August 13, 2026, 01:15:35 am
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  Glass ball needle valve problems
Author Topic: Glass ball needle valve problems  (Read 4449 times)
Elnef
« on: January 30, 2009, 21:43:38 pm »
For some month ago I bought a set of 61mm terminators for my 3L type4
http://cal-look.no/lounge/index.php/topic,3960.0.html
But like others I have problems with the 3,5mm glass ball one is working and the other is crap  Sad
then I tested the  spare set for my old 51,3mm also crap  Sad
But my 13years old Berg steel ball 3mm from the 51,3mm is stil working fine  Smiley but is 3mm fine for lets say 300hp with a fuel preasure on 0,25 bar / 3,5psi ??
Or do I have to buy a lot of 3,5mm to get one working set ??
John
« Last Edit: January 30, 2009, 22:04:34 pm by Elnef » Logged
Steve D.
« Reply #1 on: January 31, 2009, 04:22:44 am »
My experience shows that glass balls are a pain in the ass at best.  Stick with genuine weber 3.0 needle & seats, start with 3.5psi, and with the motor running run the fuel psi up until the carbs start to bleed over and it won't idle clean anymore.  Back it off a hair and lock it down.  The benefit you have with Terminators is that you have a giant float bowl to work with.
For me, the glass balls were a weeks worth of wasted time.
Über Alles
10.77 avg. on pump fuel.
238I
Sam K
« Reply #2 on: January 31, 2009, 06:18:54 am »
I had a similar problem with glass ball needle and seats in my IDA's last summer. The originals seem to work just fine.
« Reply #3 on: January 31, 2009, 13:11:44 pm »
John
You must buy some more and hope you find 2 that work . :-( , that's it
