September 22, 2026, 08:12:23 am
| | |-+  Superdiff problem
Author Topic: Superdiff problem  (Read 6627 times)
GetBackOnTrack
« on: January 10, 2009, 16:49:11 pm »
Hi. I took my swingaxel gearbox apart and found that on of the 3 pipes holding the spider gear axels in place had broken. I was able to take out the two short axels that holds in place two of the spider gears (I run a superdiff with four spider gears) and they spin nicely on the axels. Now I have the long axels with the last two spidergears sitting in the diff. The thing is it seems that atleast on of the spidergears has seized on the axel, and I cant punch out the axel. My question is, has anybody had similar problems like this? How do I get the axel out? And is it possible to buy a new axel to replace the one that obviously must be brooken?
Any input will be apreciated.
Thanks in advance.. Jakob
Check: gbot.dk
Airspeed
« Reply #1 on: January 10, 2009, 17:50:31 pm »
So you can/will break that one as well?  Roll Eyes I would try to upgrade now that your 'in there'
Sorry, no answers from me in the swingaxle issue as I don;t have experience with those..
« Reply #2 on: January 10, 2009, 19:11:24 pm »
Press it out.
Most likely, your diff is junk.
Sam K
« Reply #3 on: January 10, 2009, 23:54:54 pm »
It's possible that your axle end gear (sometimes called a crown gear) has broken. I've had this happen before and they expand a little and become very hard to get out.
dangerous
« Reply #4 on: January 11, 2009, 01:48:22 am »
http://www.shoptalkforums.com/viewtopic.php?t=123074
Ohio Tom (DdK)
« Reply #5 on: January 12, 2009, 04:03:11 am »
The Weddle Superdiff is my choice. They have spiral grooved shafts that get enough oil to the spider gears to keep them from seizing onto the shaft.
 I too have seen this happen a few times on other diffs.
Usually associated with Hi-Po burnouts...
So far, all the Weddle units I have installed have been holding up fine.
Ohio Tom
08'.. 3 R/U...3 Win...
Fast Bug
« Reply #6 on: January 12, 2009, 19:15:25 pm »
Quaife Grin
