September 23, 2026, 01:40:52 am
porsche 356b rear drum help needed please...
Topic: porsche 356b rear drum help needed please... (Read 6923 times)
jick
January 22, 2009, 19:13:52 pm »
so i've got the rear end all together on the '59 but when i tighten the rear hub nut the drum tightens up too and wont turn....i'm sure i've read somewhere about needing a spacer......does anyone have any direct experience of this? whats the deal?
also the outer ends on my short axles sit just shy of the outer face of the hub nut......do i need to machine the outer snout part of the drum....about 8mm?
thanks for any assistance!
jick
www.custommotorbodies.co.uk
Re: porsche 356b rear drum help needed please...
January 22, 2009, 20:01:19 pm »
What bearing retainer are you using. Is it like those on ovals with the bearing open? If you use the bearing retainer from the later cars then the drum will come in contact with the retainer and not turn. I had that issue on my '66 and had to replace mine with oval bearing retainers. I don't know if the '59 is the same as the earlier ones or not, but that is a place to look.
jick
January 22, 2009, 21:06:29 pm »
the retainers are from a '64...i thought that was what i needed.....the bearing isn't open ...it's covered...it feels like the drum is in contact with it.
i'm not familiar with the oval type with the bearing open....i'll look into that thanks Donny.
cheers....jick
January 22, 2009, 22:06:54 pm »
Here's what you are looking for. If you can't find any let me know. These are extras.
January 23, 2009, 01:51:04 am »
The bearing retainers you need came on split case transaxles.
January 23, 2009, 05:08:50 am »
And you might have to cut those down too.
Porsches use a spacer washer between the nut and the drum. 4mm thick, I think.
Here's a pic of a stock 58 Speedster:
jick
January 23, 2009, 12:24:37 pm »
perfect....great information....thanks everyone!
Donny, can i let you know about those retainers in a few days...i'd just like to see if i can pick some up locally first....although i dont hold out much hope!
thanks again.....jick.
January 23, 2009, 14:18:50 pm »
Quote
Not a problem. They are not going anywhere.
