October 14, 2026, 00:18:23 am
Various hi perf parts for sale,Empi,Berg,Bugpack etc
Topic: Various hi perf parts for sale,Empi,Berg,Bugpack etc (Read 7865 times)
March 15, 2009, 00:24:34 am »
1.4 Old real empi rockers,rocker blocks changed due to one breaking,good condition
1.5 sig erson rockers,adjusters have been changed to use more common pushrods,good condition $200
Older bugpack 1.4 rockers,nice condition $175
Berg pulley,no groove for belt,race only,ok condition,$100
Last Edit: March 18, 2009, 09:35:00 am by richie,uk
Re: Various parts for sale
March 15, 2009, 00:25:25 am »
Berg pulley
March 15, 2009, 00:27:23 am »
Older CB IDA manifolds,mild porting $80
5.6 Chevy journal H beam rods 5/16 bolts Used $100
March 15, 2009, 01:18:55 am »
90.5 Arias pistons,gas ported, used but in good condition,with pins but no rings[they take 1mm top,1.5 2nd and 2mm oil control]
"C" wrist pin height $200 per set
March 15, 2009, 01:19:58 am »
Oberg oil filter,re usable,cleanable with 2 spare new elements and oil lines $100
SOLD
Last Edit: March 25, 2009, 10:17:30 am by richie,uk
Re: Various hi perf parts for sale,Empi,Berg,Bugpack etc
March 18, 2009, 09:37:44 am »
Rods are pending,will put another batch of stuff later,everything is now in England,can take to Volksworld show
cheers richie
March 18, 2009, 10:30:02 am »
Sand seal race pulley 20
Bugpack breather tower replacement 25
Ceramic black coated 1 5/8 header new, 150
94mm copper head shims 0.040 and 0.060 thick available 25 each set
Engle FK 87,89 pre clearanced cams 70 each
all these prices english pounds,computer doesnt have the pound sign
cheers richie
Last Edit: March 19, 2009, 13:58:53 pm by richie,uk
March 18, 2009, 14:02:06 pm »
Scat 36mm,Scat 38mm @ 23 each and Berg gland nuts@35 each
Jaycee 2 piece push rod tubes,scat 2 piece double O ring push rod tubes
Scat 5.4 VW journal H beam rods,ARP 2000 3/8 bolts
Scat single Heavy duty valve springs,chromoly retainers and valve locks@ 28
All new
cheers richie
Scat 8 dowelled chromoly flywheel 95pounds[new]
Scat 5.5 I beam rods,VW journal, ARP 2000 3/8bolts 100pounds[new]
Last Edit: March 19, 2009, 14:00:45 pm by richie,uk
March 18, 2009, 16:26:47 pm »
Exhaust sold,pending payment to J-F
cheers richie
Berger
www.bugrent.no
March 19, 2009, 08:01:59 am »
"Scat 5.4 VW journal H beam rods,ARP 2000 3/8 bolts"
How much for these, Richie?
This is my simple religion:
-Be cool
-Don't be an asshole
March 19, 2009, 13:35:40 pm »
Quote from: Berger on March 19, 2009, 08:01:59 am
200 pounds
cheers richie
March 19, 2009, 13:57:35 pm »
More
10mm chromoly head studs, @45
Scat 5.5 h beam rods,chevy journal,arp 2000bolts, @200
Replacement ARP 2000 bolts, 5/16 and 3/8 available @40 per set of 8
Pre clearanced cams,@70 each [Fk 42,44,46,48,87,89 and for turbo,TCS20, FK45 on 112,45 on 114,46 on 114 and 89 on 110]
Shadeck 26mm oil pumps @25 each,30mm plugged for full flow, @30
Scat cam followers,lube a lobe,@ 65
76 gram lightweight, @70
Copper exhaust gaskets,good quality re usable @12 per set of 4
Jaycee 3/8 0.058 wall chromoly pushrods@65 set
Scat H/D VW dual valve springs @28
Various thickness barrell shims for 90.5,92 and 94mm bore@18
Berg full flow oil pump cover@35
Scat lash cap kits @5
Pr cylinder covers,cad plated@15
Remote Oil filter housing@20
All prices in pounds and parts are all new
cheers richie
peach_
March 19, 2009, 18:26:09 pm »
Has the fly wheel sold?
cheers
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
March 19, 2009, 20:12:49 pm »
No not yet
cheers richie
