September 02, 2026, 00:23:26 am
| | |-+  My turbo...
Author Topic: My turbo...  (Read 9931 times)
Ohio Tom (DdK)
« on: March 11, 2009, 02:52:28 am »
Hey all. I finally got some smaller size photos of my car to post.
Ohio Tom
08'.. 3 R/U...3 Win...
Ohio Tom (DdK)
« Reply #1 on: March 11, 2009, 02:53:23 am »
and another
« Last Edit: March 11, 2009, 02:58:09 am by Ohio Tom (DdK) » Logged
Ohio Tom
Ohio Tom (DdK)
« Reply #2 on: March 11, 2009, 02:53:53 am »
2 more
Ohio Tom
Ohio Tom (DdK)
« Reply #3 on: March 11, 2009, 02:55:42 am »
1904cc. 110 cam, 40 x 35.5 mild ported heads.
T-3 turbo with 40mm side draft Dellorto.
Been together for 4yrs now.
Ohio Tom
Ohio Tom (DdK)
« Reply #4 on: March 11, 2009, 02:56:34 am »
Sportsbug seats re-done custom fabrics.
Ohio Tom
Wünderwolff
aka Dr. Jeckill
« Reply #5 on: March 11, 2009, 07:07:39 am »
I love the engine (car is nice as well  Wink). Exactly the size I was looking at lately: 1904, and also lately I have again started looking at Turbo's. It might not be true cal-look, but oh does it look mean.
My plan would be to build that 1904 now(I wnated the slight bump to a trusty 1776, but with the added value of a small stroker) and add the Turbo later on. So could you elaborate on your set-up?
Wünderwaffe are Go!
bugkeeper
oldskool n numetal
« Reply #6 on: March 11, 2009, 11:03:49 am »
Nice engine, do you have any performance figures or 1/4 mls time? What boost are you running?
I am running something similar, 1914cc, 40 x 35.5, 8:1, mild cam, piston coolers, T3 and a Holley 350 and a Mallory ignition with map sensor.
I have no performance figures yet, the images were taken last season and the engine was a slightly modified (dual valve spring) stock 1585cc engine. It delivered 121 HP with only 5 PSI of boost.
Cheers Dom
« Reply #7 on: March 11, 2009, 14:52:39 pm »
beautiful car Dominique,saw it last year @ DDD#6   Wink
b.t.w. love the dash lay-out   Grin
bugkeeper
oldskool n numetal
« Reply #8 on: March 11, 2009, 15:09:54 pm »
Thank you Peter, I wonder why you like that dash layout...  Roll Eyes
Ohio Tom (DdK)
« Reply #9 on: March 12, 2009, 03:07:12 am »
Nice Car Dom. Very similar theme... Well done..
My motor is a 1904cc
Scat 74mm volksracer crank (I got new real cheap).
Scat I-beam rods.
Straight cut cam gears
90.5mm mahle p/c's.
Mofoco 042 heads (got them super cheap too). Mild p/p job with exh guides cut back. 3 angle valve job.
W-110 cam with stock rockers on solid shafts.
T-3 turbo on Matt Davis header.
Side draft 40mm Dell with many turbo mods.
boost-ref Holley regulator with Carter 14psi fuel pump.
The car has run a best of 12.23 @ 112mph on 16psi.
it is very consistent. I have run 12.20's with it every summer for the last 4yrs.
I take it to the track once a summer to lay down a # and get my "100mph club" sticker.
It made 193RWHP on a chassis dyno. 230ftlbs of torque.
I have the means to build a bigger motor for the car, but I am afraid to change anything. I'm kind of wating for something to fail, but it just keeps running strong.
The only issue I seem to have is with my old "RAYJAY" wastegate.
Time to upgrade to a TAL.
It sure does catch people off guard...
The motor is super rugged. I have done nothing  but drive it and hammer on it for several years now.  and all I have to do is change oil and plugs.
you can see that the dist cap is getting faded from being outside so much.
Ask anyone who knows me. I drive this car ALOT.
Ohio Tom
bugkeeper
oldskool n numetal
« Reply #10 on: March 12, 2009, 20:43:53 pm »
Tom, at what RPM did you get those 193 hp? Impressive times. What Ignition setting are you running? Fixed and locked dizzy? Isn't a w110 too much cam?
Cheers Dom
Ohio Tom (DdK)
« Reply #11 on: March 13, 2009, 01:31:09 am »
The peak hp was around 4,500rpm. Peak tq was around 3,500rpm.
It pulls easliy to 6,000rpm.
it all depends on how much boost I run. The more I run, the higher it seems to pull.
Mallory HyFire box. Locked dist 32deg with 8deg of retard on boost.
Blue coild feeding a Unilite dist. No ingintion issues at all.
Rev limit to 6,000rpm for street driving and 6,600rpm for track use.
Ohio Tom
TOM / EINHEIT 11
« Reply #12 on: March 13, 2009, 21:04:39 pm »
SCHÖN, SCHÖN, SCHÖN  Grin
Cheers Dom
bugkeeper
oldskool n numetal
« Reply #13 on: March 13, 2009, 22:41:49 pm »
Hey Tom was meinsch.. e 12er Zyt söt dinne ligge, i muess eifach no 40 kg abspäcke!  Cry
Ohio Tom (DdK)
« Reply #14 on: March 14, 2009, 02:54:50 am »
I'm sorry. I didn't quite get that??
Ohio Tom
WCB Hitler's Hot Rod
« Reply #15 on: March 14, 2009, 09:41:01 am »
Huh?
« Reply #16 on: March 14, 2009, 18:00:24 pm »
He says that 12's should be possible, and in that case he has to lose some weight(+/- 40kg).  Cheesy
@ Dominique,correct me if I'm wrong.
Peter  Wink
TOM / EINHEIT 11
« Reply #17 on: March 14, 2009, 20:30:05 pm »
hahaha. jo hee! I bi au grad dra, 10 kg sind scho wäg.......sbild vo uns bi Cageros hetmr dr astoss gä, hahaha Grin
TOM / EINHEIT 11
« Reply #18 on: March 14, 2009, 20:32:24 pm »
hey P
a perfect translation Grin.
greetz TOM
Peter  Wink
« Reply #19 on: March 14, 2009, 21:13:09 pm »
THX   Grin   Grin    Wink
Rune
SCC Crew
Screwdrivers #7
« Reply #20 on: March 15, 2009, 00:03:57 am »
He, höran dr uf mit dem schwizer dutch do!  Grin
Lets get back on track..
« Last Edit: March 15, 2009, 01:02:58 am by Rune » Logged
bugkeeper
oldskool n numetal
« Reply #21 on: March 15, 2009, 00:29:24 am »
Hey Rune that's no schwizer dutch... that is schwiezer dütsch or schwiezer deutsch, dutch is something else  Roll Eyes
Peter's translation is perfect, I don't know why I keep writing English to you guys, Rune I hear you are half Austrian  Wink
Yes get back on track, can't wait... and Tom I lost 7 kg so far but now my weight wont budge... I guess I will have to crank up the boost level... changing the waste gate setting is far easier than loosing weight.
I am seriously trying to get rid of my midriff, if my doctor would no what motivates me after all that time he would send me to a metal institution…  Shocked
Cheers Dom  Cool
Rune
SCC Crew
Screwdrivers #7
« Reply #22 on: March 15, 2009, 01:02:01 am »
Ah shit, and I thought I was going to impress you guys here... Roll Eyes I almost got it, just spelled it wrong. Must have been using the Norwegian half of my brain.. Anyways.. Sorry for messing up the thread.
TOM / EINHEIT 11
« Reply #23 on: March 15, 2009, 12:19:11 pm »
 :Dsay,, swisscheese ,,  Grin Wink hahaha
