September 22, 2026, 21:23:53 pm
What kind of oilpump to use for a typ 4
Topic: What kind of oilpump to use for a typ 4 (Read 6629 times)
Eddie DVK
March 03, 2009, 07:35:12 am »
Hello,
If I want to replace my oilpump on mine typ4 engine which one do I use? a typ 1? if yes which one.
I don t want to reuse my old typ 4 one in my rebuild 2.0 engine.
Little info on the Engine is:
71 standard crank
94mm typ 1 pistons
316 BAS cam
Solid lifters
40mm webers.
Kind regards Edgar
Regards Edgar
Re: What kind of oilpump to use for a typ 4
March 03, 2009, 13:01:04 pm »
The original oil pump makes enough pressure , so if you have a good used it is ok . You can also take a type1 HD 26 mm early version - 68
udo
www.Udobeckertuning.de
Eddie DVK
March 03, 2009, 22:15:21 pm »
Thanks for the info.
Yep I know it makes enough pressure, but it looks worn, I am putting together a new
engine so don t want to use old pieces.
So I will look for a 26mm pump then, do I need a Oil pressure relief Pump cover?
Kind regards Edgar
Regards Edgar
March 03, 2009, 23:14:35 pm »
No , the type 4 engine has an oilsystem like full flow staight into the filter
Eddie DVK
March 04, 2009, 17:27:47 pm »
Thanks Udo,
I will look for a 26mm pump and normal cover.
Kind regards Edgar
Regards Edgar
