September 22, 2026, 13:06:26 pm
Power size pulleys
Topic: Power size pulleys (Read 8795 times)
airstuff
Power size pulleys
January 16, 2009, 22:19:37 pm »
When does one need a powersize pulley,how good or bad are they for driving on the street?(engine overheating etc...)
Do I need a power pulley If my engine is revving past 7000 rpm?
Last Edit: January 17, 2009, 11:44:14 am by cal-look
airstuff
Re: Power size pulleys
January 17, 2009, 11:44:42 am »
Who's running berg power size in the street?
January 17, 2009, 16:29:26 pm »
youīll be fine with the stock size. Smaller pulley means your fan will turn slower and this is something you donīt want. Maybe you can compensate the power pulley with using a Porsche 356 generator upper pulley (smaller then VW) to keep the ratio, but I didnīt do a math for this.
ian c
January 17, 2009, 18:13:42 pm »
i think the ratio is right with a 356 upper , but due to slip it doessnt matter
(o\ ! /o)
January 17, 2009, 20:57:27 pm »
Quote from: cal-look on January 16, 2009, 22:19:37 pm
When does one need a powersize pulley....
When the weather is cool enough to allow it.
ian c
January 17, 2009, 21:11:26 pm »
Quote from: Bruce on January 17, 2009, 20:57:27 pm
or when one wants to get in the "kaboom , bits falling off" thread
(o\ ! /o)
January 17, 2009, 22:26:58 pm »
I run one throughout the winter months, unless we have 85+F like we are now.
As long as my oil temperature stays under 200F under hard, continuous driving, I haven't seen any ill effects, and I look for them.
Kind of a odd hop up thing, as they really, on a big engine, only give a fractional boost in hp. I notice a little difference in the lower gears up over 4500. What's nice is that it's easy enough to swap if it does get hot out. Maybe 30 minutes?
JS
January 18, 2009, 20:54:59 pm »
I am very happy with switching to power pulley size. My oil temp would never go past 65-70 degrees celcius(150-160F), but on a really warm day in Norway(32c,90F) I got it up to about 100c(210F) after switching to the power pulley. We don't have California weather over here unfortunately...
The only drawback is that my 6v generator won't give much charge when the engine idles with the power pulley. I have to check out the 356 pulley, never thought they were smaller.
Signature.
January 18, 2009, 21:09:28 pm »
Quote from: Jim Ratto on January 17, 2009, 22:26:58 pm
how about the whole crank, flywheel, rods,... balance? i think it will effect the overall balance, especially if the engine revs over 5000 rpms that must have an influence on the bearings and case.
stealth67vw
January 18, 2009, 21:15:27 pm »
I have run a power pulley year round for 3 years of daily driving from 15F to 115F and have no discernible problems. It does get a little warm when it's 115 out, oil gets to 205 and heads get to 300 on the freeway. I live in a very mountainous area with lots of grades too. The engine is a sweep the floor 1641cc with ratio rockers, stock heads, 8:1 compression, stock cam, 1 5/8 Berg header and dual Solex PBICs and a POS Empi 36hp shroud.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
benssp
www.callookvw.com
January 18, 2009, 21:21:34 pm »
I ran a power pulley on my 1776 - FK10, 1.54 Rockers, 9.5:1 compression, was fine in traffic, went to power pulley as standard size liked to flip the belt at 6.5K
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
January 18, 2009, 21:31:55 pm »
Quote from: JS on January 18, 2009, 20:54:59 pm
.... I have to check out the 356 pulley, never thought they were smaller.
Stop! Using a 356 pulley with a power pulley is dumb. It gets you the same fan speed as you'd get with all stock VW pulleys.
Quote from: benssp on January 18, 2009, 21:21:34 pm
... went to power pulley as standard size liked to flip the belt at 6.5K ....
Cheap belts do that. Get Gates.
drgouk
January 19, 2009, 05:55:02 am »
Whats the Dia of a 356 pulley? I was thinking of using one with a dry sump pulley, So I can use an autocraft pump.
rick m
January 19, 2009, 08:25:26 am »
DrGouk,
I ran an autocraft pump on my off-road car with the Powerpulley and a 356 alternator pulley. It worked great. It was a 2110cc motor with a blow through turbo set up on it. It ran cool and I never had overheating issues...even here in Arizona. Take it from those who have done it.
Don Bulitta saw my car and took a ride in it. It was a legitimate high 12 second motor. My 67 bug would run 13.90's and the off road car would kick its behind.
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
drgouk
January 19, 2009, 09:08:44 am »
Quote from: rick m on January 19, 2009, 08:25:26 am
DrGouk,
Rick Mortensen
Thanks for the seat of the pants info Rick.
David Gouk
