October 13, 2026, 08:54:56 am
| | |-+  STRAIGHT CUT GEARS......
Author Topic: STRAIGHT CUT GEARS......  (Read 7181 times)
SPEEDWELL66
VW DRAG RACING.....MEXICAN STYLE!!
« on: February 10, 2009, 04:22:45 am »
HI BRO'S
I WANT TO KNOW IF THIS TYPE OF GEARS REALLY INCREASE POWER TO THE ENGINES, OR GIVE SOME HELP TO THE CRANK OR WHATEVER  Huh
THE REASON IS THAT I LIKE A LOT THE SOUND THAT THIS GEARS MAKE, BUT ONE OF MI FRIENDS SAYS THAT, STRAIGHT CUT GEARS ARE A WASTE OF MONEY  Undecided
THANKS!
WWW.VOLKSSTYLE.COM
« Reply #1 on: February 10, 2009, 04:38:04 am »
Straight cut gears eliminate the axial thrust that helical gears cause.  The axial thrust increases with spring tension.  If you have BB Chevy springs, or stiff K800s, you pretty much must use straight cuts since the stock thrust bearing (doubled) probably won't withstand the stress.  However, if you are using VW sized duals or less, you don't need straight cut gears.
As for the hp difference, you probably couldn't measure the difference on any dyno, it is very slight.
If you like the sound, get them.  If money is tight, spend your money on the heads, where you'll actually make more power.
pughdog
www.Jagerbug.com
« Reply #2 on: February 10, 2009, 09:23:35 am »
They do sound nice though.....  Grin
<a href="http://www.youtube.com/v/tQKy7jUp6AM" target="_blank">http://www.youtube.com/v/tQKy7jUp6AM</a>
Eric Justus
« Reply #3 on: February 11, 2009, 03:28:08 am »
Someone please post a vid of Russ Hare's straight cut gears he had in the Sloval. Now those things sounded the cooooolest Cool
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
stealth67vw
« Reply #4 on: February 11, 2009, 03:54:49 am »
Hear you go.
<a href="http://www.youtube.com/v/pZzfZ0Wxvbo" target="_blank">http://www.youtube.com/v/pZzfZ0Wxvbo</a>
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
pughdog
www.Jagerbug.com
« Reply #5 on: February 11, 2009, 17:10:08 pm »
 Cool wow!
Look at those front tyres!
SPEEDWELL66
« Reply #6 on: February 12, 2009, 06:25:17 am »
THANKS BRUCE, I REALLY APRECIATE YOUR COMENTS
JOSE LUIS
WWW.VOLKSSTYLE.COM
Bewitched666
Bewitched
« Reply #7 on: February 12, 2009, 08:17:37 am »
HP increase is next to none almost Cool
Fast vw beetle's rule
SPEEDWELL66
« Reply #8 on: February 15, 2009, 20:41:34 pm »
CONTINUING WHIT THE TOPIC, WHAT ABOUT THE STRAIGHT CUT GEARS FROM "AA" THE ONES MADE OF CROMOLY.
THIS ONES:
GOOD, REGULAR, BAD.............LET ME KNOW BRO'S!
JOSE LUIS
WWW.VOLKSSTYLE.COM
