July 01, 2026, 20:19:23 pm
Latest Member: bigsiembowski
| | |-+  Brake Fluid & Trans Fluid
Author Topic: Brake Fluid & Trans Fluid  (Read 6046 times)
SteveW
« on: February 27, 2009, 08:59:30 am »
I'm going to fill up the brake system in the next day or so with fluid, I'm guessing I should run DOT 5.1 ? How much fluid will I need to fill the system from scratch?!
Also what trans fluid are you guys using?
Steve
« Last Edit: February 27, 2009, 09:08:21 am by SteveW » Logged
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
Joe_G
« Reply #1 on: February 27, 2009, 09:32:21 am »
Steve, you could try using this for your brakes  http://www.frost.co.uk/item_Detail.asp?productID=8658&frostProductName=Silicone+Fluid+%281+litre%29&catID=14&subCatID=&FrostCat=Brakes&FrostSubcat= it doesn't harm your paint and doesn't need changing.
SteveW
« Reply #2 on: February 27, 2009, 09:52:04 am »
Cool that looks good, so that's DOT 5 which is silicone based then. This fluid's boiling point is 260°C, i'm guessing that would be ok for drag racing as we're not on the brakes for long periods..
Steve
1970 Stock Beetle.
SteveW
« Reply #3 on: February 27, 2009, 10:06:40 am »
Hold on a minute.....I might have just twigged Joe Roll Eyes Grin Grin
Steve
1970 Stock Beetle.
Joe_G
« Reply #4 on: February 27, 2009, 11:31:49 am »
lol, i hadn't thought of it that way!! hope it's all getting sorted?
Bernard Newbury
9.50 @ 141 MPH
« Reply #5 on: February 27, 2009, 19:20:29 pm »
What Joe said about the brake fluid. Been using it for a few years ,no problem
Steve
I use a regular 75-90 semi synthetic, again no problem. Bernie
SteveW
« Reply #6 on: February 28, 2009, 00:03:38 am »
Joe, it's getting there, just sorting out the 'other details' now
I spoke to Chris Isaacs today who has manuals on the Strange brakes and it recommends to only use DOT 4 or DOT 5.1 but only of a glycol base not silicone. Because of the silicone based fluid not absorbing moisture, if any does get in the system then it sits on the calipers and damages them (I can't remember the exact wording it uses but its basically that..)
I just picked up some ordinary synthetic DOT 4 so I'll try that.
Steve
Steve
1970 Stock Beetle.
« Reply #7 on: February 28, 2009, 09:34:45 am »
. Because of the silicone based fluid not absorbing moisture, if any does get in the system then it sits on the calipers and damages them .....
That's the rhetoric the deniers always state.  Since silicone juice doesn't absorb water from the air, it won't be in the calipers to corrode them.
15+ years of the same silicone juice in my brake system.  No problems at all, and it rains a LOT here.
For a drag car that gets driven only in the dry, why would you worry about it?
« Reply #8 on: February 28, 2009, 23:21:05 pm »
75W90 Full Synth Kendall for the Tranny. Mercedes Brake fluid every year for brakes, because it's "available".
SteveW
« Reply #9 on: February 28, 2009, 23:42:59 pm »
Because I don't have 15+ years of experience to go back on!! It rains a hell of a lot here too (and especially when your at the racetrack!) so I thought DOT 4 would be fine.
Thanks for the advice everyone Smiley
Steve
1970 Stock Beetle.
