September 23, 2026, 19:12:57 pm
Shawn Geers Car
Topic: Shawn Geers Car (Read 35715 times)
UltraOrange67-2443
Re: Shawn Geers Car
Reply #30 on:
January 23, 2018, 22:40:07 pm »
Modified Autolinea case.
Start with no stud fixings and machine / weld it for a larger bore.
I have a 101.6mm case done this way.
1967 1200 2920cc EFI
stealth67vw
Re: Shawn Geers Car
Reply #31 on:
January 24, 2018, 17:02:39 pm »
The hotVWs article said mag case. Geers probably did the old Super Street cylinders where the case is bored to piston size and the cylinder sits on the case deck without protruding into tyhe case. It is kept in location by dowel pins. I believe JayCee was the first to do this to get a piston larger than 94 within the type 1 head stud pattern required by PRA S/S rules.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
bedjo78
Re: Shawn Geers Car
Reply #32 on:
January 26, 2018, 01:35:02 am »
I think this is easiest way to do. Bit steel require good machine shop
Quote from: UltraOrange67-2443 on January 23, 2018, 22:40:07 pm
bedjo78
Re: Shawn Geers Car
Reply #33 on:
January 26, 2018, 01:37:42 am »
Hi skill machining
Quote from: stealth67vw on January 24, 2018, 17:02:39 pm
