September 23, 2026, 19:10:42 pm
| | |-+  Shawn Geers Car
Pages: 1 [2] Print
Author Topic: Shawn Geers Car  (Read 35713 times)
UltraOrange67-2443
« Reply #30 on: January 23, 2018, 22:40:07 pm »
Modified Autolinea case.
Start with no stud fixings and machine / weld it for a larger bore.
I have a 101.6mm case done this way.
1967 1200 2920cc EFI
« Reply #31 on: January 24, 2018, 17:02:39 pm »
The hotVWs article said mag case. Geers probably did the old Super Street cylinders where the case is bored to piston size and the cylinder sits on the case deck without protruding into tyhe case. It is kept in location by dowel pins. I believe JayCee was the first to do this to get a piston larger than 94 within the type 1 head stud pattern required by PRA S/S rules.
bedjo78
« Reply #32 on: January 26, 2018, 01:35:02 am »
I think this is easiest way to do. Bit steel require good machine shop
bedjo78
« Reply #33 on: January 26, 2018, 01:37:42 am »
Hi skill machining
Pages: 1 [2] Print
