October 14, 2026, 22:20:55 pm
| | |-+  091 gearbox
Author Topic: 091 gearbox  (Read 8329 times)
airstuff
« on: January 13, 2009, 20:48:08 pm »
How tuff are the bus boxes when they are in stock form,how much HP and abuse can they handle stock as they are?
When looking for a 091 gearbox,which year buses should I look at.From 75-79?or something like this
Does anyone have 091 gearbox code list,and distinctive feautures?
 Thanks  Grin
Really would like to learn something about this boxes  Smiley
« Last Edit: January 13, 2009, 21:24:31 pm by cal-look » Logged
flatfire
« Reply #1 on: January 13, 2009, 23:41:19 pm »
Looks like you are looking for the right years. Also an early aircooled type 25 box.
I know a guy who runs regular low 11s with a stock type 2 box with type 25 diff. The motor is a Subaru Sad
I'm in the process of having a beefed/different ratios up type 2 box built. If I can help with info feel free to mail me.
airstuff
« Reply #2 on: January 14, 2009, 09:50:52 am »
I have found this  Bugpack kit with axles
http://www.vwparts.net/mm5/merchant.mvc?Screen=PROD&Product_Code=BP6539&Store_Code=VWP&search=bus+trans&offset=20&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=
How driveable are this transmissions for a street car with the gear rations they comw with?
Prowagen
« Reply #3 on: January 14, 2009, 10:45:54 am »
There is some good info on the net and all sorts of forums for this, check this thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=143138&postdays=0&postorder=asc&start=0
There are several types of 091 the early arcooled ones are usually best as they are nose cone shift (same as bug, but higher up the case)
Rob.
ESH
« Reply #4 on: January 14, 2009, 11:34:54 am »
Having seen 091s used with great success in a bunch of consistently quick cars I decided on an 091 from Cogbox; for the intended application I don't see there being a better box and for what they offer they're an extremely cost effective option.
 Smiley
Tony M
« Reply #5 on: January 14, 2009, 23:28:48 pm »
I use a 002 box - has the 5:37 R & P, stock gears - and i like the stock gearing for what i do with my car - Baja - running 31in tires in rear - but the gearing is still good - 74/75 gear box's have the 4:87 R & P - good box if you can find them - hard to get in nor cal.
