July 22, 2026, 19:15:06 pm
Hurst Roll control
Topic: Hurst Roll control (Read 17002 times)
Hurst Roll control
January 13, 2009, 15:57:12 pm »
Got one on order and have a few questions about it,
Can i fit in on to the framehead plate on the opposite side of the master cylinder or does it have to be mounted higher than the master cylinder on the bulkhead?
Also, I relise you need adaptors, but if i have my own brake pipes made up does anyone know the thread sizes for the hurst inlet/outlets (imperial?) and the thread size of the standard ends on a vw brake pipe (metric?) to avoid the adaptors
Any advice would be great.
Mike Lawless
Re: Hurst Roll control
January 13, 2009, 17:10:31 pm »
Here's how mine is mounted...
The ports in the Hurst are 1/8"NPT. There are adapters available to mate the ports to 10mm bubble flare like stock, or to 3/16" inverted flare like US cars, or to #3 AN
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
Jonny Grigg
January 13, 2009, 20:26:54 pm »
Quote from: leec on January 13, 2009, 15:57:12 pm
Lee,
You can mount it anywhere (within reason of course!). I am not sure why you think it needs to be higher than the master cylinder?
I ornignally mounted mine on the fram head the other side of the M/cylinder. I used the adapters with the VW brakelines. If you buy the brake pipe kit, there is enough in there to make the system up and looking good. Believe me, it is easier than getting your own 'bespoke' ones made up.
J.
No Compromise. O/FF111
Ohio Tom (DdK)
January 14, 2009, 05:46:36 am »
The line lock comes with 1/8" NPT ports. Adapt as required...
Ohio Tom
08'.. 3 R/U...3 Win...
SteveW
January 14, 2009, 20:39:43 pm »
Mike, have you got the brake bias adjuster fitted because your running drums on the rear?
Lee, you can get all the adapters from here..
www.speedflow.co.uk
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
benssp
www.callookvw.com
January 14, 2009, 21:48:06 pm »
we got em
http://www.vwheritage.com/ssp/Brakes/Brake-System-Parts/?srchPart=AC611999A
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Mike Lawless
January 14, 2009, 23:09:52 pm »
Quote from: SteveW on January 14, 2009, 20:39:43 pm
www.speedflow.co.uk
Yeah Steve, that's why I put it on, although I haven't messed with the adjustment yet. I have custom discs up front (my own manufacture) and type 3 drums out back. This year I had given some though to disc out back too, but I had just replaced my MC and had everything buttoned up. The calipers I was going to use were Wilwood four piston Dynalites, but I was concerned about the stock dual circuit MC having enough volume for that, so I decided to stick the the drums.
Every so often in a bracket race I need to stab the brakes pretty hard on top to ensure I'm not breaking out. When racing American cars that are substantially quicker, they can come up fast at the stripe, leaving little room for error. A couple of times I have done that and it upset the car a little when the fronts locked up. I put that on to minimize that. Since I was replumbing the entire brake system at the time, it was an easy add on that wasn't too expensive.
SteveW
January 14, 2009, 23:42:28 pm »
Thanks Mike! Do you think it's needed when running disks all round? I'm still undecided as to run one or not. RLR says he doesn't use them now (I'm running his brakes all round)
Steve
1970 Stock Beetle.
Mike Lawless
January 15, 2009, 03:44:18 am »
I'd say it would not be necessary with four corner discs. If the system is done and closed up, ready to run, then run it as is. But if you are still building the system and have not plumbed it, I say why not?
January 17, 2009, 12:56:35 pm »
Thanks for all your advice guys.
Do I need to block one outlet in my master cylinder?
Jonny Grigg
January 17, 2009, 13:00:39 pm »
yes. I used a reversing light switch- works fine.
January 17, 2009, 13:15:50 pm »
Jonny, you are the man.
Im a complete numbty with this.
Could you give me an idiots guide to how you routed the brake pipes from the master cylinder to the ports (which ones) in the roll control?
Mike Lawless
January 17, 2009, 15:45:18 pm »
Pretty simple. There are two "out" ports on the master cylinder. One gets plugged, the other goes to the "IN" port of the line lock. A Hurst has two or three out ports depending on when it was made. You use one "out" port of each front brake, and if there's a third, you can either plug it, plumb in a pressure gage, or put in a pressure switch to activate a light.
Hotrodvw
January 17, 2009, 16:38:24 pm »
Here's how I did mine. I do have a handfull of 10mmx1.0 allen plugs available here if anyone needs some.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
January 20, 2009, 20:35:57 pm »
Update!
We have fitted the line lock, switch and warning light. It has all been wired in but havent done the brake pipes so no fluid in the unit.
We wanted to check the wiring was correct so we turned the ignition on, pressed and hold the switch, but get nothing. No warning ligh on, cant 'feel' the unit working. Is this normal?
Hotrodvw
January 20, 2009, 20:59:18 pm »
No.......mine clicks on and off.
Hose & Fittings
'67 Sunroof
January 20, 2009, 21:06:39 pm »
could be a ground problem.
i just took out my lijne lock as i still had moshy brakes. now the pedal is firm and the fronts lock up good and equal. so i am happy with the result and braking now. i still like to have a linelock, but safety first and now the brakes feel much safer and better.
so for now i keep on running two residual pressure valves on the front brakes and adjusted the back drums as close as they could go without constant drag.
i run talbot brakes up front and type3 drums in the back. i still believe a linelock can't make much difference because it is a closed circuit and the displaced volume off fluid stays the same, but it is not. maybe it is the linelock, maybe the setting off the drums.
January 20, 2009, 21:08:51 pm »
Your experience with the line lock is a bit strange Nicolas, my pedal felt exactly the same after installing it, nice and firm.
January 20, 2009, 21:16:22 pm »
Quote from: JS on January 20, 2009, 21:08:51 pm
it could be that the setup on the drums was not correct. but i can't tell for sure as i changed the pads at the rear at the same time i too out the linelock... so i am allready thing off refitting it, and hopefully you are right.
thanks
Hotrodvw
January 20, 2009, 21:18:19 pm »
Theoretically your pedal should still be firm obviously. That's weird.
Hose & Fittings
'67 Sunroof
January 20, 2009, 21:24:51 pm »
Quote from: Hotrodvw on January 20, 2009, 21:18:19 pm
it should be indeed the same...
so here is a link to the post i did when i had the problem, hope it can help out others as well.
http://cal-look.no/lounge/index.php/topic,5178.0.html
January 27, 2009, 21:09:01 pm »
UPDATE!
My Hurst switch (supplied in kit) was faulty. We replaced it with another switch and we now get a reassuring clunk of the solenoid
Hotrodvw
January 27, 2009, 21:14:48 pm »
Oh sweet! Something so simple can cause such a head ache.
Hose & Fittings
'67 Sunroof
