September 23, 2026, 21:25:25 pm
| | |-+  Fitting Type1 wide 5 Drums onto an IRS setup
Author Topic: Fitting Type1 wide 5 Drums onto an IRS setup  (Read 6977 times)
71CALRIPPER
« on: February 25, 2009, 16:50:53 pm »
Ok i cant use the Type3 drums so what do i need to do to a stock wide 5 drum?
Machine 7 do a conversion , but to me it just looks like a small amount of machine work ?
http://www.machine7.com/product.php?xProd=1623&xSec=2283
If anybody knows the measurements i will buy a stock setup and just get the machine work done.
Thank you
Rob
71CALRIPPER
« Reply #1 on: February 25, 2009, 17:05:38 pm »
And if anybody just thinks i should buy the ones offered just tell me Smiley
stealth67vw
« Reply #2 on: February 25, 2009, 17:09:04 pm »
I'm pretty sure for the rear you can just use a standard T1 5 lug drum and early shoes and use a spacer between the drum and axle nut. For the front, it is almost the same except no spacer.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
benssp
www.callookvw.com
« Reply #3 on: February 25, 2009, 17:29:50 pm »
those drums are stock 55-63 split bug ones which have been machined down Grin
www.vwheritage.com  My Job
YMCA
71CALRIPPER
« Reply #4 on: February 25, 2009, 17:34:45 pm »
Ok after speaking to deano from DeanoVWs i can use a stock setup and just run a spacer Smiley
tikimadness
« Reply #5 on: February 25, 2009, 19:10:02 pm »
I have a complete wide 5 rear set up lying here I bought everything new last year but I changed to discs.
Used for about 10 miles.
If you are interested pm me .
Michael
NIDGAFWYT
von-dart
« Reply #6 on: February 25, 2009, 20:51:59 pm »
Thank you
Rob
hey Rob,
the drums in the machine 7 link are the same size as standard 4-stud drums,i.e. wider than stock wide 5 brake shoes by about 10mm.
they only need machining down if your axles are shorter,speak to Michael Leche if you need advice,he's very helpful.
all the best,
gary.
