October 14, 2026, 14:32:23 pm
| |-+  For sale!
| | |-+  2442cc T1 turbo race engine.
Author Topic: 2442cc T1 turbo race engine.  (Read 6876 times)
Jim Smith
« on: January 28, 2009, 21:46:13 pm »
Type 1 2442cc turbo race engine.
Nothing but the best parts used, please see below for a full spec list. Thanks for looking.
Case:  Scat “killer” 4 piece with wet sump. 10 mm head studs with 2 extra 8mm per cylinder.
Crank:  Scat 88mm flanged.
Rods:  5.7” Pauter chrome-moly
Pistons:  Wiseco 94mm.
Heads:  Autocraft 910 s. K motion K800 springs
Valves:  Del west titanium
Turbo:  Garret T4.
Wastegate:  Turbosmart 48mm.
Manifold:  Custom made stainless steel, fully polished, with samco hose.
Exhaust:  Custom 2” stainless steel, fully polished.
Cam:  Autocraft.
Carb:  Holley 850cfm double pumper
Followers:  Scat, fully crack tested before fitting.
Rockers:  Autocraft shafts with Pauter roller tip rockers, 1.4:1
Push rods:  Tapered Autocraft, with autocraft tubes.
Barrels:  94mm Autocraft.
Crank pulley: Fisher harmonic balancer with crank trigger.
Distributor: One off custom made billet.
The engine has only 7 dyno pulls since a full freshen up with new bearings through out. On the rolling road the motor produced 333bhp at the wheels, the motor was set very very soft only running on 108 octane unleaded, with only 18lbs of boost. Put race fuel in it turn the boost up [was built with the intension of running between 25 and 30 lbs] play with the timing and you will get loads more power.
Check out the pics, but please note the coil and clutch are not included!
Priced to sell at £6500.00      Tel 01242 232084 or mail sales@cotsweld.co.uk
www.cotsweld.co.uk      Race car fab   01242 232084
Martin Greaves
10.88@128.58
« Reply #1 on: January 28, 2009, 22:17:04 pm »
Dam good price. Smiley
Joe_G
« Reply #2 on: January 29, 2009, 10:50:32 am »
Be good in the NSU!!! Smiley
kev d
« Reply #3 on: January 29, 2009, 13:32:20 pm »
even better in my oval.. Wink
Martin Greaves
10.88@128.58
« Reply #4 on: January 29, 2009, 18:33:45 pm »
Do it you know you want to. Grin
Jim Smith
« Reply #5 on: January 30, 2009, 19:26:08 pm »
Sale pending.
Jim Smith
« Reply #6 on: February 05, 2009, 09:24:22 am »
Still for sales due to being totally F*$ked about by a time waisting wannabe!!!!!! Embarrassed Embarrassed Embarrassed
