October 13, 2026, 15:26:41 pm
| | |-+  My valvetrain-Lash caps
Author Topic: My valvetrain-Lash caps  (Read 13245 times)
airstuff
« on: February 04, 2009, 13:14:36 pm »
My CB lashcaps that came with the rockers are loose on the valve stem end of my new heads,I mean tottaly loose,when I rotate head they fall off
Is there any other brand of lash caps that would fit snug?
« Last Edit: February 04, 2009, 15:35:29 pm by cal-look » Logged
Airspeed
« Reply #1 on: February 04, 2009, 13:28:51 pm »
Good question. I have a set of new Bugpack ones, but they seem to fit not really snug either. Your CB's are 8mm as well?
airstuff
« Reply #2 on: February 04, 2009, 13:44:00 pm »
Yes,they are 8mm
They are this item:
http://www.cbperformance.com/catalog.asp?ProductID=86
They are loose on the valves of my Steve Tims stage 2's
airstuff
« Reply #3 on: February 04, 2009, 15:38:31 pm »
This is the stroker clearenced camshaft thas is going into my motor.
I just wanted to be sure,and to ask you guys here,does this look to thin,or is it Okay that it is turned so much on hte lathe.I mean with Bugpack 4047 dual springs set up for high lift,is there a chance for it to break?
This lathe turned camshaft is 16mm in the thinnest part,while an untouched cam looks like 21mm in the same area
« Last Edit: February 04, 2009, 16:06:29 pm by cal-look » Logged
« Reply #4 on: February 04, 2009, 20:42:59 pm »
Hi
What crank do you have ? Normaly 20 mm is enough to clearance all crank sizes .
udo
airstuff
« Reply #5 on: February 04, 2009, 21:45:02 pm »
Hello Udo,I have an 82 crank with 5.4 I-beam rods
Do you think the camshaft is too weak,or should it be enough meat in order not to break.
Roman
« Reply #6 on: February 04, 2009, 22:12:48 pm »
I have had a set where 4 were OK and 4 were junk and far too sloppy. I made my own, it was a hell of a work...
BTW are you sure you have 8 mm valves? 5/16" is VERY close (7.94 mm) and also very common.
airstuff
« Reply #7 on: February 04, 2009, 22:44:55 pm »
Yes,I measured the stems,they are 8mm.
dangerous
« Reply #8 on: February 04, 2009, 23:13:16 pm »
Try bergs, they have a few different sized lash caps.
Or any of the major Valvetrain companies may hae ones to suit 5/16" stems.
I would not use that cam.
If it were not cast iron it may be OK.(ie steel billet)
I like to clearance the rod in that area, and only minimal cam clearancing.
If more is needed then flats ground in timed positions would be the prefered way.
stealth67vw
« Reply #9 on: February 05, 2009, 01:46:29 am »
My CB lash caps fit snug but not tight. Berg lash caps fit so tight you need a puller to remove them.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
besserwisser
« Reply #10 on: February 05, 2009, 08:16:09 am »
If you take a close look at an original camshaft you will find a 45degree on the lobe edges. The factory wouldnt put it there if it didnt have a purpose. When your lifters and camshaft are flat those sharp edges will chew up your lifters in no time. Personally it seems to me that there is a little too much taken of that camshaft.
« Reply #11 on: February 05, 2009, 12:45:03 pm »
Same as i think , 16 mm is a little too small . don't  know but it can break with double springs
« Reply #12 on: February 05, 2009, 16:16:37 pm »
I clearanced my cam on a lathe to 20 mm dia. in critical places. I made a nice radius on the end of lathe trace and I polished those places with a grinderīs stone. I have the same 82mm crank as you Zvonimir and H-Beams on the way so Iīll let you know if it clears when I mock it up..
« Reply #13 on: February 05, 2009, 16:56:04 pm »
if you buy an Engle cam from Roger @ Heads Up, they come with radiused lobe edges. Good Point (no pun intended).
dirk zeyen
« Reply #14 on: February 05, 2009, 19:54:48 pm »
hello,
if i use stock or 1/1.25 ratio rockers with porsche swivel-feet adjusting screws must i have lash caps?
in an old gene berg catalog he said about his swivel feet: no need for lash caps when you use these.
dirk zeyen
back again!!!
Ohio Tom (DdK)
« Reply #15 on: February 07, 2009, 21:03:36 pm »
With any kind of swivel or roller tip rocker,you don't need lashcaps.
Personally, I hate lash caps.
Yes, sometimes they are required, but if not then I say don't run them.
they are problematic. They break, fall off, don't sit flat. The quality is all over the place depending on who you buy from.
I'd just rather not use them. Most valve's are just as tough as the lashcap so you really arn't saving anything buy running them...
Ohio Tom
08'.. 3 R/U...3 Win...
« Reply #16 on: February 08, 2009, 07:14:30 am »
and they add weight
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #17 on: February 08, 2009, 18:59:15 pm »
  Looks like the cam is too small to me too. You can get clearanced cams straight from engle. I think you might not even need a clearanced cam with the 82.
dirk zeyen
« Reply #18 on: February 08, 2009, 21:35:12 pm »
thank's for information!
dirk zeyen
back again!!!
« Reply #19 on: February 09, 2009, 17:26:13 pm »
depends on journal and type of rod. I Built a few VW -journal 82mm lumps that had to have special smaller base circle and clearanced cams dropped in. Who would have thought?
