October 13, 2026, 07:18:09 am
| | |-+  counterweights or balanced stock
Author Topic: counterweights or balanced stock  (Read 12325 times)
« on: February 21, 2009, 15:38:16 pm »
for a relatively low budget project i'm weighing the alternatives of purchasing a new CB Performance 69mm c/w crank or a new stock 69mm crank, which is (obviously)cheaper as i've got my eye on one. the remainder of the money would then be spend on balancing the pulley, crank, flywheel and pressure plate, which we will not be doing in the case of the new crank, cos it is rather low budget.
the engine we're dealing with is a hot 1600 single port engine in a line-bored mexico case.
i'm not sure about which of the 2 (counterweights or a balanced bottom end) would work out best, the only pro of buying a c/w crank would be to retain it when upgrading to a larger bore at a later stage.
please let us know your thoughts.  Smiley
« Reply #1 on: February 21, 2009, 16:06:52 pm »
If you are not going to rev it above 5500 then you won't need counter weights. I would spend the money on a good balance job.
« Reply #2 on: February 21, 2009, 17:39:57 pm »
cam will be 242º @ 0.50 with 0.420" lift and for now the heads are stock 1600 s/p. so it won't be that much of a high revving engine.
« Reply #3 on: February 21, 2009, 17:51:31 pm »
CW.
« Reply #4 on: February 21, 2009, 18:11:39 pm »
I think you will use a vz14. I'm building the same engine and I use a stock balanced cranck with a taiwan damper pulley. I follow the advices of the guy I buy parts.
He says that taiwan pulley on a balanced crank with a stock weight flywheel is a good combo for a mild street engine and will give a good reliablity.
Doktor
« Reply #5 on: February 21, 2009, 22:09:34 pm »
I've heard something similar few days ago on the Samba from a guy under nick SRP1 - he wrote that he builds engines for off-road racing based on a ballanced stock crang (non C/w) without lighthening a flywheel and in combination with equalizer pulley...and no negative effect on the bottom end or the case. Engines are revved more than 5500 rpm frequently !
He was mentioning that Gene Berg did the same thing years ago...
My plan is to build 1776ccm with Webcam 163 (between Engle 110 and 120) with ballanced stock internals and Equalizer pulley or even with Engle 120 - I'm not sure 100% !
dr.aircooled
Sander/DVK
« Reply #6 on: February 22, 2009, 01:42:58 am »
Go for the 82 DPR  Wink
Dougy Dee
« Reply #7 on: February 22, 2009, 05:29:56 am »
Aren't the new stock cranks cast? Huh
« Reply #8 on: February 22, 2009, 06:41:28 am »
yep
« Reply #9 on: February 22, 2009, 11:34:17 am »
Yes, I don't mention that but he says me to use an old one. Stock new are just enough for a stock use...
tikimadness
« Reply #10 on: February 22, 2009, 11:42:51 am »
I would go for an old stock non counterweight crank
Michael
NIDGAFWYT
Jesse/DVK
'64 2176cc
« Reply #11 on: February 23, 2009, 10:57:05 am »
I have a stock old one lying around with stock 180mm flywheel. Donnow how good it is but for a small fee it's yours Tongue
« Last Edit: February 23, 2009, 11:02:32 am by Jesse/DVK » Logged
« Reply #12 on: February 23, 2009, 14:12:11 pm »
i've got two myself, but a grind and polish will set me back 260 euro's. a CB crank is 250 and a full balance job is 180.
hence, this topic. i'm trying to weigh the alternatives...
Jesse/DVK
'64 2176cc
« Reply #13 on: February 23, 2009, 15:02:06 pm »
I would go for a DPR than.. 85 bucks for a stock one.
« Reply #14 on: February 23, 2009, 17:09:09 pm »
"counterweights or a balanced bottom end"
BOTH!
Sander/DVK
« Reply #15 on: February 23, 2009, 17:35:22 pm »
An rebuild stock crank cost you 140 euro's by Ahnendorp, when you change it with your old crank.
But why not a stroker engine? You have beautiful heads and good set of carbs. Go for it!
« Reply #16 on: February 23, 2009, 17:44:32 pm »
this is not for myself sander, i've got all my parts sorted  Smiley
besides i should be able to haul some ass with my stock stroker  Cheesy Wink
this is for my brother, what started out as a sweep the floor engine plan is now changing with new parts. but he's spending a lot of money on a sprayover so i don't want to take it too far in terms of $$. gotta disappoint you there, lee. though you're right of course.
it's only a 1600 in the end. i'll take a look at ahnendorp then.
« Last Edit: February 23, 2009, 17:46:56 pm by 67-indeed/DVK » Logged
« Reply #17 on: February 23, 2009, 17:56:16 pm »
1. first choice: Rimco 69mm c/w orig VW crank
2. second choice: stock 1600 x drilled orig VW crank (don't use a 6V crank if you're using a 12V o-ring type flywheel)
don't use a new stock replacement crank
(aftermarket)
have you looked on Samba for a used CW like yours?
« Reply #18 on: February 23, 2009, 18:00:42 pm »
i've got the crank from my 1300 s/p engine and from a 1600 d/p engine. but both could probably need a regrind.
he'll be using my old 180mm flywheel for now, as it's been lightenend and i've got a low mileage clutch and p/p to go with it.
copy that.
and will have a go there too.
bugkeeper
oldskool n numetal
« Reply #19 on: February 24, 2009, 23:48:02 pm »
A good old german forged original 69mm crank wil do just fine. Far better than any cheap chinese cast "counterweight" crank.
I used one in a 1915cc engine and it would rev up to 6500 rpm with no problem. Just get it balanced and use an equalizer pulley.
The main advantage of a good counterweight crank is it saves your main bearing saddles in the case. I guess it depends on how many miles you plan to put on that engine. German forged better than any cast crank. Else go with a DPR crank. Good crank for the money. Also check out AJ. Sims at low bugget.
If you think sex is a pain in the ass, try a diffrent position...
Beauty is only skin deep, and the world is full of thin skinned people.
« Reply #20 on: February 24, 2009, 23:49:41 pm »
the problem is that i'm guessing my crank needs a grind and that very pricey over here...
