September 22, 2026, 06:04:04 am
| | |-+  ****Best Stacks For IDA 48***
Author Topic: ****Best Stacks For IDA 48***  (Read 15785 times)
beetlemic
« on: March 02, 2009, 17:08:57 pm »
We got a thread about IDA stacks but nothing for the Weber 48 IDA.
First to find the right stack wich one to choose?
 I now Jaycee makes nice looking ones but how good are they?
Also find it difficult to find  aircleaners.
What do you guys  recomend?
Here's a pic of my old stacks:
« Reply #1 on: March 03, 2009, 03:16:10 am »
eugene
« Reply #2 on: March 03, 2009, 10:24:51 am »
This scan is coming from STF right? I posted it. Wink It's from the book Tuning the A-series engine by David Vizard ( minis and such). It has extensive chapters about carbs also. Even little about IDAs. Vizard also tested flow trough various carbs:
WEBER 40DCOE (36mm venturi) = 175cfm
DELLORTO 40DRLA (36mm venturi) = 182 cfm
WEBER 45DCOE (38mm venturi) = 242
DELLORTO 45 DRLA (38mm) =254
DELLORTO 48DRLA (38mm)=283
WEBER 48IDA (38mmventuri) = 296
flow is per one barrel @21.3 inch of water depp.
Really great book. Very detailed information about carbs, manifold, head porting( with drawings and measurements!) bottom ends, oiling , ignition,...500 pages. Is not for mini enthusiast only.  I don't have one and have found lot of useful info in it.
« Last Edit: March 03, 2009, 14:14:19 pm by eugene » Logged
181
« Reply #3 on: March 03, 2009, 11:26:20 am »
I s there a reason why 48DRLA flow less then 45DRLA with the same venturi?
Jan
« Reply #4 on: March 03, 2009, 13:06:49 pm »
Wow, great post!!  Shocked Shocked
eugene
« Reply #5 on: March 03, 2009, 14:07:08 pm »
Jan
typing error. fixed Smiley
« Reply #6 on: March 03, 2009, 14:41:13 pm »
This doesn't look to promising for the stock stack of the IDA Sad
« Reply #7 on: March 03, 2009, 14:48:48 pm »
True... but the Jay Cee on the other hand..
« Reply #8 on: March 04, 2009, 05:22:46 am »
Could be.  I don't remember where I found it.
I wonder what #10 would flow like if it had a good 1/4" radius around the top of the stack?
Roman
« Reply #9 on: March 04, 2009, 20:27:47 pm »
Here is some more in depth information about stacks:
http://www.profblairandassociates.com/pdfs/RET_Bellmouth_Sept.pdf
