
I also got my stage 1 kennedy cover and a super daiken disc, so they can go on as well
Jo Clifford
Reply #96 on:
December 11, 2011, 00:48:59 am »
All those parts were then cleaned and we decided to paint the cylinders, with a high heat paint.
Jo Clifford
Reply #97 on:
December 11, 2011, 23:53:53 pm »
With the paint dry on the cylinders, they got a final clean and the insides lubricated, ready for ring sealing, the rings were checked for gap then refitted to the pistons, which were then fitted back into the cylinders, using a tapered ring compressor all that was needed was a gentle push down and they were in, seals put onto pushrod tubes and that was all I could do until the heads arrive.
rick m
Reply #98 on:
December 12, 2011, 06:16:14 am »
Nice work Jo. I'm send these shots of you doing your motor to my daughter Shanna. She has a 65 bug and wants to do her next motor, with me there to simply give direction. You do a better job than many guys I've observed trying to build a motor.
Rick Mortensen
Rick Mortensen
Jo Clifford
Reply #99 on:
December 12, 2011, 19:52:22 pm »
Quote from: rick m on December 12, 2011, 06:16:14 am
Rick Mortensen
Thanks for the kind words Rick, it would be nice to think that me doing this and posting on here helps to inspire her to go ahead and do it. Having someone watching and giving advice gave me the confidence to try it myself, I'm sure having you there giving direction will do the same for Shanna
It would be cool if you could do a build thread with her on here as well.
Jo
Jo Clifford
Reply #100 on:
December 17, 2011, 05:52:20 am »
On Wednesday morning I got a message to say my heads and manifolds were ready to be picked up, at this point I just would to say 'Thank You' to Greg and Steve Tims for their excellent service, vary rarely do you get parts or products earlier than promised, which is the case here
So we collected them that afternoon, now I could continue with my engine build.
First the head studs were checked for length and shortened slightly, with a small amount of loctite on each I fitted them to the case. Then the wrist pins, rod small ends and pistons all were lightly oiled, the inner piston clip was fitted and a small amount of sealant placed on the bottom mating surface of the cylinder.
I then fitted the first piston/cylinder to the rod and pushed it down to the case, this was repeated with the adjacent piston/cylinder and the under cylinder tin fitted.
Jo Clifford
Reply #101 on:
December 17, 2011, 05:59:31 am »
Now I could fit my new cylinder heads
I lowered one into place, applied a little sealant to the pushrod tube seals and fitted them in place, with a little more sealant under the 4 lower head washers, the washers and nuts fitted with some thread assembly lube, I torqued the heads in place.
Jo Clifford
Reply #102 on:
December 17, 2011, 06:03:36 am »
With pushrod length and rocker geometry sorted for me I fitted the pushrods with a little lubricant on each end and on the tip of the valve, then fitted the rockers, which torqued down and finally adjusted the valves.
Jo Clifford
Reply #103 on:
December 22, 2011, 04:50:55 am »
So next was all the tin, a vent tube was added to the 1 & 2 valve cover, some pieces of tin got some paint then with some small adjustments and trimming everything was made to fit together.
This older Scat breather box was cleaned and declared fit for use, the carbs were fitted back to the ported intake manifolds then to the engine.
The shroud was marked for the coil mount, drilled then fitted with rivnuts and the coil was then fitted.
Jo Clifford
Reply #104 on:
December 22, 2011, 05:02:21 am »
Time to take it off the build stand and onto the run stand, took the opportunity to introduce the car to it's new engine
Then onto the run stand, everything was hooked up, a special run in oil added, carbs primed and it fired up, timing checked and adjusted then straight away we could tell it was a little lean so stopped, idle jets changed and started up again, ran for a few minutes like this, still seemed to want more fuel so up another size on the idle jets and it ran much better and smoother. Ran it long enough to bed the cam in properly and then shut it off
It was really nice after shutting it down to see it was totally dry underneath, not the slightest sign of a leak, I guess I did my part well
Carbs are now going to come apart as one of them isn't reacting to adjustment very well so may have a problem from sitting for several years, once that is sorted it will go in the car.
Re: 59 gets a makeover-Early Cal-look - includes 1985cc Engine Build - it runs!!!!!!
Reply #105 on:
December 22, 2011, 08:23:38 am »
Nice build thread, thanks for sharing. A beautiful, little engine indeed.
I would like to wish you and Richie a Merry Christmas and a Happy New Year. Look forward to seeing you again in 2012.
Kind regards,
Kalle
Taylor
Reply #106 on:
December 22, 2011, 12:49:03 pm »
I dig the mufflers! cool!
Fasterbrit
Reply #107 on:
December 22, 2011, 21:26:53 pm »
Sweet project
I dig the colour!
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Jo Clifford
Reply #108 on:
December 24, 2011, 18:19:47 pm »
After a lot of tinkering with the carbs and making several jet changes, we ran the engine again last night, and now todays job is to get it in the car
http://www.youtube.com/v/8eSBFlEIoqs
Reply #109 on:
December 24, 2011, 22:33:28 pm »
Sounds great
Have a good Christmas
Lee
Reply #110 on:
December 25, 2011, 17:31:52 pm »
x2
Jo Clifford
Reply #111 on:
December 25, 2011, 19:35:05 pm »
So first job was to remove the old engine, then remove the header and exhaust as these will be used on the new engine (the exhaust shown before is one we just use to run engines on the stand).
I then cleaned up the header and painted it with high temp black paint (it was ceramic coated silver when I bought it)
The tin over the flywheel was fitted then the Scat breather box mounted and we now could install the engine.
Jo Clifford
Reply #112 on:
December 25, 2011, 19:44:25 pm »
Engine fitted, no problem, so next was plumbing, I also had a new Berg Traction Bar kit that we bought at the Classic a few years ago, that had been gathering dust waiting for a project like this
This was fitted and we decided it would provide a good place to mount the oil filter, then we measured the length for the oil lines and I made them up, then fitted them.
Jo Clifford
Reply #113 on:
December 25, 2011, 19:51:32 pm »
Carbs were fitted, fuel lines done and all the little things connected or added, mufflers bolted back on and it was ready, first we just checked for any possible fuel leaks, primed the carbs and it fired straight up, a faulty oil pressure light switch gave us a small scare, but after it was swapped everything was good, all we had left to do was adjust the clutch cable free play.
First time the clutch pedal was pushed down the tube in the tunnel broke away and left us with no clutch operation
It sounds good seems to run well, no leaks, but I can't drive it!!!!
Jo Clifford
Reply #114 on:
December 26, 2011, 01:18:14 am »
Well it seems that even naughty girls get Christmas presents, I just took it on it's maiden voyage
rick m
Reply #115 on:
December 26, 2011, 09:55:07 am »
Jo,
What cam did you put in this motor? Just curious.
Rick M
Rick Mortensen
Reply #116 on:
December 26, 2011, 14:25:51 pm »
Quote from: Jo Clifford on December 03, 2011, 19:12:51 pm
So here's the full spec of the engine:-
VW Magnesium case, with machine work by Jason Lauffer
DPR 78mm welded crank, with matching 14lb flywheel, 36mm Scat Gland nut
Eagle VW journal 5.5 rods (donated by my red car after it's engine rebuild)
NPR 90mm stroke pistons and cylinders (New)
Engle 125 with bolt on cam gear and Scat lifters
Steve Tims Heads, 42/37 valves, opened up for 90mm cylinders, 52cc chamber
1.1 / 1 swivel feet rockers
VW main bearings, Mahle rod bearings, Silverline Cam bearings, dual thrust.
Kennedy Stage 1 and Super Daiken disc
1.5 qtr sump (no name brand, swapmeet find)
Santana Power Pulley (swapmeet bargain)
26mm Shadeck oil pump, blue printed and plugged for full flow, with swapmeet pump cover
Thunderbird 1 5/8 header and dual mufflers
44 DCNF's on Berg Manifolds
Bosch 010 Distributor with blue coil
12v Alternator with Berg welded fan
36hp style shroud
Jo Clifford
Reply #117 on:
December 26, 2011, 22:54:25 pm »
Small job done today, re-installed the original speedo, this was restored almost 3 years ago by Orange Empire Speedometer, reset to Zero, in preparation for a new engine.
Jo Clifford
Reply #118 on:
December 27, 2011, 00:36:11 am »
Another job done, thought it was time to upgrade the rear lights, so these are now installed and what an improvement
Mike Lawless
Reply #119 on:
December 27, 2011, 01:17:28 am »
Quote from: Jo Clifford on December 26, 2011, 01:18:14 am
Been following along Jo. That's gotta feel pretty good. Doin' it your own self, then drivin' it around! Nicely done!
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
5
