September 22, 2026, 16:18:30 pm
| | |-+  installing double valve springs in 043's
Author Topic: installing double valve springs in 043's  (Read 5294 times)
FDK/mrpedrini
« on: February 14, 2009, 19:09:38 pm »
Hey guy's, need some technical advice here.
I want to mill the valve guides of my 043 vw heads, to instal some double Berg (273 a) springs. I need to know to what size the guides have to be to clear the springs. I did some measurements and i think it would be 15 milimeters, is this correct?
cheers, Dennis....
« Reply #1 on: February 15, 2009, 17:48:25 pm »
I think you mean the guide boss ? Cut it only to 17 - 17,5mm . Most cut them too much and you get problems when changing guides .
FDK/mrpedrini
« Reply #2 on: February 15, 2009, 19:28:23 pm »
Jep, guide boss is the correct discription!!! Thanks Udo for giving this info Cool
besserwisser
« Reply #3 on: February 19, 2009, 07:55:52 am »
When I repair guides in heads machined for dual springs I use K-line liners. Its a sleeve inside the valve guide that actualy holds upp better than the original guide.
