April 09, 2026, 09:53:09 am
352103 Posts in 28882 Topics by 6917 Members
Latest Member: joni75
| | |-+  30hp (36hp US) tuning
Author Topic: 30hp (36hp US) tuning  (Read 9377 times)
Turtle001
« on: December 23, 2006, 01:26:06 am »
hey guys -- i'm gonna tune my 30hp with a riechert kit -- do any of you guys have other suggestions to get that little motor spin as a horny kittin ...
http://turtle.skynetblogs.be
Frank LUX
Back...Soon...hopefully!!!
« Reply #1 on: December 23, 2006, 08:19:42 am »
Make it Bigger... Wink Grin Grin Grin
Frank
REY
« Reply #2 on: December 23, 2006, 09:13:52 am »
Hey my friend,
Used an Okrasa or Porsche 356 crankshaft and a perf camshaft for 36HP ..,  Wink you can find these parts via MrOK (Joe ruiz )
I think it is enought to do an interresting 36 hp..
REY
Frank LUX
« Reply #3 on: December 23, 2006, 09:28:07 am »
Or you could use this...
http://www.thesamba.com/vw/classifieds/detail.php?id=349943
Frank
REY
« Reply #4 on: December 23, 2006, 10:01:11 am »
Hey Frank,
Perfect it is exactly what I mean.. Wink
REY
« Last Edit: December 23, 2006, 10:27:53 am by REY » Logged
« Reply #5 on: December 23, 2006, 12:25:25 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=400171
besserwisser
« Reply #6 on: December 24, 2006, 21:57:48 pm »
Why not go all the way. Maximum bore and stroke. 74x83. Amotor like this was recently dynoed in Sweden at 80hp and tons of torque. Find a Porsche crank or send a 30hp crank to Demello and he will stroke it with counterweights for about the same money. You need to put larger valves in the heads and some porting would help. I have 39x32 on the 83 bore. Dual springs and a reground cam about 284degrees will make that thing move better than youre friends 1600. My pesonal oppinion is that Kadrons will do more than the solex 32 that comes with the kit. You can raise the comp up a bit but be careful the 30hp crank is your weak link in the chain. Good luck and se you at EBI.
Christoph
« Reply #7 on: December 27, 2006, 13:43:28 pm »
you can also use the 356 cams from the 1300s, 1500s, 1600s and 1600s 90 modells
« Reply #8 on: December 27, 2006, 15:26:41 pm »
sounds pretty cool!
what are you up to now turtle?  Wink
herrvee
« Reply #9 on: December 27, 2006, 21:46:13 pm »
<a href="http://www.youtube.com/v/l7TGB863IAI" target="_blank">http://www.youtube.com/v/l7TGB863IAI</a>
it is the firsts rpm of this motor.
the bloc is a 25cv one.
the crank is a 74mm porsche preA, cylinders are 80mmand heads are okrasa one ported to work with GB manifolds and solex PII carbs.
the cam is a 30hp regrind one.
all tin ware are 25hp .
one day, we will try 48idas on it. Shocked
and then NOS Grin Grin
more stories about this motor here:
http://vwisgood4you.skynetblogs.be/
hervé
« Last Edit: December 27, 2006, 21:48:36 pm by herrvee » Logged
« Reply #10 on: December 28, 2006, 04:45:31 am »
looking good hervee! yeeha  Grin
