May 22, 2026, 03:10:16 am
Latest Member: mvptkfjb
| | |-+  Type 3 Brakes
Author Topic: Type 3 Brakes  (Read 5606 times)
Chris W
« on: January 21, 2009, 00:05:07 am »
Can anyone tell me what late type 3 drums should measure after being cut down for use on a Type 1?
« Reply #1 on: January 21, 2009, 00:43:55 am »
Take .550" off the snout to work on a short spline Wink
Chris W
« Reply #2 on: January 21, 2009, 00:47:07 am »
Yep got that. I need to know if the stock un-machined hight is about 2.5 inches?
deano
« Reply #3 on: January 21, 2009, 01:48:50 am »
Once you trim the nose on your T-3 drums, before you leave the lathe area, test your axles and jamb nut in your machined drum to check the location of the cotter pin hole, and the nut. I had to trim another .080 to get the cotter pin hole right where it needed to be. Otherwise, the depth of the hole in relation to the axle nut may not be in exactly the right spot (too shallow).
Anglia Obsolete Guru
'67 Heaven
« Reply #4 on: January 21, 2009, 10:38:04 am »
measured from where to where? i could measure it as i have type3 drums at home and on the car. i think i even have machined down centers.
i will look for them and measure them both.
Chris W
« Reply #5 on: January 21, 2009, 17:27:20 pm »
I got the measurement I was looking for. thanks for the help.
