November 03, 2026, 05:31:30 am
| | |-+  Stainless Steel fuel line for 2276 with IDA : opinions / ideas ?
Author Topic: Stainless Steel fuel line for 2276 with IDA : opinions / ideas ?  (Read 9252 times)
guillaume
« on: February 23, 2009, 23:13:30 pm »
Hello,
I am planning to build a rigid stainless steel fuel line for my engine. It is a 2276 with weber IDA and DDS short manifolds.
I've never done a stainless steel fuel line before, and never for that kind of engine.
What would be the ideal tube diameter in millimeters ? I often read 8 millimeters for the fuel line instead of the stock one. Is it the inside or outside diameter ?
I plan to make a fuel line like this model (see picture). The 2 rounds are loops to prevent from vibrations (like a hard spring). Do you think the loops are usefull or can I make a straight line? The fitting will be early AN still. But what is the best size? What kind of banjos do you recommend ?
Thanks for your help. I will really appreciate it. If someone already do it, don't hesitate to post photos  Smiley
67worshipper
« Reply #1 on: February 23, 2009, 23:20:09 pm »
i,ll try and get a better pic when the car comes back from the paint shop guillaume
vw hot rod heaven
« Reply #2 on: February 23, 2009, 23:36:39 pm »
paintshop?
cool idea, but there were some thoughts on expansion of a hard line in another topic some time ago.
guillaume
« Reply #3 on: February 23, 2009, 23:37:03 pm »
Thanks a lot for your answer. If you have some details and dimensions, I will really appreciate it. The line looks good  Cool
67worshipper
« Reply #4 on: February 24, 2009, 00:07:50 am »
paintshop?
just getting the front wings done because of pickling and a crack in the paint on the front quarter panel Wink should be mint again then for a while Smiley
vw hot rod heaven
guillaume
« Reply #5 on: February 25, 2009, 12:10:04 pm »
Anyone else has some info ?
« Reply #6 on: February 25, 2009, 14:42:17 pm »
like i said, use the search function. i haven't got time right now, but there was a topic on this 2months ago or so.
use "hard line"
guillaume
« Reply #7 on: February 25, 2009, 15:03:18 pm »
Yes, I already search and read the post a few days ago.
But their is no tech info like diameter, AN fitting sizes etc etc and I really need them. Any help ?
« Reply #8 on: February 25, 2009, 17:14:22 pm »
Eric (HotrodVW) is the man you're looking for, he does this for a living.
Try sending him a PM, perhaps?
« Reply #9 on: February 26, 2009, 03:32:44 am »
What size is your inlet valve in the carb?  2.5mm?  If so, a tube with 5mm ID or larger would be more than enough.
